    [Plugin] Scale Face to Target Area - TIG
    46 Posts 11 Posters 31.3k Views 11 Watching
      @earthmover said:
      Thom, excuse my ignorance, but how would I going about testing your code?
      Sorry Adam, I typed it up and posted in a hurry. You'd put it in a .rb file and form the console invoke: TT_ScaleToArea.scale_face( Sketchup.active_model.selection[0], 4000 )
      Didn't have the time to add UI.
        The code is now tested and working version... I edited the original ! http://forums.sketchucation.com/viewtopic.php?p=419936#p419936
        Stupid typo unless**.**file_loaded? instead of unless file_loaded?
        I added the UI as an afterthought and never tested it sorry!
        • EarthMoverE Offline
          EarthMover
          Thanks TIG. It works as long as I am using a decimal unit type. With fractional units, it deletes everything in the model. Not sure why, just have to remember to switch the units before using the plugin. Thanks again. I'll update the first post with the rb file.
          Also it is still stating inches in the dialog even when the units are feet. No big deal though. Works for what I need. Thanks again! πŸ‘ πŸ‘
          Content Creator at Skapeup
            I'll adjust the code... I did type it on the fly...
              EarthMover
              If you have time. If not, no worries. I just figured I'd mention the issues in case anyone else needed to use the plugin.
                I've updated the .rb in your post and edited the post's text to match [hope you are OK with that πŸ˜‰ ]
                It now handles all Unit-types/Fractional/Engineering etc properly.
                One oddity is that 'Engineering' displays on screen in 'feet', but the API unit-type [LengthUnit] is left in 'inches' [0] - unlike all other types where the 'LengthUnit' matches the displayed-unit.
                Anyway it now works for all combos... I hope πŸ˜•
                  EarthMover
                  Works great now. Thanks again.
                  • H Offline
                    hebeijianke
                    This plug-in only applies to the quadrangle
                      NO, it works on any face.
                      The selected face is simply scaled to have the desired area.
                      The dialog shows the current area in current units.
                      You enter the new area and OK.
                      The selected face is made to have that area.
                      So if it's a square, a star or a circle it doesn't matter...
                      • bmikeB Offline
                        bmike
                        This is a great little plugin.
                        Any chance to make it work in square ft, when my units are set to Architectural?
                        Or do I need to divide by hand first...?
                          EarthMover
                          Works on almost any face. Faces created by the freehand tool seem to fail to resize properly. Not sure why.
                            jorge2011
                            @thomthom said:
                            @jorge2011 said:
                            You see this plugin?
                            Not Found
                            (rubits.com)
                            That's nice looking. The VCB is a nice way to control it. But I think $10 is too much for such a trivial script. πŸ˜•
                            YES thomthom. You are right, it's a plugin with a high cost.
                            I made the post, the plugin is very interesting, and has features that can be added to the free version plugin of sr. TIG.
                              Here's a version of the code for users who want to work in feet OR inches [any kind] and see 'sq ft' areas; it also does 'sq m' areas if the user is using any metric units [m/cm/mm]... Copy the code and paste it into the .rb file using Notepad or similar plain-text editor - overwriting all of the original code...
                              require 'sketchup.rb'
                              module TIG
                              ### scales a selected face about its center to a new area, in current units.
                              	def self.scale_face()
                              		model=Sketchup.active_model
                              		es=model.active_entities
                              		ss=model.selection
                              		fa=nil
                              		fa=ss[0] if ss[0]
                              		unless fa && fa.is_a?(Sketchup;;Face)
                              			UI.messagebox("Scale_Face;\n\nPreSelect ONE FACE !")
                              			return nil
                              		ar=fa.area
                              		mo=model.options["UnitsOptions"]
                              		if mo["LengthUnit"] > 1 ### metric
                              			units="m"
                              			ar=ar*25.4*25.4/1000/1000
                              		else ### ft/"
                              			units="ft"
                              			ar=ar/12.0/12.0
                              		rs=inputbox(["New Area [sq "+units+"];        "], [ar], "Scale_Face")
                              		return nil unless rs
                              		na= rs[0]
                              		na= -na if na < 0
                              		unless na>0
                              			UI.beep
                              			return nil
                              		ro=Math.sqrt(na/ar)
                              		pt=fa.bounds.center
                              		tr=Geom;;Transformation.scaling(pt, ro)
                              	  model.start_operation("Scale_Face")
                              		es.transform_entities(tr, fa.vertices)
                              	  model.commit_operation
                              	UI.menu("Plugins").add_item("Scale_Face"){self.scale_face()} unless file_loaded?(__FILE__)
                              	file_loaded(__FILE__)
                                EarthMover
                                Thanks TIG. That's even better!
                                  Do you want to add an alternative version .rb in the first post ?
                                    EarthMover
                                    Sure, I can. If you feel like dropping it in it's own thread for proper indexing, let me know and I'll remove the bracketed plugin wording. Or feel free to edit it yourself if need be. I don't mind at all.
                                    • I Offline
                                      irich
                                      Hi guys!
                                      Thank you for this plugin it’s very very useful.
                                      My question is, is it possible to make it scale texture on face too?
                                      If you for example have one projected texture on face.
                                        Hi Miso,
                                        You may be interested in this plugin: http://forums.sketchucation.com/viewtopic.php?t=18992
                                        • zhangyu200831Z Offline
                                          zhangyu200831
                                          Thank you TIG
                                            luozhan
                                            Thanks TIG. It's a very useful tool. Is there a way to scale the other faces with the same ratio? The plugin only scale the selected face, but the remaining faces remain unchanged as shown below:
                                            Please let me know. Thank you so much again!
                                            Best regards,
                                            Leo
                                            • 2 / 3
