    I quit sketchup because of follow me.
    29 Posts 14 Posters 6.7k Views 14 Watching
    • pbacotP Offline
      Actually they are from the same circle, so the base lines are not the same. So I see, the way SU defines the radius this would mean arc #13 would have other problems and an arch drawn with it would not dimension properly. I keep wanting to put "circle" and "arc" in quotes. The same issue we beat to death here, but not quite, regarding finding points that would easily be defined by a true arc.
      • Rich O BrienR Online
        @Pilou
        Doesn't TIG have some plugin that draws arc in this way?
          Sorry I must miss something! 😳
          How do you draw the "13" arc for have perpendicular segments without a rotation?
          If you make a rotation, what is advantage to have odd number except kabalistic πŸ˜„
          I have not that! 😳
          (view top)
          12-13.skp
            Maybe Tig True Tangent ?
            Arc curve set ? by Tig
            Arc by tools by TIG β˜€
                It's my previous method above β˜€
                http://forums.sketchucation.com/download/file.php?id=89720&t=1
                  I did that but you showed it in more detail. Thank you.
                  Although it would be nice if SketchUP did real circles without vertices, we have to live with what it does do. It's not that difficult to set up the Follow Me path and the profile perpendicular to each other.
                    I wonder if the OP has quit?
                    Lot's of great answers here but so far silence from Anarchist86ed.
                    • pbacotP Offline
                      I have not that! 😳
                      (view top)
                      [attachment=1:nfr6v75i]<!-- ia1 -->12-13.jpg<!-- ia1 -->[/attachment:nfr6v75i]
                      That's how you do it.
                      I would think the answer to the second question was obvious, the point of our conversation.
                      I will continue to wonder about other ways of doing things and try to understand what is the reasoning.
                      • soloS Offline
                        • pbacotP Offline
                          I wonder if you are Anarchist "86ed" (see english idom) you've been kicked out of the anarchists , or if 85 other anarchists are boss of you? πŸ˜‰
                          • 2 / 2
