    *NOT SOLVED* UV Mapping Stuff with Unity - Help Please?
    16 Posts 4 Posters 3.2k Views 4 Watching
      Is there a forum for Unity users? seems to me you're more likely to run into someone there who knows how to solve your problem.
      • T
        TalentNinjaInc
        You guys are missing the point! 😒 😞
        I need to know how to UV map in Sketchup. How do I do that and then export it?
        This isn't a Unity problem! This is me trying to learn Sketchup.
          I'll have a stab at this....
          [a] Are you exporting textured models?
          [b] Are the models triangulated prior to export?
          [c] Solid colours in SketchUp are not textures therefore have no UV values. So does Unity have mapping capabilities?
            Excuse me! You wrote, "I don't want textures on it UNTIL its in Unity." πŸ˜’
            As Rich said, solid colors are not textures and don't have UV values.
              Can you answer my questions please?
              If you want to learn about what UV mapping is then try reading wikipedia. When you understand it a bit more or need something clarified ask here. But so far you have failed to explain yourself clearly. This maybe because you are not fully understanding the intricacies of working in 3D?
              • T
                TalentNinjaInc
                Okay - I'm going to try this real simple like.
                How do I create a UV map in Sketchup?
                And @Rich
                A) No.
                B)I don't think so..?
                C) None. No Mapping at all in Unity.
                • T
                  TalentNinjaInc
                  Edited my original reply for you Rich. I didnt see your post.
                    OK, so we are getting somewhere....
                    [a] if you are exporting untextured model then your geometry has no uv values applied. If untiy doesn't have mapping tools then it is unable to texture an area if that area hasn't got UV values already.
                    [b] if unity is trinagulating geometry on import then it may lead to other issues. This can be addressed later.
                    Have you watched this?
                    • T
                      TalentNinjaInc
                      We are getting somewhere indeed!
                      So what you're saying is that I have to add a texture to it in Sketchup, and it will automatically create the UV details? Thus allowing me to export and import it into Unity with said texture still applied? Am I understanding your concept?
                        You are seeing the route you should at least test.
                        Try this on a cube to see what happens. Don't use colours as these are not textures as I mentioned already. If when you export a cube and things still have errors holla back.
