    [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
    137 Posts 49 Posters 140.9k Views 49 Watching
      Aerilius
      the first post of this thread has version 1.4.9 (29.04.2012). If it is also distributed on another site, then I don't have access to update it there.
        dawrightau
        Thanks Aerilus,
        The update worked perfectly and immediately (essentially no delay).
        For some reason I thought the official site was http://extendsketchup.com/plugins/kml-tools/
        The logical spot as you say was at the beginning of this forum.
        Thanks again.
        Kind regards
        David Wright
        • U Offline
          ulisessol7
          @aerilius said:
          I had done more than a week testing and hadn't imagined that there still could be such issues.
          Now I've uploaded a new version. I found a work-around to drop the IE8 requirement and fixed some more things. I hope it works this time.
          just wanted to say thank you so much for making this tool available
          cheers from Mexico
            @ulisessol7 said:
            just wanted to say thank you so much for making this tool available...
              dawrightau
              Hi Again Aerilus
              The plugin is working fine for some kml files but for some reason inst working with others.
              The ones that work have elevation data generated when they are created.
              I tried importing a simple kml file with no elevation data and I get a white dialog box progress and no progress (please see hayrack boundary.kml)
              I added 10 m vertices to the polygon and added elevation data to them and now get a dialog box with 50% progress where it stops (please see hayrack boundary with elevation.kml)
              Any assistance would be appreciated.
              Regards
              David
              @dawrightau said:
              Thanks Aerilus,
              Thanks again.
              Kind regards
              David Wright
              Hayrack Boundary.KML
              Hayrack Boundary with Elevation.KML
                I got an KML file I'm trying to import, but I'm getting errors:
                fetching elevation from url; http://api.geonames.org/astergdemJSON?formatted=true&lat=63.430509&lng=10.395091&username=aerilius&style=full&callback=returnJson
                kmlImport.rb; geonames returned 6
                Error; #<NoMethodError; undefined method `[]' for nil;NilClass>
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `points_to_plane'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `each'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;327;in `polygon'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;195;in `run2'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;655;in `eachp'
                (eval);155;in `each_with_index'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `each'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `each_with_index'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `eachp'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;175;in `each'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;175;in `run2'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;151;in `fetch_alt'
                  Aerilius
                  This plugin is unfortunately very error-prone because it was my second plugin and it uses RegExps to parse xml (I hope I find a better way to handle xml, rexml didn't prove to perform better). I'll take a look at this whern I'm at home!
                    You're using a webdialog for the import - you can use the XML parsing capabilities of the web-browser:
                    http://www.w3schools.com/xml/xml_parser.asp
                    If you use jQuery it's very simple:
                    http://stackoverflow.com/questions/649614/xml-parsing-in-javascript
                      Aerilius
                      That sounds interesting. Javascript isn't the fastest either, but this strategy probably doesn't use the script language's string functions but the browser's compiled code.
                      I once ported the plugin (partly) to ReXML and ran performace tests (more reliable but 107% slower, ReXML is pure Ruby and I wanted to avoid gems). So I'll try it with this again.
                        ReXML is one of the slowest XML solutions - but as you mention it's pure Ruby. The others require some binaries. I want a Ruby parser because some times I don't have a WebDialog UI for plugins that has use of XML.
                          Aerilius
                          Hi David,
                          I tried both files in a non-geolocated model and in a geolocated model (with terrain) and they both work for me (plugin version 1.4.6). I have no idea what could go wrong. When you open the Ruby Console before running th plugin, do there appear some error messages?
                          with terrain
                            Aerilius
                            I'm not sure what causes this problem. It looks like one point of a polygon could not be parsed (nil) or a polygon has less than 3 points. Off the bat I would have tried:
                            while a.length > 3 # replace line 754
                            return if outerLoop.length < 3 # insert after line 311
                              dawrightau
                              Thanks for getting back to me Aerilius,
                              I am using 1.4.9 being the version you updated to fix the part loading issue of mine in a previous post.
                              There is an error in the ruby console. This is the ruby console messages for the harack boundary file :
                              fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=-30.4077328499&lng=152.0265933208&username=aerilius&style=full&callback=returnJson
                              kmlImport.rb: geonames returned 1098
                              Error: #<NoMethodError: undefined method remove' for #<Sketchup::Materials:0xbfba0e4>> C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in color_to_su'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:738:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:738:in color_to_su'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:607:in style' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:170:in run2'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:655:in eachp' (eval):48:in each_with_index'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in each_with_index'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in eachp' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:170:in run2'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:151:in fetch_alt' C:/Program Files/Google/Google SketchUp 8/Plugins/enjshape/shapes.rb:48:in call'
                              This is the ruby console message for the other file :
                              fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=-30.40773285&lng=152.026593321&username=aerilius&style=full&callback=returnJson
                              Error: #<NoMethodError: undefined method remove' for #<Sketchup::Materials:0xc11d030>> C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in color_to_su'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:655:in eachp' (eval):740:in each_with_index'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:151:in fetch_alt' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in call'
                              Hope this helps nut it out.
                              Regards
                              David
                              @aerilius said:
                              Hi David,
                                dawrightau
                                Also a question
                                When one kml file (that imports ok) has been imported it is not possible to import another. A new instance of sketchup has to be opened to use the tool again.
                                Is this how it is or should I be able to import multiple kml files, one after another?
                                [quote="dawrightau"]Thanks for getting back to me Aerilius,
                                  Aerilius
                                  This should not happen, one should be able to import any amount of kml files ninto the same model.
                                  I think I found the issue and have almost fixed it (I will finish and release an update this evening).
                                    Aerilius
                                    I uploaded a new version!
                                      dawrightau
                                      Thanks very much Aerilius I will give it a try.
                                      Regards
                                      David
                                        dawrightau
                                        Hi Aerilius,
                                        Billiant thank you.
                                        Just to let you know that I could import both kml files into the one session, both geolocted correctly.
                                        Regards
                                        David
                                          dawrightau
                                          Your kml import works so well.
                                          Would you now consider creating a kmz import to import a geo located ongoing image.
                                          It would in part be a matter of extracting the doc.kml file from the kmz zip file read the coordinates in the same way as you do now and then import the png file to that location.
                                          Would be great functionality.
                                          Could send you an example file
                                          Cheers
                                          David
                                            banxee
                                            When I use the import, I get a 'Missing Textures- Unknown Texture' window. The model info comes in but no surfaces. The jpgs for the textures are in the Files folder of the KML but it can't seem to find it.
                                            Am I missing a step?
                                            • 4 / 7
