    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
      If you type [or copy/paste] the full text into the Sketchup Menu > Window > Ruby Console and press <enter> to confirm it, you will always get something returned as the answer !
      So typed correctly:
      Sketchup.find_support_file("Plugins")
      C:/Program Files/Google/Google SketchUp 8/Plugins
      Typed incorrectly [i.e. not an initial capital 'S']:
      sketchup.find_support_file("Plugins")
      *Error: #<NameError: undefined local variable or method sketchup' for main:Object> (eval):155* Typed incorrectly another way [i.e. without a final 's']: Sketchup.find_support_file("Plugin")`
      nil
      So even if the file/folder you are looking for doesn't exist you will get 'nil' 😒
      Can't you do the folders screen-shot I mentioned before?
      You seem to be making very heavy-weather of this 😕
      • K
        kersnyc
        I have attached a print of the screen...
          But you did get an answer, Keryn. The answer was
          "C:/Program Files/Google/Google SketchUp 8/Plugins"
          You got that answer three times.
            Hooray!
            You do have a Plugins folder after all 😮
            Find that 'Plugins' folder [navigate your folders using Windows-Explorer...] and put the script/subfolder-of-files that ship inside the zip into it.
            Check that the added files are really in the folder - I know your profile says XP but you might have changed? and Vista/Win7 can sometimes put such things into a side-folder IF you are not an Admin or have insufficient security permissions.
            The subfolders inside the Sketchup folder should all have FULL permissions of you as you will from time to time want to add files into them...
            Once the file/subfolder is in place restart Sketchup and everything should then work.
            • W
              whitelock
              hi I need to install the fredo 6 plugin for round corners and unlike other plugins where its just been a simple drag and drop into the plugins folder. this download seems to be full of lots of files and I am not sure which ones to put in the plugins folder!!! I am not very computer savvy when I read the installation instructions (im on a mac) it said:
              Unzip ‘RoundCorner 2.0.zip', by doing a Select All and then Extract in the Plugins
              directory of Sketchup, answering YES to all prompts for file overwriting, in order to
              make sure you reconstruct the folder hierarchy. NEVER change the name of files or
              move them from their folder. The footprint should be (Windows environment):
              I have no idea what I should do!! can anyone plese help
                All of the files in the ZIP file should go into the Plugins folder but they need to maintain the same footprint as they have when you open the ZIP file. Fredo has outlined this very clearly in his first post of this thread. Go back and look at that. It's really quite simple and you should wind up with a folder and a Ruby file when they get installed.
                • W
                  whitelock
                  Thanks for the reply, however I mean to stress I dont know what un-zipping files means. the file on my desktop is a blue folder. I open that and I have a .rb script and another blue folder. I open that and its filled with loads of .rb scripts, some pdfs some pngs and more blue folders with more pdfs and pngs. So waht do you do from here. I tried dragging the whole folder over into my plugins folder and when I opened sketchup it had a warning error loading plugins message, so I closed SU, went back to plugins folder and moved the file back to my desktop. I then tried moving all the .rb files over and got the same message when I opened SU. So again I removed all the files and put them back in the blue folder on the desktop. I then deleted the files and tried downloading the plugin again. It is then that I saw you need the additional lib fredo 6 plugin. i downloaded this first and was confronted with the same problem, I have a blue folder inside which there is a .rb script and another blue folder containing a mass of .rb scripts, png, pdfs etc. I gave up at this point!!!!
                  normally I am used to just dragging one .rb script across the plugins folder and it works.
                  So to reiterate my point what is unzipping? and what items do i drag over?.
                  I did read the instructions fully several times and they make no sense unless you are fluent in computer speak. which I am not I am a complete philistine so I need laymans terms if possible.
                  thanks
                    Stop right there. Copy the file and the folder to the Plugins folder and you're finished.
                    "Zipping" is a method of compressing files so they are smaller for transferring from one computer to another. Unzipping is decompressing. By opening the ZIP file on your Mac you are gaining access to the files inside and that is enough.
                    • fredo6F
                      @whitelock
                      As you are on Mac, you should follow the specific instructions for Mac. Note that this is because OSX hides the process of Un-zipping and shows the resulting files and folders in the dedicated Download Window.
                      On Mac OSX
                      1. Click on the Zip archive on Sketchucation
                      2. This should open the Download box with highlight on the folder LIBFREDO6_Dir_46 and LibFredo6.rb
                      3. Copy this folder and file to the Sketchup Plugins directory
                        Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
                      The footprint on Mac OSX in the SU Plugin Directory must be:
                      PS: It would be helpful if a Mac users with a video capture software could make a short video on how installation can be done on Mac
                        Or, use Simple Installer which is a single .rb that needs to be placed in the plugins folder.
                        Then use that to install RBZ, ZIP, RB or RBS plugins.
                        404 Not Found
                        (forums.sketchucation.com)
                        • W
                          whitelock
                          thank you all for your help and patience!!! I will let you know how I get on.
                          • V
                            vittete
                            hi,
                            i got a small problem.
                            whenever i press on round corners in 3D, it crashes imediatly.
                            any suggestions?
                            thanks in advance
                              What is "it"?
                              • V
                                vittete
                                hei, sorry. everything works. thanks! it's a great and easy tool!
                                • Z
                                  zick
                                  ty sir
                                  • P
                                    pyeng3
                                    wow thank you very much I'll try it.. hai I am Newbie, I just came registered here because ma sketchup program always produce bug splat. but I m also want to learn a more skill about this great program..
                                    • C
                                      cacowan
                                      Issue with it crashing SketchUp Pro 8. Now running OS 10.8.1. Crashes on even the simple things. Can it be fixed? Is it the OS? I'm only trying to use Fredo Scale.
                                        Have you installed everything into the correct Mac HD.. 'plugins' folder?
                                        Reread the download details.
                                        Have you kept everything inside the subfolder in which it was packaged as a zip ?
                                        If you have files loose inside the Plugins folder that ought to be inside the Lib's subfolder you must remove them as they will now be auto-loadings and causing all kinds of weirdness...
                                        On a MAC it's possible to setup Safari to auto-extract zips into a folder - this causes confusion because all guidance assumes that the zip files are intact and you will manually extract them, keeping files inside any subfolders etc.
                                        If you do have a 'zip' file [or any other downloaded format for that matter] then the safest way of installing its contents is to use thomthom's simple installer - http://forums.sketchucation.com/viewtopic.php?p=375454#p375454 it works in v8 PC AND MAC - you do need to install this first from the RBZ file using the clear instructions ... using Preferences > Extensions > Installer button...
                                        Good luck.
                                        How do you mean 'crash' - are there messages in the Ruby Console?
                                        Is it a Bugsplat! etc ? ...
                                        • C
                                          cacowan
                                          ShetchUp crashes. Shuts down. Closes. Work reverts to last saved version on reopening SketchUp. I've learned to save before trying to use the tool so I don't have to go dig out the autosave file.
                                          Fredo Scale and all the Fredo Tools were downloaded exactly as detailed in the user download and installed and working perfectly before I upgraded the OS from 10.7 to 10.8, so I can only assume its the upgrade.
                                          I'm going to try a reinstall later today, but wondered if anyone else was having this problem after upgrading. If not, I may have another issue going on...OR the tools need tweaking in order to work with 10.8. I'd just like to have an idea which it is before I go messing around with files that used to work... And waste more time.
                                          I tried updating LibFredo6 to v4.6c, and that did nothing. (previous to the upgrade I had 4.6a working). Purging the outdated files in the folder via the upgrade screen didn't help either. Kind of frustrated because I've come to rely on the ability to correct sizing on my construction drawings with the ability to choose where the stretch or shrink should occur.
                                            Others are using FredoScale with OS 10.8.1 so it isn't likely to be Fredo's files. Others have reported that the permissions for the Plugins folder have changed after upgrading the OS. Perhaps that's what has happened in your case. Make sure the Plugins folder isn't set to be Read Only.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 113
                                            • 114
                                            • 21 / 114
