    1.3k Posts 299 Posters 2.9m Views 297 Watching
      As I said, it's an install error.
      You have extracted all those curviloft... .rb files into the Plugins folder. They are loading at the wrong place. They should be in the curviloft folder. Go back to the first post and look at the Footprint of the plugin as described by Fredo.
      I think if you delete all the curviloft .rb files you see in Plugins you'll probably be fine.
        You can also use this utility to help you install ZIP packages correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
          transamws6
          I get the same error after deleting.
          I tried using the install utility as well, as was recommended in earlier posts. I pointed to the libfredo plugin zip first, followed by the curviloft plugin zip.
            Can you show a current shot of your entire Plugins folder and the current contents of the Curviloft and LiFredo folders. You must still have something installed incorrectly or the plugin would work without errors.
            You can upload your images to the forum by clicking on Upload Attachment below your text window.
            • 3 Offline
              3cookec
              Hi everyone, like some people i am having trouble with the plugin, below should be the screens of my plugin directory:
              I added fredoscale and round corners with no problem, but when i downloaded these they have Z_loaders (ZLoader__FredoScale) with the curviloft download there is no Z_loader...is this the problem?
              curviloft file
              fredo
              default plugins
                Look in Window>Preferences>Extensions and see if the box for Curviloft is checked. If it isn't, check it.
                • 3 Offline
                  3cookec
                  Just looked under extensions, curviloft does not appear on the list at all. 😐
                    What version of Windows are you using? Please edit your profile to make that information useful. Do you have full administrative rights to install files into the Plugins folder? If not, change that and reinstall the files.
                    • 3 Offline
                      3cookec
                      im using windows 7 and i have full administrative rights, the trouble is that curviloft is the only plugin that has not worked for me, could the missing Z_loader be the problem?
                        3cookec
                        This shows that you do not have FULL access rights to your Plugins folder.
                        Select your Sketchup folder's icon and right-click > context-menu > Properties [last item on the list] > Security [tab] - find you details and select the item > Edit [button]... set all permissions to be 'checked' == FULL.
                        You might need to be 'administrator' to do this effectively.
                        Being an administrator is not enough to ensure correct installation settings - even an 'admin' can have limited rights to folders within 'Program Files', which are causing you these problems.
                        This permissions-set should ripple down through the folder's subfolders/files so that you can now add files/subfolders into the Plugins folder without the system hiding them in a subfolder without telling you, and thereby giving unexpected and perplexing results.
                        This 'fix' will also allow you to use save_as etc for Materials, Components and Styles into those Sketchup subfolders too...
                          TIG beat me to it. But you don't have full administrative rights.
                          What missing z_loader? There isn't one for Curviloft.
                            It's quite possible to be an administrator and for you still not to have FULL rights to change some folders or files.
                            The system tries to protect things within folders like Program Files by limiting what you can do by default.
                            However you must reset the Sketchup folders to be 'FULL' to allow installation and save_as to work as desired...
                            • H Offline
                              hygicell
                              many thanks, TIG, for extremely helpful information
                              • 3 Offline
                                3cookec
                                Ok so I set permissions to full on google folder, sketchup folder, plugins folder. and now when I extract curviloft to plugins folder i dont get a permissions pop up, but when i load sketchup curviloft still does not show.
                                I still have 'combatibility files' tab showing , does that mean I somehow have not set full permission?
                                  Click on the Plugins folder's 'Compatibility Files' link and remove what comes up that's related to this tool.
                                  Retry installing everything related to this tool after that...
                                  Remember that it also needs the linked 'Lib' file installing, before a restart of Sketchup, as previously explained.
                                  Also remember that this particular tool is an Extension that needs activating from Preferences before you can access it...
                                  Once it's installed and the extension has been activated you should then have the menu items [as detailed on the tool's main-page] and its toolbar is activated from View > Toolbars...
                                  • 3 Offline
                                    3cookec
                                    Under 'combatibilty files' there was only roundcorner.def and LibFredo06.def, are these still related?
                                    Is the linked Lib file LIBFREDO06? i have that installed and working, or is there a different one?
                                    Under extensions, Curviloft does not appear on the list at all, and re extracting the files does not seen to help.
                                    Is there any way to get a previous version of curviloft to see if that works?
                                      The current version of Curviloft works just fine. An earlier version won't fix your problem. You don't have a unique version of SketchUp and the current version of the plugin works for thousands of users.
                                      Try this. Rename the Plugins folder to something like Plugins Original. Make a new Plugins folder (make sure you have full admin priveleges and install the Curviloft and LibFredo files in it. See if that works.
                                      • 3 Offline
                                        3cookec
                                        😍 Well it finally worked, huge thankyou to Dave R and TIG for taking time to help me out on this.
                                          Did you make the new Plugin folder? If so, carefully copy the other plugins you've got in the old one to the new one and discard the old one.
                                          • F Offline
                                            fantomie
                                            I've tried several times to install the plugin but everytime I get this error message:
                                            Error Loading File __loader.rb
                                            uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                                            uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                                            uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                                            uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                                            uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                                            What's wrong?
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 65
                                            • 66
                                            • 38 / 66
