    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 314.2k Views 172 Watching
      pibuz
      ..I still can't figure out how to install and make this plugin properly work 😆
      I've downloaded the new addition by Pejman, but same error message when loading (something about not being able to insert an empty component..).
      Moreover, no toolbar shows up.....
      I'm no noob, but I really can't figure this out 😆
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • KrisidiousK Offline
        Krisidious
        delete your LiveIvy folder in side your plugins folder. make sure you have no plugins for liveivy inside your plugins folder.
        reinstall by opening the last zip folder and dragging the plugin and folders into your plugins folder.
        you'll need to restart sketchup. go to toolbars and turn on the liveivy toolbar.
        should work. make sure that there are ivy components in your "Plugins\LiveIvy\Textures" folder.
        By: Kristoff Rand
          Krisidious
          look at tips in the console. you'll have to grow the ivy branches and then hit ctrl click to put leaves on. you'll see green markers where leaves are going to be located. then hit shift click to finish.
          By: Kristoff Rand
          • charly2008C Offline
            charly2008
            HI
            I installed the "LiveIvy 1" but there are generated only strains and no leaves. Am I doing something wrong? In the Ruby Console is displayed, see below.
            Problem solved: I had forgotten to press the ctrl key.
            Charly
              charly2008
              Hi Krisidious,
              Thank you for your help
              Charly
                Krisidious
                no problem I guess you figured it out before I even got my response in. have fun and feel free to post some examples. and settings to go with them.
                would love to add some presets to this plugin.
                By: Kristoff Rand
                  charly2008
                  Maybe you can help me again. Now the leaves are not transparent! The problem was treated in an earlier post but I could not find it until now.
                  Charly
                    Krisidious
                    I had to go in and edit each component and it's material. each material source needs to be a .png file for transparency. and then I hid the line edges and saved the component. let me see if I can upload mine.
                    By: Kristoff Rand
                      pibuz
                      I did exactly like this, last time. Just to make sure, I re-did that and it's just the same: "can't insert empty component" (I'm translating the message from italian). Under "View->toolbars" there is no option to turn on the LiveIvy toolbar. If I choose the tool manually, I can generate the red lines and leaves, but generating the actual geometry leads to no real geometry but a simple black line over the first stem's position (no leaves and no additional stems).
                      ..your latest post also makes me wonder if these problems could be generated by base components saved in SU8 format..If so, could anybody convert them to the previous version, to maximize compatibility?
                      • rodrigonotorR Offline
                        rodrigonotor
                        Charly
                        Hi Charly, he`re others
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=36882&p=409877&hilit=sketchup+ivy#p409877
                        regards
                        • Sketchando.net • www.arqcad.net •
                          charly2008
                          Hi Kristoff,
                          thank you for your friendly help. With your files, it works fine. Thanks also to the others.
                          I've tried similar to your example to do this with the Wisteria flowers and leaves. But the old leaves are still present, although only the Wisteria pngs are in the Texture directory.
                          I probably have not understood how it works or I'm too stupid.
                          Charly
                          IVY.zip
                          • E Offline
                            ehitel
                            How can i make to them from more close to de wall?
                              Thiago Luz
                              When I SHIFT + CLICK nothing happens ... creates just one line ends and not the creation of branches and leaves ... what's wrong??
                                smooge
                                i can not get this to work at all! on mac with su8 have looked thro forum and still no help? is thare sumthing rong with what im doing?
                                  You'll have to explain more detailed what "isn't working".
                                  No menus? Error messages? Unexpected results?
                                    smooge
                                    sorry! when i click on an object in the space it dos nothing at all i can see all the plugin and looks like it will wurk but wen i click nuthing happens?
                                      If you keep the Ruby Console open, do you get any error messages?
                                        smooge
                                        yes!
                                        MX: unloading Fire data
                                        MX: load => plan 12-09-11
                                          smooge
                                          sorry no that is from maxwell i think!
                                            craigcampbell66
                                            Some help with Sketchup Ivy appreciated. I have downloaded/installed and run the plugin fine although there was an error message at installation and each time I start the plugin(capture). My issues are that The leaf 2 and 3 have a white background displayed in model and when rendered. see image capture1. The material editor in Sk8 has leaf 1 as a .tif and 2 and 3 as .jpg's. I thought I could just go into the folder in plugins find the images and convert them to tifs to give a see through background but therein lies my problem. I can't find the plugin or folder where I extracted it to nor in any of the sub folders of sketchup. I have tried to reinstall (both extract to and copy from a separate location) but it says the file is already there and would I like to overwrite it?? Given I can't find it I can't remove it to try and re-install again in case the initial was corrupted ie the white backgrounds. Thanks to Pierre though for what looks like a great plugin once I get it sorted.
                                            Thanks also to whoever is able to assist
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 36
                                            • 37
                                            • 26 / 37
