    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 535.3k Views 108 Watching
      tak2hata
      Hi,all.
      I update version1.1a.
      ...andyomis.
      I placed the profile list file in the top of threadhttp://forums.sketchucation.com/viewtopic.php?f=323&t=35798#p315482
      please download "default_pflist.csv" or "northAmerica_pflist.csv" or "default_pflist_xml(unzip from default_pflist_xml.zip)".
      And change profile list path.
      "menu" -> "plugins" -> "building structure tools1.0" - > "change profile list path"
      ....SUFractal.
      The problem is related to web browser "Safari".
      I changed css styles about textbox text color to white.
      Probabry you will see texts in textbox.
      (But that problem is not shown on my mac os, so it fixed "probabry")
      ...Ken.
      I fixed about sending command with imperial length to webdialog.
      Thanks to becoming Completion for all.
      by TAK2HATA
        tak2hata
        HI,all.
        I update to version 1.1b.
        Very Small bugfix. πŸ˜‰
        The error about color name fixed.
        Thanks.
        by TAK2HATA
          SUFractal
          @tak2hata said:
          HI,all.
          Thanks.
          Thanks tak2hata.
          (Not sure if this matters, but I generally don't use Safari anyway.)
            Ben Ritter
            Thank you very much for your hard work and generosity
              Ben Ritter
              What do I need to do to select North American shapes?
              • kenK Offline
                ken
                Hello
                After installing V 1.0a, I have the following error code. Not sure why.
                Thanks in advance for your plugins and help
                Ken
                Tak2hata
                Thanks for the update 1.1b. It fixed the above illustrated error. However, I notice now, that the beams selection will not make any beams that are vertical. It will make beams close to vertical but not exactly 90 degrees. As close as I can get to vertical is 0.067 degrees off vertical. I didn't see this problem on the first version.
                Again thanks for the quick response on the other error.
                Ken
                  tak2hata
                  place it valid path.(the path must not include non-english characters)
                  And Set that file by the menu "Change Profile List Path".
                  Menubar -> "Plugins" -> "building structure tools v1.0" -> "Change Profile List Path"
                  It will work fine! πŸ‘
                  by TAK2HATA
                    SUFractal
                    @tak2hata said:
                    HI,all.
                    Thanks.
                    Excellent! (White text in black box = clever!) The basic function appears to be working now. I'll jump into the fancier features you've added when I get a chance.
                    Thanks again tak2hata ... this is a great plugin!
                      andyomis
                      Tak2hata san,
                      Thank you very much for the bug fix and the profile files
                      • Z Offline
                        ZFRPS
                        Tak2hata:
                        Thank you very much !
                        I LOVE YOU !
                        sketchup is bim
                          tak2hata
                          Hello
                          Ken
                          Tak2hata
                          Ken
                          Hi,Ken.
                          I want to see your description as picture.and parameters in webdialog.
                          And I have an elementary question.
                          "degrees" is units of distance?
                          In my country ,distance is decimal.so I'm not used to be the degree as distance.
                          Does 90 degrees equal to 1/4"?
                          Thanks.
                          by TAK2HATA
                          • kenK Offline
                            ken
                            The three illustration show a yellow background rectangle, 2'wide by 10' tall. Starting at the bottom at the center line closest I can get the 4x13 I beam to vertical is 9/64 off the center vertical line at the top. So right now I can not draw any beams exactly vertical.
                            Hope this helps.
                            Ken
                              SUFractal
                              Hope this helps.
                              Ken
                              Ken:
                              For comparison's sake, I did a similar test and do not seem to have an issue with true verticality. I used the 'column' tool and my column was 12'-0" tall. I noticed that you used the term 'beam' ... are you by any chance using the beam tool to try to draw a vertical line as a column? Is that perhaps the cause?
                              SUFractal
                              • kenK Offline
                                ken
                                Well yes, I am using the beam tool, along with the "bar, T-bar, pipe, angles and beams" None these selection will make a vertical object. Note, zooming in for a real close view, I can see that as long as the top (note going from the top to bottom doesn't make a difference) selection point is outside the area where the point will be snapped to the vertical I can make any of the above objects. However, if I let Sketchup snap take over and the point is snap to a vertical position, than the program will not make the selected object, "beam, bars, pipe angle or beams". See the attached file.
                                Ken
                                Vertical Test Ken.skp
                                  tak2hata
                                  Ken
                                  Hi,Ken,SUFracatal.
                                  I understand this problem.
                                  This is mistake of mine.
                                  I want to limit the drawing wall as vertical.(It make error certainly.)
                                  But this code is not so.
                                  I will fix this bug later.Now I am out of my computer.
                                  Sorry,Please wait.
                                  Thanks.
                                  by TAK2HATA
                                  • guanjinG Offline
                                    guanjin
                                    tak2hata:
                                    Thank you for your hard work
                                    How to disappear other tools? icons, language change does not completely!
                                    Click on the icon does not work
                                      tak2hata
                                      H,All.
                                      I update this.
                                      ...KEN.
                                      BUGFIX :about create nothing when clicks points as Vertical.
                                      It will clear the problem.
                                      ...guanjin.
                                      Laungage .......
                                      Wait deadly tried me.
                                      or You can change word as you like If you can edit html.
                                      It is more convenient to be both?
                                      or If it is both, what will be troubled?
                                      I can not know what makes problem from that text.
                                      Good night. πŸ˜‰
                                      by TAK2HATA
                                      • Z Offline
                                        ZFRPS
                                        tak2hata:
                                        about create nothing when clicks points as Vertical,
                                        in v1.1d not clear,
                                        please try one times it ;
                                        Thanks again !
                                        sketchup is bim
                                          tak2hata
                                          tak2hata:
                                          in v1.1d not clear,
                                          Thanks again !
                                          Hi.
                                          At first,when working with the class "wall" ,you can not pick second point to vertical.
                                          I need to know more detailed information if this is not your case.
                                          1. Screen shot of setting inBst dialog.
                                          2. The axis the slope directing to.(x,y,z)
                                          3. The message Ruby console shows when the error is exists.
                                          4. I want to see the two picked points were truely vertical.
                                          Please reply about lines above.
                                          by TAK2HATA
                                          • Z Offline
                                            ZFRPS
                                            Dear tak2hata:
                                            This my test,please try it again !
                                            Your this plugin already very powerful,I wish it change more powerful πŸ‘
                                              thanks again!
                                            sketchup is bim
                                            • 16
                                            • 17
                                            • 8 / 17
