[Plugin]T2H_BuildingStructureTools2.2.4 in20141207
Depressed!
Early versions of the dot, line automatically created according to the function also is gone!! -
Depressed!
Early versions of the dot, line automatically created according to the function also is gone!!Hi,zfrps.
I think your sketchup was missing profile list filepath.
Profile schema keeps working well.In this version the profile list is not included in main file.
Because installing guard from overwriting the already existed profile list you changed.So you must set your profile list file path,if you delete your profile list with building structure tool folder.
The generating automatically from edges with "apply" button.Please watch video I added in first thread.
Thanks. -
takshata:
I just installed your new plugin, but all of the boxes in the dialog window are filled in 'black' and I cannot see the values inside of them?
Thanks.
Tak2hata san
Thank you for your reply. I have now loaded the new .rbz file.
When I open the BST tool options there are no profiles listed.
When I select CLASS I get the following message "how to edit_pflist.pdf is not Exists. So read from default.
When I select OK I get the following message "could not find profile list. So select your profile list file"
There is no CSV file or xml file that I can select.When I cancel the select file dialog some default profile appear.
If I change the class then I get the same sequences of messages again.When I look at the other tabs in the BST tool options the box backgrounds are black so I can't see anything.
Can you guide me to the csv or xml file. Thank you
@sufractal said:
takshata:
Thanks.
hi,SUFractal.
I am out now.
So I will test it later.
But I tested this verison in mac os yesterday.It was no problems.Please tell me you install from "RBZ"? or "ZIP".
Thanks.
@sufractal said:
takshata:
Thanks.
Sounds like this problem: http://forums.sketchucation.com/viewtopic.php?f=11&t=45382
@troypiggo said:
@sufractal said:
takshata:
Thanks.
Thanks troypiggo.
It is very helpful information.I will add html code about text background color to white.
Thanks.
Thanks takshata !
@tak2hata said:
@sufractal said:
takshata:
Thanks.
hi,SUFractal.
I am out now.
Thanks.
I've installed it via both methods, but with no change in result.
I have also kept my original .list.csv files.
Thanks.
Hello
After installing V 1.0a, I have the following error code. Not sure why.
Thanks in advance for your plugins and help
Ken
Hi,all.
I update version1.1a....andyomis.
I placed the profile list file in the top of threadhttp://forums.sketchucation.com/viewtopic.php?f=323&t=35798#p315482
please download "default_pflist.csv" or "northAmerica_pflist.csv" or "default_pflist_xml(unzip from default_pflist_xml.zip)".
And change profile list path.
"menu" -> "plugins" -> "building structure tools1.0" - > "change profile list path"....SUFractal.
The problem is related to web browser "Safari".
I changed css styles about textbox text color to white.
Probabry you will see texts in textbox.
(But that problem is not shown on my mac os, so it fixed "probabry")
...Ken.
I fixed about sending command with imperial length to webdialog.Thanks to becoming Completion for all.
HI,all.
I update to version 1.1b.
Very Small bugfix.
The error about color name fixed.Thanks.
@tak2hata said:
HI,all.
Very Small bugfix.
Thanks tak2hata.
(Not sure if this matters, but I generally don't use Safari anyway.)
Thank you very much for your hard work and generosity
What do I need to do to select North American shapes?
Hello
Ken
Tak2hata
Thanks for the update 1.1b. It fixed the above illustrated error. However, I notice now, that the beams selection will not make any beams that are vertical. It will make beams close to vertical but not exactly 90 degrees. As close as I can get to vertical is 0.067 degrees off vertical. I didn't see this problem on the first version.
Again thanks for the quick response on the other error.
Ken
place it valid path.(the path must not include non-english characters)
And Set that file by the menu "Change Profile List Path".
Menubar -> "Plugins" -> "building structure tools v1.0" -> "Change Profile List Path"It will work fine!
@tak2hata said:
HI,all.
Very Small bugfix.
Excellent! (White text in black box = clever!) The basic function appears to be working now. I'll jump into the fancier features you've added when I get a chance.
Thanks again tak2hata ... this is a great plugin!
Tak2hata san,
Thank you very much for the bug fix and the profile files
Tak2hata:
Thank you very much !
I LOVE YOU !
