    How to make it pls
    28 Posts 6 Posters 1.6k Views 6 Watching
    • E
      erzane
      WOW! is it so easy !!??
      it makes it automaticly ?
      pls wait a moment , I will try it
        It is that easy, indeed!
        And all done with the native tools. No plugins to install. 😉
        • Mike LuceyM
          Mike Lucey
          Well done Dave ..... 'up there for thinking and down there for dancing!' 👍
          • E
            erzane
            so, I made the basis but I didn't succeed to use the follow me tool
            the truth is that I didn't understood your explanations well lol
            http://img513.imageshack.us/img513/9172/capture01fa.jpg
              The profile needs to be aligned on the radius of the circular path.
              Start with the circular path centered on the origin and the rectangular face on a radius of the circle. I delete the face of the circle before running Follow Me because if you don't, there'll be no face created on the bottom of the extrusion.
              Thanks, Mike.
              • E
                erzane
                I succeeded it
                but I didn't needed to erase the basis circle
                I just choosed the follow me tool and pushed ''Alt''
                http://img708.imageshack.us/img708/1589/capture01oy.jpg
                thanks for your help 😉
                  Glad you got it to work.
                  Now correct the face orientation so the back faces (blue) are inside and delete the circle for the path and you're finished.
                  • E
                    erzane
                    done
                    now I would like to place it on the center of the circle but I dont know how to center it..
                    http://img824.imageshack.us/img824/2113/capture01qi.jpg
                      Probably the easiest way would be to add some temporary cross hairs at the bottom center of the thing. Then grab the thing at the center with the Move tool and move it to the center of that other circle. It would be best if you make that shape a component and change its axes so they are centered at its bottom center. then bring the component in from the Component browser. See this for reference.
                      • E
                        erzane
                        ok I see, this is the famous glue I learned last year
                        I forget all about what I learned last year, it's terrific lol
                        anyway during your reply I do it like this
                        I erased the circle and created a new one from the basis with the offset tool
                        http://img805.imageshack.us/img805/773/capture01r.jpg
                          Good. Now correct the face orientation. Don't be sloppy in your modeling. 😉
                            Where did you read that, Pilou? I don't see that anywhere in his original post.
                            You right for the text 😉
                            I had interpreted the images! And was right! 😉
                            And sure your method is more speedy than the FredoScale when you start from the beginning! 😉
                            But when you have yet the object, that is an another story! 😄
                            • 2 / 2
