    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 145.8k Views 49 Watching
      @schoobie said:
      Questions:
      1. And how do I convert labels to construction points?
      2. Where do I insert the code TIG is suggesting?
      3. I have imported in the past from GE to SU with this plugin and do not remember having this issue.
      1. The code changes adds cpoints at all labels.
      2. Search the script for the first set of code and add the extra lines context.add_cpoint c where shown...
      3. ???
        schoobie
        @tig said:
        @schoobie said:
        Questions:
        3. ???
        Wow, thanks!
        Quite simple, but very impressive!
        • JClementsJ Offline
          JClements
          Thanks TIG for helping out.
            dawrightau
            This is a great tool thank you. I am using it to import contour lines but am having an issue with failing to import all data with more detailed contours (ie 1 metre contours for a small area).
            The KML file containing contours is only 152 k but when using the plug in fetches elevation data and then imports about 1/3 of the contour lines but then it hangs on a dialog title "Progess" importing linestrings which is all in blue and no further data is imported.
            Is this a size / number of entities / memory limitation? Even though detailed it is not huge.
            Any help would be appreciated.
            Thanks regards
            David
              dawrightau
              TIG Thanks for your PM reply :
              I know of no size limit.
              Are you sure Sketchup has hung and not just slowed down?
              What does the Task Manager show ??
              Re your questions :
              Sketchup doesnt seem to have "Stopped responding" according to the task manager.
              The first third of the contours come in quickly. After trying a couple of times I left it sit for a couple of hours but no further activity other than a blue progress bar sitting at 100%.
              I did find a suggested size kml file limit of not much more than 200KB, otherwise Sketchup will go very slowly.
              I have attached the file in question.
              For other forum members interest, I also found another tool to import shapefiles into sketchup at the following URL :
               [http://www.strategis.nl/StrateGisSoftware/SGGISShapeImporterForSketchup.zip](http://www.strategis.nl/StrateGisSoftware/SGGISShapeImporterForSketchup.zip)
              This imports all the contours from a shapefile into sketchup in instant (which suggests to me the KML file shouldn't be too big for sketchup).
              However unlike KML Import, GIS Shape Importer does not georeference the contours or group individual contours with the elevation height as the group name. GIS Shape Importer as the name suggests also cannot export to shapefiles whereas KML Import can export as well. These features in KML Import are nice features which allows automation of height adjustment of the contours to create a tin file and export the elevated contours as well.
              Unfortunately because of the import problem I cant use KML import for this at the moment so am doing it all painfully / manually. However at least with GIS Shape importer I am able to progress in the meantime.
              If anyone can test my file and see if they are getting the same problem and suggest a solution that would be much appreciated.
              Regards
              David
              Woolshed Contours 1m.KML
                Aerilius
                I found the problem and fixed it. Thanks for attaching the file with which the problem occured.
                Importing big kml files can be slow because they are in xml format and there is no efficient way in SketchUp/Ruby to do it faster. I think shapefiles are in a binary format, so if there is a direct importer it could be faster.
                  dawrightau
                  Hi Aerilius,
                  Thanks for getting back to me.
                  Glad you were able to fix it but how do I get access to the fix?
                  I checked the plugin download site and the date of the download plugin file is
                     3/07/2011 7:05 PM
                  Be grateful to get this working.
                  Thanks again.
                  Cheers
                  David
                    Aerilius
                    the first post of this thread has version 1.4.9 (29.04.2012). If it is also distributed on another site, then I don't have access to update it there.
                      dawrightau
                      Thanks Aerilus,
                      The update worked perfectly and immediately (essentially no delay).
                      For some reason I thought the official site was http://extendsketchup.com/plugins/kml-tools/
                      The logical spot as you say was at the beginning of this forum.
                      Thanks again.
                      Kind regards
                      David Wright
                      • U Offline
                        ulisessol7
                        @aerilius said:
                        I had done more than a week testing and hadn't imagined that there still could be such issues.
                        Now I've uploaded a new version. I found a work-around to drop the IE8 requirement and fixed some more things. I hope it works this time.
                        just wanted to say thank you so much for making this tool available
                        cheers from Mexico
                          @ulisessol7 said:
                          just wanted to say thank you so much for making this tool available...
                            dawrightau
                            Hi Again Aerilus
                            The plugin is working fine for some kml files but for some reason inst working with others.
                            The ones that work have elevation data generated when they are created.
                            I tried importing a simple kml file with no elevation data and I get a white dialog box progress and no progress (please see hayrack boundary.kml)
                            I added 10 m vertices to the polygon and added elevation data to them and now get a dialog box with 50% progress where it stops (please see hayrack boundary with elevation.kml)
                            Any assistance would be appreciated.
                            Regards
                            David
                            @dawrightau said:
                            Thanks Aerilus,
                            Thanks again.
                            Kind regards
                            David Wright
                            Hayrack Boundary.KML
                            Hayrack Boundary with Elevation.KML
                              I got an KML file I'm trying to import, but I'm getting errors:
                              fetching elevation from url; http://api.geonames.org/astergdemJSON?formatted=true&lat=63.430509&lng=10.395091&username=aerilius&style=full&callback=returnJson
                              kmlImport.rb; geonames returned 6
                              Error; #<NoMethodError; undefined method `[]' for nil;NilClass>
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `points_to_plane'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;327;in `polygon'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;195;in `run2'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;655;in `eachp'
                              (eval);155;in `each_with_index'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `each_with_index'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `eachp'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;175;in `each'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;175;in `run2'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;151;in `fetch_alt'
                                Aerilius
                                This plugin is unfortunately very error-prone because it was my second plugin and it uses RegExps to parse xml (I hope I find a better way to handle xml, rexml didn't prove to perform better). I'll take a look at this whern I'm at home!
                                  You're using a webdialog for the import - you can use the XML parsing capabilities of the web-browser:
                                  http://www.w3schools.com/xml/xml_parser.asp
                                  If you use jQuery it's very simple:
                                  http://stackoverflow.com/questions/649614/xml-parsing-in-javascript
                                    Aerilius
                                    That sounds interesting. Javascript isn't the fastest either, but this strategy probably doesn't use the script language's string functions but the browser's compiled code.
                                    I once ported the plugin (partly) to ReXML and ran performace tests (more reliable but 107% slower, ReXML is pure Ruby and I wanted to avoid gems). So I'll try it with this again.
                                      ReXML is one of the slowest XML solutions - but as you mention it's pure Ruby. The others require some binaries. I want a Ruby parser because some times I don't have a WebDialog UI for plugins that has use of XML.
                                        Aerilius
                                        Hi David,
                                        I tried both files in a non-geolocated model and in a geolocated model (with terrain) and they both work for me (plugin version 1.4.6). I have no idea what could go wrong. When you open the Ruby Console before running th plugin, do there appear some error messages?
                                        with terrain
                                          Aerilius
                                          I'm not sure what causes this problem. It looks like one point of a polygon could not be parsed (nil) or a polygon has less than 3 points. Off the bat I would have tried:
                                          while a.length > 3 # replace line 754
                                          return if outerLoop.length < 3 # insert after line 311
                                            dawrightau
                                            Thanks for getting back to me Aerilius,
                                            I am using 1.4.9 being the version you updated to fix the part loading issue of mine in a previous post.
                                            There is an error in the ruby console. This is the ruby console messages for the harack boundary file :
                                            fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=-30.4077328499&lng=152.0265933208&username=aerilius&style=full&callback=returnJson
                                            kmlImport.rb: geonames returned 1098
                                            Error: #<NoMethodError: undefined method remove' for #<Sketchup::Materials:0xbfba0e4>> C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in color_to_su'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:738:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:738:in color_to_su'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:607:in style' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:170:in run2'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:655:in eachp' (eval):48:in each_with_index'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in each_with_index'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in eachp' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:170:in run2'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:151:in fetch_alt' C:/Program Files/Google/Google SketchUp 8/Plugins/enjshape/shapes.rb:48:in call'
                                            This is the ruby console message for the other file :
                                            fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=-30.40773285&lng=152.026593321&username=aerilius&style=full&callback=returnJson
                                            Error: #<NoMethodError: undefined method remove' for #<Sketchup::Materials:0xc11d030>> C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in color_to_su'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:655:in eachp' (eval):740:in each_with_index'
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:151:in fetch_alt' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in call'
                                            Hope this helps nut it out.
                                            Regards
                                            David
                                            @aerilius said:
                                            Hi David,
                                            • 4 / 7
