    A better offset for non coplanar faces !?
    17 Posts 6 Posters 1.8k Views 6 Watching
    • ely862meE Offline
      ely862me
      @rich o brien said:
      Hi Eli,
      Does this net overlay match the underlying mesh?
      Yup, that's the main reason I created it manually to match the grooves, so it will be easier for the next operations !
      Elisei (sketchupper)
      Come and See EliseiDesign
        Is this going to be printed/rendered?
        The reason I ask is that could you make a custom texture that fulfills the effect?
        • ely862meE Offline
          ely862me
          I wouldn't pay that much attention to details, unfortunately it has to be 3d printed . Inside the grooves will be placed real ropes to attach the cabin underneath and to give it a real effect .
          Thanks and have a lovely day !
          PS I am off to bed now(already 01:00 AM here) . I hope to wake up tomorrow with some new solutions(in my mind) 😎 !
            Did you try this in Blender? It has a very good latticing tool but it would mean remodeling.
            Or I know Rhino has this also (Jeff may know more on this)?
            • ely862meE Offline
              ely862me
              @rich o brien said:
              Did you try this in Blender? It has a very good latticing tool but it would mean remodeling...
              I haven't tried other software yet, and I think I won't do it , at least not for this project !
              This morning I woke up with new strength and I started removing the small segments from the offset operation. It took me about 3 hours, but now it is done !
              Thanks to all for the comments and ideas !
              • jeff hammondJ Offline
                πŸ‘ πŸ‘
                that's pretty much how you have to do it.. πŸ˜‰ sketchup is awesome in many regards but it just can't (automatically) handle this type of stuff properly..
                looks good.
                • ely862meE Offline
                  ely862me
                  Thanks Jeff !
                  I don't know how ruby works but I thought it will be easy to create a plugin that will search for segments which are smaller than, lets say 1mm and remove those segments and connect the lose end to/with the nearest segment. Will it be possible ?
                    @ely862me said:
                    Thanks Jeff !
                    Edge Tools
                    http://forums.sketchucation.com/viewtopic.php?t=24593
                    Use the "Inspect and Close Gaps" feature. I use it all the time for cleaning up CAD drawings. It doesn't just connect to closest vertex, but tries to extend line segments to nearest intersection - ensuring straight corners.
                    hmm... think I forgot to make a video tutorial on that...
                    • ely862meE Offline
                      ely862me
                      Your tool is interesting, but it doesn't do the job .
                      See attached , what I would like it to do is to remove the small segment and move the lose end to the hidden line but at the end of the other segment .
                      A work around will be to have a plugin removing the small edges(if geometry is not erased/or even then), then to move the loose end near to the other closer segment's end which is placed on the hidden line(better explained to move it to the nearest intersected lines).
                      Your tool(after I deleted the small segment) just placed the loose end randomly on the hidden line .
                      STEP 1-Deleting small segments(given range)
                      STEP 2-Tried to recreate with your plugin,but didn't worked as expected
                      This should be the correct step 2
                      Thanks !
                        Ah, I see. No my tool cannot do that. 😞
                        • EarthMoverE Offline
                          EarthMover
                          I think best case scenerio would be for Fredo to add a function to Offset on Surface which will perform multiple offsets at once on all "hard" edges in an organic shape. Perhaps a request is in order.
                          Content Creator at Skapeup
