    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 535.3k Views 108 Watching
    • Z Offline
      ZFRPS
      Thanks takshata !
      sketchup is bim
        SUFractal
        @tak2hata said:
        @sufractal said:
        takshata:
        I just installed your new plugin, but all of the boxes in the dialog window are filled in 'black' and I cannot see the values inside of them?
        Thanks.
        hi,SUFractal.
        I am out now.
        So I will test it later.
        But I tested this verison in mac os yesterday.It was no problems.
        Please tell me you install from "RBZ"? or "ZIP".
        Thanks.
        I've installed it via both methods, but with no change in result.
        I have also kept my original .list.csv files.
        Thanks.
        • kenK Offline
          ken
          Hello
          After installing V 1.0a, I have the following error code. Not sure why.
          Thanks in advance for your plugins and help
          Ken
            tak2hata
            Hi,all.
            I update version1.1a.
            ...andyomis.
            I placed the profile list file in the top of threadhttp://forums.sketchucation.com/viewtopic.php?f=323&t=35798#p315482
            please download "default_pflist.csv" or "northAmerica_pflist.csv" or "default_pflist_xml(unzip from default_pflist_xml.zip)".
            And change profile list path.
            "menu" -> "plugins" -> "building structure tools1.0" - > "change profile list path"
            ....SUFractal.
            The problem is related to web browser "Safari".
            I changed css styles about textbox text color to white.
            Probabry you will see texts in textbox.
            (But that problem is not shown on my mac os, so it fixed "probabry")
            ...Ken.
            I fixed about sending command with imperial length to webdialog.
            Thanks to becoming Completion for all.
            by TAK2HATA
              tak2hata
              HI,all.
              I update to version 1.1b.
              Very Small bugfix. πŸ˜‰
              The error about color name fixed.
              Thanks.
              by TAK2HATA
                SUFractal
                @tak2hata said:
                HI,all.
                Thanks.
                Thanks tak2hata.
                (Not sure if this matters, but I generally don't use Safari anyway.)
                  Ben Ritter
                  Thank you very much for your hard work and generosity
                    Ben Ritter
                    What do I need to do to select North American shapes?
                    • kenK Offline
                      ken
                      Hello
                      Ken
                      Tak2hata
                      Thanks for the update 1.1b. It fixed the above illustrated error. However, I notice now, that the beams selection will not make any beams that are vertical. It will make beams close to vertical but not exactly 90 degrees. As close as I can get to vertical is 0.067 degrees off vertical. I didn't see this problem on the first version.
                      Again thanks for the quick response on the other error.
                      Ken
                        tak2hata
                        place it valid path.(the path must not include non-english characters)
                        And Set that file by the menu "Change Profile List Path".
                        Menubar -> "Plugins" -> "building structure tools v1.0" -> "Change Profile List Path"
                        It will work fine! πŸ‘
                        by TAK2HATA
                          SUFractal
                          @tak2hata said:
                          HI,all.
                          Thanks.
                          Excellent! (White text in black box = clever!) The basic function appears to be working now. I'll jump into the fancier features you've added when I get a chance.
                          Thanks again tak2hata ... this is a great plugin!
                            andyomis
                            Tak2hata san,
                            Thank you very much for the bug fix and the profile files
                            • Z Offline
                              ZFRPS
                              Tak2hata:
                              Thank you very much !
                              I LOVE YOU !
                              sketchup is bim
                                tak2hata
                                Hello
                                Ken
                                Tak2hata
                                Ken
                                Hi,Ken.
                                I want to see your description as picture.and parameters in webdialog.
                                And I have an elementary question.
                                "degrees" is units of distance?
                                In my country ,distance is decimal.so I'm not used to be the degree as distance.
                                Does 90 degrees equal to 1/4"?
                                Thanks.
                                by TAK2HATA
                                • kenK Offline
                                  ken
                                  The three illustration show a yellow background rectangle, 2'wide by 10' tall. Starting at the bottom at the center line closest I can get the 4x13 I beam to vertical is 9/64 off the center vertical line at the top. So right now I can not draw any beams exactly vertical.
                                  Hope this helps.
                                  Ken
                                    SUFractal
                                    Hope this helps.
                                    Ken
                                    Ken:
                                    For comparison's sake, I did a similar test and do not seem to have an issue with true verticality. I used the 'column' tool and my column was 12'-0" tall. I noticed that you used the term 'beam' ... are you by any chance using the beam tool to try to draw a vertical line as a column? Is that perhaps the cause?
                                    SUFractal
                                    • kenK Offline
                                      ken
                                      Well yes, I am using the beam tool, along with the "bar, T-bar, pipe, angles and beams" None these selection will make a vertical object. Note, zooming in for a real close view, I can see that as long as the top (note going from the top to bottom doesn't make a difference) selection point is outside the area where the point will be snapped to the vertical I can make any of the above objects. However, if I let Sketchup snap take over and the point is snap to a vertical position, than the program will not make the selected object, "beam, bars, pipe angle or beams". See the attached file.
                                      Ken
                                      Vertical Test Ken.skp
                                        tak2hata
                                        Ken
                                        Hi,Ken,SUFracatal.
                                        I understand this problem.
                                        This is mistake of mine.
                                        I want to limit the drawing wall as vertical.(It make error certainly.)
                                        But this code is not so.
                                        I will fix this bug later.Now I am out of my computer.
                                        Sorry,Please wait.
                                        Thanks.
                                        by TAK2HATA
                                        • guanjinG Offline
                                          guanjin
                                          tak2hata:
                                          Thank you for your hard work
                                          How to disappear other tools? icons, language change does not completely!
                                          Click on the icon does not work
                                            tak2hata
                                            H,All.
                                            I update this.
                                            ...KEN.
                                            BUGFIX :about create nothing when clicks points as Vertical.
                                            It will clear the problem.
                                            ...guanjin.
                                            Laungage .......
                                            Wait deadly tried me.
                                            or You can change word as you like If you can edit html.
                                            It is more convenient to be both?
                                            or If it is both, what will be troubled?
                                            I can not know what makes problem from that text.
                                            Good night. πŸ˜‰
                                            by TAK2HATA
                                            • 16
                                            • 17
                                            • 8 / 17
