    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.8k Views 172 Watching
    • T
      the.pjt
      oh oh oh ... I'm so sorry ....and a stupid person ... sorry
      I have uploaded previous file ...
      that was not the new ZIP files ...
      here is the full files ...
      LiveIvy-1.zip
      dear TIG , I's sorry for that mistake agane , I'm sorry for taking your time downloading ,reading it and writhing frum post .. sorry TIG ...
      dear ThomThom .. I's sorry
      I hope this This toolbar and its Icons could be usefull for you sketchukators ...
      zipped from my own plugin folder
      100% tested 😄
      here is a screenshot
      • rodrigonotorR
        rodrigonotor
        thanks, now it´s working
        • Sketchando.net • www.arqcad.net •
          • P
            pibuz
            ..I still can't figure out how to install and make this plugin properly work 😆
            I've downloaded the new addition by Pejman, but same error message when loading (something about not being able to insert an empty component..).
            Moreover, no toolbar shows up.....
            I'm no noob, but I really can't figure this out 😆
            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
            • KrisidiousK
              Krisidious
              delete your LiveIvy folder in side your plugins folder. make sure you have no plugins for liveivy inside your plugins folder.
              reinstall by opening the last zip folder and dragging the plugin and folders into your plugins folder.
              you'll need to restart sketchup. go to toolbars and turn on the liveivy toolbar.
              should work. make sure that there are ivy components in your "Plugins\LiveIvy\Textures" folder.
              By: Kristoff Rand
              • KrisidiousK
                Krisidious
                look at tips in the console. you'll have to grow the ivy branches and then hit ctrl click to put leaves on. you'll see green markers where leaves are going to be located. then hit shift click to finish.
                By: Kristoff Rand
                • charly2008C
                  charly2008
                  HI
                  I installed the "LiveIvy 1" but there are generated only strains and no leaves. Am I doing something wrong? In the Ruby Console is displayed, see below.
                  Problem solved: I had forgotten to press the ctrl key.
                  Charly
                  • charly2008C
                    charly2008
                    Hi Krisidious,
                    Thank you for your help
                    Charly
                    • KrisidiousK
                      Krisidious
                      no problem I guess you figured it out before I even got my response in. have fun and feel free to post some examples. and settings to go with them.
                      would love to add some presets to this plugin.
                      By: Kristoff Rand
                      • charly2008C
                        charly2008
                        Maybe you can help me again. Now the leaves are not transparent! The problem was treated in an earlier post but I could not find it until now.
                        Charly
                        • KrisidiousK
                          Krisidious
                          I had to go in and edit each component and it's material. each material source needs to be a .png file for transparency. and then I hid the line edges and saved the component. let me see if I can upload mine.
                          By: Kristoff Rand
                          • P
                            pibuz
                            I did exactly like this, last time. Just to make sure, I re-did that and it's just the same: "can't insert empty component" (I'm translating the message from italian). Under "View->toolbars" there is no option to turn on the LiveIvy toolbar. If I choose the tool manually, I can generate the red lines and leaves, but generating the actual geometry leads to no real geometry but a simple black line over the first stem's position (no leaves and no additional stems).
                            ..your latest post also makes me wonder if these problems could be generated by base components saved in SU8 format..If so, could anybody convert them to the previous version, to maximize compatibility?
                            • rodrigonotorR
                              rodrigonotor
                              Charly
                              Hi Charly, he`re others
                              http://forums.sketchucation.com/viewtopic.php?f=323&t=36882&p=409877&hilit=sketchup+ivy#p409877
                              regards
                              • charly2008C
                                charly2008
                                Hi Kristoff,
                                thank you for your friendly help. With your files, it works fine. Thanks also to the others.
                                I've tried similar to your example to do this with the Wisteria flowers and leaves. But the old leaves are still present, although only the Wisteria pngs are in the Texture directory.
                                I probably have not understood how it works or I'm too stupid.
                                Charly
                                IVY.zip
                                • E
                                  ehitel
                                  How can i make to them from more close to de wall?
                                  • T
                                    Thiago Luz
                                    When I SHIFT + CLICK nothing happens ... creates just one line ends and not the creation of branches and leaves ... what's wrong??
                                      smooge
                                      i can not get this to work at all! on mac with su8 have looked thro forum and still no help? is thare sumthing rong with what im doing?
                                        You'll have to explain more detailed what "isn't working".
                                        No menus? Error messages? Unexpected results?
                                          smooge
                                          sorry! when i click on an object in the space it dos nothing at all i can see all the plugin and looks like it will wurk but wen i click nuthing happens?
                                            If you keep the Ruby Console open, do you get any error messages?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 36
                                            • 37
                                            • 22 / 37
