    Organic forms
    21 Posts 7 Posters 2.7k Views 7 Watching
    • brookefoxB
      brookefox
      I think there are some ways of smooving that would help; the selection of faces is the key, but another approach might be to create a profile with which to use follow me, like a half circle, faced and deformed. Make a curve to follow and round the ends.
      ~ Brooke
      • fuzzionF
        fuzzion
        Artisan Plugin
        "Only the dead have seen the end of war" - Plato
        • P
          pluke100
          In that case the surface will be all straight while I need it to go up and down.
          @fuzzion said:
          Artisan Plugin
          [attachment=0:30f2itmh]<!-- ia0 -->SNAKETAIL1.jpg<!-- ia0 -->[/attachment:30f2itmh]
          That looks promising. I can create the sides with your method and then I can subdivide the flat part and sculpt it. Think I need to choose a method and perfect it.
          • brookefoxB
            brookefox
            I don't think you mentioned that. Perhaps I should have guessed.
            Curviloft: loft along path.
            ~ Brooke
            • P
              pluke100
              Wow thanks! That's a very useful plugin
              • X
                xrok1
                Check out the video in the first post: http://forums.sketchucation.com/viewtopic.php?t=34868
                โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                • brookefoxB
                  brookefox
                  I believe another option would be to use follow me or other tools to get your shape as you want it (constant Z) and then use 'shape bender' to align with a 3d curve. gilles would know.
                  ~ Brooke
                  • fuzzionF
                    fuzzion
                    TGI3d plugin
                    • P
                      pluke100
                      Thanks for all the suggestions guys. I've settled with using Sandbox + the Artisan plugin. They are interchangeable and they allow me to create more organic forms (albeit taking more time). The auto smooth in the Artisan plugin helps cleaning up slightly the edges. Once again thanks to everyone who contributed!
                      screenshot
                      • brookefoxB
                        brookefox
                        The horse ain't dead yet and I just want to save you from yourself. I think sandbox and artisan are very likely your finishing tools, but to get the model to finish I must simply insist: make the 3d curve path, create the face which covers the box in the way you want it most typically and then use curviloft along path to make the whole damn thing ready for fine tuning.
                        No need to agree. Anyone.
                        ~ Brooke
                        • HieruH
                          Hieru
                          Yes, I agree, that's pretty much my most common workflow for this kind of landscaping.
                          www.davidhier.co.uk
                          • P
                            pluke100
                            How do i get the curviloft with the sandbox grid? I create a sandbox grid and do the profile and path on it then loft? and is there a way where i can flatten some parts to the flat plane if i decide to remove something which i did and didn't like (undo is not possible)?
                            • pbacotP
                              Have some pictures, steps, (or video) to go with that, Brooke? ๐Ÿ˜‰
                              • P
                                pluke100
                                He already posted it in previous posts ๐Ÿ˜„
                                • brookefoxB
                                  brookefox
                                  Curviloft will create a sandbox grid as a function of 'skinning' or 'lofting', the grid is simply the edges which define the individual faces. You must turn on display hidden geometry in order to see them.
                                  Once you have created your basic mound you can use smoove or Artisan (or even simply move edges manually) to deform it locally, either make it flatter or otherwise shape it. Undo should work fine. You can undo incrementally in curviloft as well, with the little orange back arrow, I think.
                                  Let us know if you want more examples and/or post what you come up with.
                                  ~ Brooke
                                  • P
                                    pluke100
                                    So I had a change of plan and I'm going to create a sort of a small scale golf course. What's the best way to raise up and lower the sand beds?
                                    Ideally I want a whole mesh so I can fine tune it how I want in the end. I guess for the sand beds it would be better to make geometry lines and use from contours, but i guess that will result in a separate mesh right?
                                    golf course
                                    Something like the result i want.
                                    http://2.bp.blogspot.com/-7n70QgJ9hsQ/TtzzMiuiH8I/AAAAAAAAAZQ/kpI6uSpOAuY/s400/Ground-For-Golf-Courses.jpg
