    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 152.1k Views 43 Watching
    • pbacotP Offline
      No, displacement is another mode like bump (you choose it by clicking where it says "mode"), but capable of more extreme molding of the shape, and more time consuming than bump. You might look at this tutorial by Jason that has some information on bump. Clip number 3/8
      http://www.maxwellrender.com/index.php/maxwell_for_google_sketchup/tutorials
        MMM717
        Great, thanks! Jason's videos are excellent, and really helped me in getting this far. I've already watched the first seven, but will look at #3 again...
        • RichardR Offline
          Richard
          Mate you will get all sorts of issues turning on displacement unless you divide the surface up a lot! Plus additional render times.
          Peter is right that this material should work well just as automatic, though I would reset the colour in SU prior to rendering with fire and make any adjustments to the material in the plugin. Weird things can happen when you add colour to the material in SU.
          Certainly SSS would be the right kid of material for this stone in the real world but use some caution rendering, and if you do use SSS then ensure the geometry has volume!
          BUILTBRAND.COM.AU
            MMM717
            I see that! πŸ˜„
            I tried displacement with around a 27mm setting, and it really didn't help me. I then tried 56mm, and I can't even get it to render. The manual states there are two different displacement modes (one with a note that it is harder to render than the other), but my computer isn't giving me a choice of displacement modes for whatever reason. Maybe that's all the free version has...
            I'm going to try an in-between displacement size and see if that will render...
            • jason_marantoJ Offline
              jason_maranto
              This thread has more info about using displacement based materials in SketchUp: http://www.maxwellrender.com/forum/viewtopic.php?f=107&t=38223
              However I would avoid displacement based materials whenever possible if you are rendering within SketchUp since you are limited in RAM.
              Materials are a very complex topic (possibly the most complex issue when dealing with Maxwell) and if you really want to learn more about them in depth then it might be worthwhile watching these series I made:
              http://www.vtc.com/products/Maxwell-Render-2-Tutorials.htm
              http://www.vtc.com/products/Google-SketchUp-to-Maxwell-Render-Workflow-Tutorials.htm
              They are both a little dated (mostly in the fact that they pre-date FIRE) -- but the materials related content is still valid and it would likely save you many hours of trial and error.
              For instance, what you have here is not likely to make a good bump map because the contrast is too low -- which is perfectly natural considering it is white rock. So you would want to increase the contrast (and possibly modify the brightness as well) so that you get dark "darks" and light "whites" in the texture for the bump map, which will significantly improve your resulting detail (this can be done much better in Photoshop using levels if you know how). Here's a quick example of a what a better bump would look like:Flagstone_chop_crop.png
              When you start getting into textures you often come up against the issue of "baked in lighting" (as you have in this texture) which can be a real problem -- better quality textures are photographed in such a way as to reduce "baked in lighting"... which will make the resulting material render much better.
              Best,
              Jason.
              an example sketchup file.
                MMM717
                Thanks for your help, Jason. Are there any of these videos in particular that I should take a look at that best relate to this issue?
                  jason_maranto
                  Not particularly -- it's more of the fundamentals of the material system (in relationship to the rendered output) and the SketchUp to Maxwell series expands on those ideas to talk about the embedded character-type materials and what their strengths and weaknesses are.
                  The idea is to get a solid foundation in what the various materials settings do in Maxwell and how you can bend them to your desired purpose with the least amount of trial and error possible.
                  If I've seen any one area where more people are confused than any other (in regards to Maxwell) it is definitely materials -- it is really important to understand the fundamentals of the system to avoid wasting your time... I would just start with the free videos and I bet that would be enough to answer many questions already for you.
                  Do bear in mind that I recommend anybody using the stand-alone plugin to download the trial version of the full Maxwell Render Suite to have access to MXED (allowing you to create your own custom MXM files for use in the plugin).
                  Best,
                  Jason.
                    MMM717
                    Thanks Jason! You've been a big help...
                      MMM717
                      I've been considering adding some trees/bushes/etc. to my model. I looked through the Sketchup 3d warehouse, and tried out these two first:
                      Error 404 (Not Found)!!1
                      (sketchup.google.com)
                      When rendering in Maxwell, the both the tree and bush are rendering 2d/flat instead of 3d.
                      Should I be looking for a particular type of model that appears 3d in Maxwell? Is there something I can do to make the above ones (or others) appear 3d, even though they're showing 2d presently?
                      Thank you...
                        SketchUp can't convert a 2D image to 3D. Try searching the warehouse for a 3D tree.
                          MMM717
                          Thanks. I thought these were both 3D models, since each page allows for a "3D View", but I guess not! πŸ˜„
                          • Mistro11M Offline
                            Mistro11
                            Can I keep Kerkythea plugin in SU at the same time or would it cause conflict?
                            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                            Structural Integrity is Not Just Physical...It's in the Design and Purpose
                            • brodieB Offline
                              brodie
                              I don't speak from experience but I don't see why the two would cause a conflict. You can save a copy of your plugins folder just in case though. If it causes an issue just go back to the copy.
                              -Brodie
                              • pbacotP Offline
                                I have been trying the free Maxwell plugin. It doesn't seem to be able to do two point perspective. I thought some renderers did. Anyone know which ones do off-hand? Maybe it was K-T which I haven't used in a long time.
                                • brodieB Offline
                                  brodie
                                  Yes, I don't believe the real-time engine can do that. With the full version, however, that is able to be handled during the export process.
                                  -Brodie
                                  • pbacotP Offline
                                    I exported a Maxwell scene and made many changes in GIMP etc. to make an image (background, color adjustments). Now I want to re-export a scene with a few specific things remodeled as an alternate design. I want to insert those changed areas into my previously developed image.
                                    Maxwell Fire appears to depend on the size of the SU window on screen to setup the extents of the shot. I can set the pixel width but how do I exactly set the extents of the shot to what I had before. I am back at the same monitor and I might get close by guessing at the window size, but what if I were using my laptop monitor instead? If the file save from Maxwell fire is the exact extents and pixels, it's easy to overlay in PS.
                                      jason_maranto
                                      I cover custom aspect ratios in video 4/8 of this playlist:
                                      Best,
                                      Jason.
                                      • pbacotP Offline
                                        Thank you Jason! I know I'd seen that before, but at the time I didn't know how I'd use it--so I guess it slipped my mind. That should do the trick.
                                        Peter
                                          Cubcrafter
                                          I have been going thru this tread and the Maxwell for SketchUp looks like it could be a good render for what I want to do. I am an architect and I have no experience at all with rendering.
                                          First I would like to be able to do clay renderings, but I do not know where to begin. I design R/C aircraft that I laser cut and kit and I would like to do a clay rendering of this attached image that I have done all of the work in SketchUp.
                                          This is a Eindecker EIII at 1/3 scale - 135" wingspan. I would like to put clay renderings into the assembly instructions.
                                          I have downloaded the free plugin and watched some of the videos but I didn't see anything about clay renderings.
                                          Are there any tutorials or guides that could get me started with clay renderings.
                                          Thanks,
                                          Larry
                                          Over view
                                          What I would like to be able to do
                                          Wing closeup
                                            jason_maranto
                                            In the plugin Scene Manager go to the "Output" tab and find the "Materials" subsection -- there you will see a checkbox to enable material overide, which when activated will allow you to load any MXM you might like to use for your clay material (I've attached a simple one).
                                            You can get more MXMs from http://resources.maxwellrender.com and I have a large array of colors (183 based on the RAL system) you might find useful for clay renders here: http://resources.maxwellrender.com/scripts/Diffuse1_9227.zip
                                            Best,
                                            Jason.
                                            basic_clay.zip
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
