    DC Exploration 2 - Movement! (rotation, linear)
    Scheduled Pinned Locked Moved Dynamic Components
    19 Posts 9 Posters 11.6k Views 9 Watching
    • Chris FullmerC
      Way cool Jim. Is that a Sin Wave? I admit the math you used is over my head, but it sure looks cool.
        Jim
        @jim said:
        These (simple) legs were done by using sub-components and smart placement of the component's axes. By making the upper and lower parts sub-components of the leg, I didn't need to worry about their positions - rotating the parent leg rotates both the upper and lower parts together, no matter what their local position/rotation is.
        Then by placing the lower leg's axis at the top of the component (at the knee), I just had to set it's RotY attribute to make the lower part rotate.
        PS: Technically, this animation is only a half-stride.
        I've had someone ask why on this component you can't animate the legs directly using code such as:
        ANIMATE("Leg!RotY",45,-45)
        When you use this, the leg animates from 0 to -45 which is not as expected. I'm having trouble explaining it myself, so does someone know exactly what happens in this case?
        The modified file.
        The original file.
        • Q
          Qverburg
          Thanks for helping finding the answer to my question here Jim!
          I had this problem a couple of times allready. mainly with opening windows and sortalike.
          Im happy with the workaround of Jim but I guess it shouldnt be necessary.
          I have some troubles with another DC of mine too. Will post it soon so you pro's can give it a look 😎
          Regards
          Quintus
          • Q
            Qverburg
            Hmm this is strange,
            I found this door example of Remus and in there a mix of positive and negative rotations works just fine!
            Maybe its a nesting problem.
            Door fix
            • Chris FullmerC
              Scott commented on that once. I don't rememeber if he had an explanation, or if he just said that its buggy to animate the rotation/position/scale/ values directly, and that an intermediate value should be animated.
              I don't remember if that comment was made here or elsewhere though. I'd be hard pressed to find it.
              • E
                ericschimel
                I'd like to throw my hat in here with this drawing....
                This is what I used to create the logo for my website. I was going to use the animated gears for my videos, I just haven't implemented it yet....
                Just magic finger the gears and you will see...
                Dynamic Training Logo.skp
                -Eric
                http://plugin.sketchthis.net
                Sketchup Kitchen Design Plugin
                Custom Models
                  ahmedkaleem
                  You my friend, are my saviour... i`ve been trying to figure this out for the past three days without any success..
                  thank you! thank you so much!
                  • jason_marantoJ
                    jason_maranto
                    Here's a DC clock I made -- I'm sure this has been done to death but it was new to me.
                    DC rotation.skp
                    Best,
                    Jason.
                    • jason_marantoJ
                      jason_maranto
                      Here's an animation version of the Clock:DC clock animation.skp
                      Best,
                      Jason.
                      • yantskiY
                        yantski
                        I'm not sure if this thread is still catching some action, but...
                        I stumbled onto this technique while looking to solve another problem. I recognized the application immediately as a solve for another problem I was trying to figure out a few days earlier. Funny how that works sometimes!
                        How it works: When clicking on the drawer face (when it's in a cabinet) the whole drawer opens. The second click makes the top tray move back toward the cabinet revealing the bottom tray. Third click, top tray moves forward again. Fourth click, the drawer closes.
                        I'm not sure if the "On Click" code could be simplified and still work the same as I'm quite new to DC syntax.
                        Option_2Tier Cutlery Tray.skp
                          scottalanclymer
                          Wow, talk about being late to the party. You guys were messing with dynamic components way before I was even in diapers (SU diapers). 10 years since last post, huh?
                          In all the time you've had since then, has anyone figured out how to have an object move along an arc while maintaining a fixed attitude?
                          Another way to say the same thing would be that it needs to rotate around a fixed point, while not rotating. But I like the first way of saying it better. Any one know how to do this in dynamic components?
                          • SJS66S
                            SJS66
                            Howdy folks. I've made a kitchen sink mixer tap & put an onClick attribute on it that rotates the handles as if turning on the water. The right side handle turns on hot or cold. On is rotate on the Y axis 0 to 15 deg (to right), cold is rotate on X 0 to 30 deg (forward), hot is rotate on X 0 to -30 deg (back or away) say the spout is the front or facing forward.
                            The problem is, they move at the same time, rather then in sequence.
                            How would I get them to move in sequence when onClicked?
                            I tried using a "step" or "set" attribute but couldn't get it to work...above my DC pay grade I'm afraid πŸ˜‰
                            Any suggestions much appreciated.
                            Component Attributes
                            I have a video of the onClick rotations so far but it wouldn't let me attach as a second file!
                            I'll try to upload it as a separate post...is mp4 okay, or doesn't have to be another format?
                            • SJS66S
                              SJS66
                              Wouldn't let my upload my mp4 file showing my onClick rotations so here's a screenshot of the tap at least.
                              Be nice if you got a prompt or message that it was the wrong file type or something rather than just not working...does it have to be a gif or something? Doh!
                              Screenshot of the mixer tap.
