    [Plugin] Scale Face to Target Area - TIG
    46 Posts 11 Posters 31.3k Views 11 Watching
      I've updated the .rb in your post and edited the post's text to match [hope you are OK with that πŸ˜‰ ]
      It now handles all Unit-types/Fractional/Engineering etc properly.
      One oddity is that 'Engineering' displays on screen in 'feet', but the API unit-type [LengthUnit] is left in 'inches' [0] - unlike all other types where the 'LengthUnit' matches the displayed-unit.
      Anyway it now works for all combos... I hope πŸ˜•
      • EarthMoverE Offline
        EarthMover
        Works great now. Thanks again.
        Content Creator at Skapeup
        • H Offline
          hebeijianke
          This plug-in only applies to the quadrangle
            NO, it works on any face.
            The selected face is simply scaled to have the desired area.
            The dialog shows the current area in current units.
            You enter the new area and OK.
            The selected face is made to have that area.
            So if it's a square, a star or a circle it doesn't matter...
            • bmikeB Offline
              bmike
              This is a great little plugin.
              Any chance to make it work in square ft, when my units are set to Architectural?
              Or do I need to divide by hand first...?
                EarthMover
                Works on almost any face. Faces created by the freehand tool seem to fail to resize properly. Not sure why.
                  jorge2011
                  @thomthom said:
                  @jorge2011 said:
                  You see this plugin?
                  Not Found
                  (rubits.com)
                  That's nice looking. The VCB is a nice way to control it. But I think $10 is too much for such a trivial script. πŸ˜•
                  YES thomthom. You are right, it's a plugin with a high cost.
                  I made the post, the plugin is very interesting, and has features that can be added to the free version plugin of sr. TIG.
                    Here's a version of the code for users who want to work in feet OR inches [any kind] and see 'sq ft' areas; it also does 'sq m' areas if the user is using any metric units [m/cm/mm]... Copy the code and paste it into the .rb file using Notepad or similar plain-text editor - overwriting all of the original code...
                    require 'sketchup.rb'
                    module TIG
                    ### scales a selected face about its center to a new area, in current units.
                    	def self.scale_face()
                    		model=Sketchup.active_model
                    		es=model.active_entities
                    		ss=model.selection
                    		fa=nil
                    		fa=ss[0] if ss[0]
                    		unless fa && fa.is_a?(Sketchup;;Face)
                    			UI.messagebox("Scale_Face;\n\nPreSelect ONE FACE !")
                    			return nil
                    		ar=fa.area
                    		mo=model.options["UnitsOptions"]
                    		if mo["LengthUnit"] > 1 ### metric
                    			units="m"
                    			ar=ar*25.4*25.4/1000/1000
                    		else ### ft/"
                    			units="ft"
                    			ar=ar/12.0/12.0
                    		rs=inputbox(["New Area [sq "+units+"];        "], [ar], "Scale_Face")
                    		return nil unless rs
                    		na= rs[0]
                    		na= -na if na < 0
                    		unless na>0
                    			UI.beep
                    			return nil
                    		ro=Math.sqrt(na/ar)
                    		pt=fa.bounds.center
                    		tr=Geom;;Transformation.scaling(pt, ro)
                    	  model.start_operation("Scale_Face")
                    		es.transform_entities(tr, fa.vertices)
                    	  model.commit_operation
                    	UI.menu("Plugins").add_item("Scale_Face"){self.scale_face()} unless file_loaded?(__FILE__)
                    	file_loaded(__FILE__)
                      EarthMover
                      Thanks TIG. That's even better!
                        Do you want to add an alternative version .rb in the first post ?
                          EarthMover
                          Sure, I can. If you feel like dropping it in it's own thread for proper indexing, let me know and I'll remove the bracketed plugin wording. Or feel free to edit it yourself if need be. I don't mind at all.
                          • I Offline
                            irich
                            Hi guys!
                            Thank you for this plugin it’s very very useful.
                            My question is, is it possible to make it scale texture on face too?
                            If you for example have one projected texture on face.
                              Hi Miso,
                              You may be interested in this plugin: http://forums.sketchucation.com/viewtopic.php?t=18992
                              • zhangyu200831Z Offline
                                zhangyu200831
                                Thank you TIG
                                  luozhan
                                  Thanks TIG. It's a very useful tool. Is there a way to scale the other faces with the same ratio? The plugin only scale the selected face, but the remaining faces remain unchanged as shown below:
                                  Please let me know. Thank you so much again!
                                  Best regards,
                                  Leo
                                    luozhan
                                    Never mind. I finally figured it out after I look into the rb code. I just use the scale tool and type in a ratio = square root of (new area/old area).
                                    • O Offline
                                      ovaleks
                                      The one who causes is like the one who does .Teşekkür ederim tig
                                      • O Offline
                                        ovaleks
                                        https://img.onl/OCybYb
                                        Hello, thank you for the plugin. It's great.
                                        How can I equalize the areas in the photo I sent? Equal area
                                          The plugin isn't intended for that use.
                                          I assume you ask how to add lines across a single face to end up with four faces of equal areas...
                                          How about this for an idea...
                                          Get my CofG tool.
                                          Delete any edges that spit the face, so that it's now one.
                                          Give that face a thickness with PushPull, so it's a solid volume, then group it.
                                          Now use CofG on the group, and the center of the volume is marked.
                                          Edit the group and add a line across it through this center marker.
                                          This should now have equal areas for the two parts.
                                          Copy the group to one side and now re-edit the group and PushPull one side till it disappears.
                                          Now you have a part with the half-area.
                                          Repeat the edit on the group copy, this time erasing the other half.
                                          Now you have two groups containing equal area parts.
                                          Repeat the whole process on each group to end up with four groups containing 1/4 area parts.
                                          Edit the groups and delete the unwanted faces/edges so you end up with single faces.
                                          Viewing sideways and selecting by fence is a quick way to leave just the top face.
                                          Arrange the 4 groups so that they align on the cut edges.
                                          If desired, explode the 4 groups so that the 4 faces join along the cuts.
                                          You can total/measure the whole starting area, the 1/4 parts are easily calculated and then checked against this.
                                          O 1 Reply Last reply Reply Quote 0
                                          • O Offline
                                            ovaleks
                                            Get my CofG tool.
                                            tig, excellent explanation, I will try and work on it, thank you, I follow you closely, your help is invaluable, thank you for your interest, best regards, tig
                                            • 2 / 3
