    How do I make these curves and bends?
    10 Posts 7 Posters 1.5k Views 7 Watching
      3eighty
      I hate to say I give up but I need to save the rest of my hair and I would really like to learn how to make the attached bends and curves....So...How do I do these all at once?
      Thank You
      • boofredlayB
        boofredlay
        Try the attached model file.
        CompoundShape.skp
          Boofredlay's solution probably fits the bill... But a better image would help us be sure... πŸ˜•
            3eighty
            Tig; This is the item I would like to make...Thank you.
            • pbacotP
              a drive-in tray! πŸŽ‰
              My take: draw outline shape using circle, line, arc, and offset tool. Draw plan of tray with rectangle and arc tool. Plugins: Weld (or recurve) profile and tray plan edges (or soften lines on finished shape instead). Use follow-me.
              The detail (segments in arcs & cirlces etc.) depends on if you are just showing a tray or the whole drive in. (On second thought with the '57 Chevys and all, the tray polygons are irrelevant πŸ˜‰ )
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                Peter beats me but see this SU file for ideas anyway:
                Metal pan with compound curves.skp
                • boofredlayB
                  boofredlay
                  Well that sure was not what I thought it was, ha ha. I thought that was the corner of a laptop. πŸ˜†
                  • hellnbakH
                    hellnbak
                    This would look perfect hanging from the window of one of my classics
                      3eighty
                      Thanks to all...hellnbak that is exactly what I want if for..If I can get it made you will have one also..Richard
                      Jean Lemire; i had to come back after seeing your input..That is most excellent sample...As with anything else it doesn't have to be a mind breaker to make it work..Now I will add the window hangers and support..I already made the rubber mat..Thank you all again..
                      • fuzzionF
                        fuzzion
                        pan1.jpgArtisan
                        "Only the dead have seen the end of war" - Plato
