    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tak2hata
      @sufractal said:
      takshata:
      I just installed your new plugin, but all of the boxes in the dialog window are filled in 'black' and I cannot see the values inside of them?
      Thanks.
      hi,SUFractal.
      I am out now.
      So I will test it later.
      But I tested this verison in mac os yesterday.It was no problems.
      Please tell me you install from "RBZ"? or "ZIP".
      Thanks.
      by TAK2HATA
      • T
        troypiggo
        @sufractal said:
        takshata:
        Thanks.
        Sounds like this problem: http://forums.sketchucation.com/viewtopic.php?f=11&t=45382
        This is not my signature. I type it at the end of every message for quality control.
        • T
          tak2hata
          @troypiggo said:
          @sufractal said:
          takshata:
          Thanks.
          Thanks troypiggo.
          It is very helpful information.
          I will add html code about text background color to white.
          Thanks.
          by TAK2HATA
          • Z
            ZFRPS
            Thanks takshata !
            sketchup is bim
              SUFractal
              @tak2hata said:
              @sufractal said:
              takshata:
              Thanks.
              hi,SUFractal.
              I am out now.
              Thanks.
              I've installed it via both methods, but with no change in result.
              I have also kept my original .list.csv files.
              Thanks.
              • kenK
                ken
                Hello
                After installing V 1.0a, I have the following error code. Not sure why.
                Thanks in advance for your plugins and help
                Ken
                • T
                  tak2hata
                  Hi,all.
                  I update version1.1a.
                  ...andyomis.
                  I placed the profile list file in the top of threadhttp://forums.sketchucation.com/viewtopic.php?f=323&t=35798#p315482
                  please download "default_pflist.csv" or "northAmerica_pflist.csv" or "default_pflist_xml(unzip from default_pflist_xml.zip)".
                  And change profile list path.
                  "menu" -> "plugins" -> "building structure tools1.0" - > "change profile list path"
                  ....SUFractal.
                  The problem is related to web browser "Safari".
                  I changed css styles about textbox text color to white.
                  Probabry you will see texts in textbox.
                  (But that problem is not shown on my mac os, so it fixed "probabry")
                  ...Ken.
                  I fixed about sending command with imperial length to webdialog.
                  Thanks to becoming Completion for all.
                  by TAK2HATA
                  • T
                    tak2hata
                    HI,all.
                    I update to version 1.1b.
                    Very Small bugfix. πŸ˜‰
                    The error about color name fixed.
                    Thanks.
                    by TAK2HATA
                      SUFractal
                      @tak2hata said:
                      HI,all.
                      Thanks.
                      Thanks tak2hata.
                      (Not sure if this matters, but I generally don't use Safari anyway.)
                      • B
                        Ben Ritter
                        Thank you very much for your hard work and generosity
                        • B
                          Ben Ritter
                          What do I need to do to select North American shapes?
                          • kenK
                            ken
                            Hello
                            Ken
                            Tak2hata
                            Thanks for the update 1.1b. It fixed the above illustrated error. However, I notice now, that the beams selection will not make any beams that are vertical. It will make beams close to vertical but not exactly 90 degrees. As close as I can get to vertical is 0.067 degrees off vertical. I didn't see this problem on the first version.
                            Again thanks for the quick response on the other error.
                            Ken
                            • T
                              tak2hata
                              place it valid path.(the path must not include non-english characters)
                              And Set that file by the menu "Change Profile List Path".
                              Menubar -> "Plugins" -> "building structure tools v1.0" -> "Change Profile List Path"
                              It will work fine! πŸ‘
                              by TAK2HATA
                                SUFractal
                                @tak2hata said:
                                HI,all.
                                Thanks.
                                Excellent! (White text in black box = clever!) The basic function appears to be working now. I'll jump into the fancier features you've added when I get a chance.
                                Thanks again tak2hata ... this is a great plugin!
                                  andyomis
                                  Tak2hata san,
                                  Thank you very much for the bug fix and the profile files
                                  • Z
                                    ZFRPS
                                    Tak2hata:
                                    Thank you very much !
                                    I LOVE YOU !
                                    sketchup is bim
                                    • T
                                      tak2hata
                                      Hello
                                      Ken
                                      Tak2hata
                                      Ken
                                      Hi,Ken.
                                      I want to see your description as picture.and parameters in webdialog.
                                      And I have an elementary question.
                                      "degrees" is units of distance?
                                      In my country ,distance is decimal.so I'm not used to be the degree as distance.
                                      Does 90 degrees equal to 1/4"?
                                      Thanks.
                                      by TAK2HATA
                                      • kenK
                                        ken
                                        The three illustration show a yellow background rectangle, 2'wide by 10' tall. Starting at the bottom at the center line closest I can get the 4x13 I beam to vertical is 9/64 off the center vertical line at the top. So right now I can not draw any beams exactly vertical.
                                        Hope this helps.
                                        Ken
                                          SUFractal
                                          Hope this helps.
                                          Ken
                                          Ken:
                                          For comparison's sake, I did a similar test and do not seem to have an issue with true verticality. I used the 'column' tool and my column was 12'-0" tall. I noticed that you used the term 'beam' ... are you by any chance using the beam tool to try to draw a vertical line as a column? Is that perhaps the cause?
                                          SUFractal
                                          • kenK
                                            ken
                                            Well yes, I am using the beam tool, along with the "bar, T-bar, pipe, angles and beams" None these selection will make a vertical object. Note, zooming in for a real close view, I can see that as long as the top (note going from the top to bottom doesn't make a difference) selection point is outside the area where the point will be snapped to the vertical I can make any of the above objects. However, if I let Sketchup snap take over and the point is snap to a vertical position, than the program will not make the selected object, "beam, bars, pipe angle or beams". See the attached file.
                                            Ken
                                            Vertical Test Ken.skp
                                            • 16
                                            • 17
                                            • 7 / 17
