    [Plugin] Material Tools
    124 Posts 44 Posters 204.1k Views 44 Watching
    • irwanwrI
      irwanwr
      thank you very much for this plugins. 👍
      it's very useful for me to keep the file size as small as it could.
      • halroachH
        halroach
        1. Does the 'remove specific material work on textures?
        2. I've got a problem when trying to remove a specific material. Have many many materials in my model and the list of materials in the plugin is not long enough for me to see all of them. Any solution?
        3. The reason I am trying to use this plugin is for removing a material that has a TGA in it (which causes annoying errors when I first open the model). I am not able to find the TGA in the model, but am able to find the material it is in. When I try to right click on the material in the regular materials window, sketchup freezes for 10 seconds or so, and then I see the context menu for only a fraction of a second, and I am not able to actually delete the material. This happens a lot when I have a lot of materials in a model.
        This is a sketchup bug that's been around for quite a long time! Any suggestions?
        1. 'List textures in console' doesn't seem to do anything other than opening the console box, but nothing happens.
        (I'm using latest sketchup pro 8 with windows 7 64bit)
        FlexTools - Super Quick Windows, Doors, Slats...
          You mean removing texture from material?
          The plugin would remove the material - entirely. Making no distinction if it is textured or not.
          1. I've got a problem when trying to remove a specific material. Have many many materials in my model and the list of materials in the plugin is not long enough for me to see all of them. Any solution?
          That's a bug in SketchUp. Only way around it is to create a WebDialog instead - which I don't have the time for right now.
          1. The reason I am trying to use this plugin is for removing a material that has a TGA in it (which causes annoying errors when I first open the model). I am not able to find the TGA in the model, but am able to find the material it is in. When I try to right click on the material in the regular materials window, sketchup freezes for 10 seconds or so, and then I see the context menu for only a fraction of a second, and I am not able to actually delete the material. This happens a lot when I have a lot of materials in a model.
          Have you tried assigning a different texture to that material - if the purpose is to avoid the errors when you open the model? (What does the error say btw?)
            Huh! I see that as well. Sure is a bug.
          • halroachH
            halroach
            1. cool
            2. I imagine the sketchup team is aware of the bug... I really wish I could just mark a bunch of selected materials in one go, and delete them...
            3. That's a good idea! I just unchecked the texture in the material, purged, saved, and the error doesn't appear anymore.
              The error I get looked like this:
              TGA Error - must be from a really old component I downloaded
            4. happy I could be of assistance
              If you have a long list in a UI dialog you can click in the list pane and then use the up/down arrow keys to scroll to the item you want.
              If you want to jump a long way up/down a list [i.e. to somethings that's off screen!] let's say you are on 'Aardvark' but you want to jump to 'White' then press the W key and it'll jump to the first W - perhaps 'Wheat' [assuming alphanumeric sorting], then you can press the down-arrow until 'White' is the select item...
              It's not perfect... BUT it does allow you to access any item in an overly long list in a standard UI dialog... 🤓
              • halroachH
                halroach
                For some reason my list is not sorted alphanumerically... but your tip is good to know!
                  If you have an array of strings then array.sort! will sort it...
                  I'm unfamiliar with the code producing this list - but it should be easy enough to have an ordered list ??
                    Since the list of SketchUp material names which is UTF-8 - meaning there can be multi-byte characters. And Ruby's #sort will mangle these characters because it treat each byte as individual characters.
                    This is another reason why a WebDialog is better - since one can make a dropdown box with scrollbar and utilize the fact the JS is Unicode compatible. (In addition I have a natural sort algorithm that would ensure that you get numbers in correct order ( 1,2,3,10...etc instead of 1,10,2,3... )
                    • EarthMoverE
                      EarthMover
                      Thom, possible to add removing materials from all groups and components? Not the materials on the inside surfaces, just anything applied to a group or component itself and replacing it with default?
                      Content Creator at Skapeup
                        Something like
                        Sketchup.active_model.definitions.each{|d|next if d.image?;d.instances.each{|i|i.material=nil}}
                        for every group/instance in the model, ignoring whether visible/locked etc...
                        OR
                        Sketchup.active_model.selection.each{|e|e.material=nil if(e.is_a?(Sketchup;;Group)||e.is_a?(Sketchup;;ComponentInstance))&& !e.locked?)}}
                        to process all groups/instances in a selection, ignoring locked ones...
                        Copy/paste one-liners into the Ruby Console...
                          rv1974
                          Fantastic tools! 👍 Thank you.
                          What I really miss 😒 is additional script to assign the front faces material to backfaces (at least
                          on geometry with transparent mats).
                          • massimoM
                            massimo Moderator
                            404 Not Found
                            (sketchucation.com)
                                oh... I might have forgotten to upload this little update... 😳
                                  rv1974
                                  @thomthom said:
                                  [attachment=0:37kfn04k]<!-- ia0 -->Transparent.png<!-- ia0 -->[/attachment:37kfn04k]
                                  What exactly do you ask?
                                  If it's already there (the last line) I for some mystic reason don't have it (the version is updated)
                                  If it's a printscreen of the latest future update- it looks awesome (exactly what I mean (if it processes entire model)).
                                  P.S. How do you make the printscreen of the dropped down list???
                                    rv1974
                                    unpardonable forgetfulness
                                      Give me a couple of days. I need to release an update to TT_Lib2 first.
                                        rv1974
                                        Yet another thing:
                                        Assign component\group mat to its front faces (to the inner geometry with default mat) would be amazing feature.
                                        There's already the great 'remove C-G materials.rb' , something the opposite is also needed.
                                          How would you handle groups with faces of multiple materials? It's just not an symmetrical operation.
                                            rv1974
                                            Only default material within the would inherit the comp\group mat. The manually set multiple mats would survive.
                                            • 5 / 7
