    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 514.1k Views 108 Watching
      tak2hata
      HI,all.
      I update to version 1.1b.
      Very Small bugfix. πŸ˜‰
      The error about color name fixed.
      Thanks.
      by TAK2HATA
        SUFractal
        @tak2hata said:
        HI,all.
        Thanks.
        Thanks tak2hata.
        (Not sure if this matters, but I generally don't use Safari anyway.)
          Ben Ritter
          Thank you very much for your hard work and generosity
            Ben Ritter
            What do I need to do to select North American shapes?
            • kenK Offline
              ken
              Hello
              After installing V 1.0a, I have the following error code. Not sure why.
              Thanks in advance for your plugins and help
              Ken
              Tak2hata
              Thanks for the update 1.1b. It fixed the above illustrated error. However, I notice now, that the beams selection will not make any beams that are vertical. It will make beams close to vertical but not exactly 90 degrees. As close as I can get to vertical is 0.067 degrees off vertical. I didn't see this problem on the first version.
              Again thanks for the quick response on the other error.
              Ken
                tak2hata
                place it valid path.(the path must not include non-english characters)
                And Set that file by the menu "Change Profile List Path".
                Menubar -> "Plugins" -> "building structure tools v1.0" -> "Change Profile List Path"
                It will work fine! πŸ‘
                by TAK2HATA
                  SUFractal
                  @tak2hata said:
                  HI,all.
                  Thanks.
                  Excellent! (White text in black box = clever!) The basic function appears to be working now. I'll jump into the fancier features you've added when I get a chance.
                  Thanks again tak2hata ... this is a great plugin!
                    andyomis
                    Tak2hata san,
                    Thank you very much for the bug fix and the profile files
                    • Z Offline
                      ZFRPS
                      Tak2hata:
                      Thank you very much !
                      I LOVE YOU !
                      sketchup is bim
                        tak2hata
                        Hello
                        Ken
                        Tak2hata
                        Ken
                        Hi,Ken.
                        I want to see your description as picture.and parameters in webdialog.
                        And I have an elementary question.
                        "degrees" is units of distance?
                        In my country ,distance is decimal.so I'm not used to be the degree as distance.
                        Does 90 degrees equal to 1/4"?
                        Thanks.
                        by TAK2HATA
                        • kenK Offline
                          ken
                          The three illustration show a yellow background rectangle, 2'wide by 10' tall. Starting at the bottom at the center line closest I can get the 4x13 I beam to vertical is 9/64 off the center vertical line at the top. So right now I can not draw any beams exactly vertical.
                          Hope this helps.
                          Ken
                            SUFractal
                            Hope this helps.
                            Ken
                            Ken:
                            For comparison's sake, I did a similar test and do not seem to have an issue with true verticality. I used the 'column' tool and my column was 12'-0" tall. I noticed that you used the term 'beam' ... are you by any chance using the beam tool to try to draw a vertical line as a column? Is that perhaps the cause?
                            SUFractal
                            • kenK Offline
                              ken
                              Well yes, I am using the beam tool, along with the "bar, T-bar, pipe, angles and beams" None these selection will make a vertical object. Note, zooming in for a real close view, I can see that as long as the top (note going from the top to bottom doesn't make a difference) selection point is outside the area where the point will be snapped to the vertical I can make any of the above objects. However, if I let Sketchup snap take over and the point is snap to a vertical position, than the program will not make the selected object, "beam, bars, pipe angle or beams". See the attached file.
                              Ken
                              Vertical Test Ken.skp
                                tak2hata
                                Ken
                                Hi,Ken,SUFracatal.
                                I understand this problem.
                                This is mistake of mine.
                                I want to limit the drawing wall as vertical.(It make error certainly.)
                                But this code is not so.
                                I will fix this bug later.Now I am out of my computer.
                                Sorry,Please wait.
                                Thanks.
                                by TAK2HATA
                                • guanjinG Offline
                                  guanjin
                                  tak2hata:
                                  Thank you for your hard work
                                  How to disappear other tools? icons, language change does not completely!
                                  Click on the icon does not work
                                    tak2hata
                                    H,All.
                                    I update this.
                                    ...KEN.
                                    BUGFIX :about create nothing when clicks points as Vertical.
                                    It will clear the problem.
                                    ...guanjin.
                                    Laungage .......
                                    Wait deadly tried me.
                                    or You can change word as you like If you can edit html.
                                    It is more convenient to be both?
                                    or If it is both, what will be troubled?
                                    I can not know what makes problem from that text.
                                    Good night. πŸ˜‰
                                    by TAK2HATA
                                    • Z Offline
                                      ZFRPS
                                      tak2hata:
                                      about create nothing when clicks points as Vertical,
                                      in v1.1d not clear,
                                      please try one times it ;
                                      Thanks again !
                                      sketchup is bim
                                        tak2hata
                                        tak2hata:
                                        in v1.1d not clear,
                                        Thanks again !
                                        Hi.
                                        At first,when working with the class "wall" ,you can not pick second point to vertical.
                                        I need to know more detailed information if this is not your case.
                                        1. Screen shot of setting inBst dialog.
                                        2. The axis the slope directing to.(x,y,z)
                                        3. The message Ruby console shows when the error is exists.
                                        4. I want to see the two picked points were truely vertical.
                                        Please reply about lines above.
                                        by TAK2HATA
                                        • Z Offline
                                          ZFRPS
                                          Dear tak2hata:
                                          This my test,please try it again !
                                          Your this plugin already very powerful,I wish it change more powerful πŸ‘
                                            thanks again!
                                          sketchup is bim
                                            tak2hata
                                            Dear tak2hata:
                                            [attachment=3:22lfhpqk]<!-- ia3 -->c01.jpg<!-- ia3 -->[/attachment:22lfhpqk][attachment=2:22lfhpqk]<!-- ia2 -->c02.jpg<!-- ia2 -->[/attachment:22lfhpqk][attachment=1:22lfhpqk]<!-- ia1 -->c03.jpg<!-- ia1 -->[/attachment:22lfhpqk][attachment=0:22lfhpqk]<!-- ia0 -->c04.jpg<!-- ia0 -->[/attachment:22lfhpqk]
                                              thanks again!
                                            Hi,zfrps.
                                            "MWALL" is not able to create automatically from curves.
                                            I will test "COLUMN" auto create.
                                            tak2hata:
                                            in v1.1d not clear,
                                            Does this reply mean this problem?
                                            Thnx.
                                            by TAK2HATA
                                            • 16
                                            • 17
                                            • 8 / 17
