    How to make it pls
    28 Posts 6 Posters 1.1k Views 6 Watching
    • E Offline
      erzane
      Dave R your draw is correct, do you have another technic ?
      http://img228.imageshack.us/img228/4174/ioioz.jpg
      Philou are you french ?
      p.s. si oui c plus simple de parler français car l'anglais ça va mais ça peine un peu dans ce genre d'explications
      anyway I will try again to install fredo again
        Excellent!
        The thing your blue arrow is pointing at is the profile and the circle is the path for Follow Me.
        http://farm9.staticflickr.com/8146/7566939162_3a11ff9a69.jpg
        I started out with a rectangle on which to draw the profile.
        I deleted the unneeded parts of the rectangle, selected the edge of the circle, got Follow Me and clicked on the profile.
        It's sort of the reverse of making a section cut from the shape. Draw the section cut and make a shape.
        • E Offline
          erzane
          WOW! is it so easy !!??
          it makes it automaticly ?
          pls wait a moment , I will try it
            It is that easy, indeed!
            And all done with the native tools. No plugins to install. 😉
            • Mike LuceyM Offline
              Mike Lucey
              Well done Dave ..... 'up there for thinking and down there for dancing!' 👍
              • E Offline
                erzane
                so, I made the basis but I didn't succeed to use the follow me tool
                the truth is that I didn't understood your explanations well lol
                http://img513.imageshack.us/img513/9172/capture01fa.jpg
                  The profile needs to be aligned on the radius of the circular path.
                  Start with the circular path centered on the origin and the rectangular face on a radius of the circle. I delete the face of the circle before running Follow Me because if you don't, there'll be no face created on the bottom of the extrusion.
                  Thanks, Mike.
                  • E Offline
                    erzane
                    I succeeded it
                    but I didn't needed to erase the basis circle
                    I just choosed the follow me tool and pushed ''Alt''
                    http://img708.imageshack.us/img708/1589/capture01oy.jpg
                    thanks for your help 😉
                      Glad you got it to work.
                      Now correct the face orientation so the back faces (blue) are inside and delete the circle for the path and you're finished.
                      • E Offline
                        erzane
                        done
                        now I would like to place it on the center of the circle but I dont know how to center it..
                        http://img824.imageshack.us/img824/2113/capture01qi.jpg
                          Probably the easiest way would be to add some temporary cross hairs at the bottom center of the thing. Then grab the thing at the center with the Move tool and move it to the center of that other circle. It would be best if you make that shape a component and change its axes so they are centered at its bottom center. then bring the component in from the Component browser. See this for reference.
                          • E Offline
                            erzane
                            ok I see, this is the famous glue I learned last year
                            I forget all about what I learned last year, it's terrific lol
                            anyway during your reply I do it like this
                            I erased the circle and created a new one from the basis with the offset tool
                            http://img805.imageshack.us/img805/773/capture01r.jpg
                              Good. Now correct the face orientation. Don't be sloppy in your modeling. 😉
                                Where did you read that, Pilou? I don't see that anywhere in his original post.
                                You right for the text 😉
                                I had interpreted the images! And was right! 😉
                                And sure your method is more speedy than the FredoScale when you start from the beginning! 😉
                                But when you have yet the object, that is an another story! 😄
                                • 2 / 2
