    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    How to apply material to all objects?
    7 Posts 4 Posters 315 Views 4 Watching
      arystoteles
      Hello I have big model with components and groups that have color material and textures. I would like to get rid off all the colors and textures and replace it with white. Is there a more automatic method than opening a group selecting faces and painting with bucket tool on white?
      thanks
        You could go to the In Model materials library and delete the materials and let SketchUp replace them with the default material. Set the default front face color to white.
        Or you could just switch to the Monochrome face style so the materials don't display.
        • massimoM Offline
          massimo Moderator
          ...or, for example, you could use this plugin to remove them all at once.
            arystoteles
            thank you! actually I wanted to quickly render with V-ray and I found out that there is a tick button in Vray Global Settings that enables to overwrite all materials with certain colour ๐Ÿ˜„
              arystoteles
              thanks. I tried it but it is really slow/ or at least with the scene I have it doesn't really work...
                Seems you have also the last plugin of Fredo 6!
                ThruPaint
                  arystoteles
                  ThruPaint
                  Oh I forgot about this one! Thank you Pilou!!!
