    Chidori furniture joint
    25 Posts 7 Posters 7.7k Views 7 Watching
    • W Offline
      Woodarc
      Hi TIG just seen your modified version. Looks much easier to fabricate, will give it a try when I get the chance. Thanks for that. πŸ‘
        One of the burr puzzles I referred to. πŸ˜‰
          Remember this crazzy puzzle 😲
          My SU File πŸ˜‰
          http://www.polyloop.net/imagehosting/196484de038426a6.jpg
          http://www.polyloop.net/imagehosting/196484de03851553.jpg
            Even you find a solution in 3D that want not to say that is the solution in the reality! πŸ˜‰
            A very difficult one! πŸ‘
              Pilou, I'm not sure what you just said. I had one of those puzzles when I was a child. That one isn't too bad to figure out. πŸ˜‰
                If I had the wooden one I could probably do it with my eyes closed. When I have some time I'll put yours together.
                  You must several days of try before to find the solution by hands (if you find it ! πŸ’š
                  I know only one person who i said to test it who find it! 😲
                  All the others give up! πŸ˜’
                  It's a vicious solution! πŸ˜„
                    Muscle memory. πŸ˜’
                      Impossible to make it eyes closed! πŸ˜’
                      Carreful there are variations as shown here
                      It's not mine! πŸ˜‰
                      http://woodgears.ca/box_joint/burr_parts.jpg
                      or
                      http://t0.gstatic.com/images?q=tbn;ANd9GcQDR-xtUEH7mKeYBle0rDWmJ8y2L_44EL8p5tkL0ra6rCTXNXPV7MRi8hGx
                      etc...
                      [flash=420,315:1nd228mp]http://www.youtube.com/v/dTGO_NR6YiA[/flash:1nd228mp]
                        And I am very curious to know how
                        they build in wood because you must make some very little decrease/ decrease measures against a computer 3D model!
                        (for easy sliding)
                        If you don't know the solution i don't see how that is possible πŸ˜„
                          Roger
                          Carnegie Mellon Architecture school
                          @woodarc said:
                          Is anybody familiar with this system. I'm looking for details of the joints. The system apparently consists of 12 sticks with different junction details which connect without the aid of glues, nails or screws. I've checked out Amazon but with no joy. Any leads would be greatly appreciated. Many thanks in advance. ❓
                          Reminds me of a system that I came up with in architecture school.
                          http://www.azcreative.com
                            (for easy sliding)
                            You can hardly make it exactly right in the Model because the 'cutting' has so many variables...
                            You make some 'clamped on jigs' on your table-saw or router-table [these depend what you are using to make the cuts!] for the max/min extents of the various cuts. You make some test cuts and see how they fit together. The jigs can be 'fine tuned' by adding thin paper shims between its parts to reduce the amount cut off [or by removing them to increase the amount that is cut off] ... until the test cuts fit snuggly together - if it's a dry fit you want a tighter fit that if it were to be glued as you have to leave space for the glue! Of course if you had one of the clever [but expensive] Incra jigs [ http://www.incrementaltools.com/ ] you could input 1000th of an inch adjustments until your cuts were perfect...
                              Roger - that looks similar to a coffee-table I made over 35 years ago - remodeled in Sketchup...
                                I'd cut the joints with this:
                                http://farm8.staticflickr.com/7274/6922349406_40aa4eb0e4.jpg
                                πŸ˜„
                                A simple fixture as TIG mentions would make it simple to create accurate joints.
                                  Roger
                                  πŸ˜„
                                  I would too if I had one.
                                    I know where you can get one. πŸ˜‰
                                      In the case of the Puzzle headache...
                                      I am agree with all these tools can make any precision cuts but that can't say what "sides" must be increase or decrease! πŸ˜„
                                      Without the entiere solution's path known! πŸ˜’
                                      Else the gliding will be blocked at some place! πŸ’š
                                      It's not only the "nicks" but sometimes an entiere side face must be cut!
                                      And without the solution you can't build it! πŸ˜„
                                        guardoff
                                        Hello, Woodarc. I know how to do this joint (= I have worked out how to do it) the way that Japanese design house does it. Since I am brand-new to this forum, and don't know how to post photos, best you go to this link where I tell the whole story (for one sample joint):
                                        http://forums.delphiforums.com/n/main.asp?webtag=woodbutcher&nav=messages&msg=5596.18&prettyurl=%2Fwoodbutcher%2Fmessages%3Fmsg%3D5596%2E18
                                        It is a lot easier to make than the replies on this thread suggest - and easiest of all if you have a radial arm saw.
                                        Love this crazy forum. I will be back.
                                        Cheers
                                        Mark
