    [Plugin] SurfaceGen (0.9.0b) — 28 April 2012
    69 Posts 25 Posters 65.2k Views 25 Watching
    • H Offline
      Heven7_floor
      Thanks you very great plugin 👍 👍
        boilingsnow
        Very cool plugin!
        But a progress bar could be very helpful. Because I 've installed it and by performing the plugin it seems to take hours to generate a surface and I don't know if it is really working!
        I've waited for more than 25 minutes for a simple eqation so I have to give up finally...
        In other words, I can't get it work in my sketchup 8.
        • I Offline
          imabzeous
          a very nice plugin, ( as i have seen only in pics and shapes that you have created) but i don't understand where can i get equations for it? i want to make some fractal geometry but when i applied the equation it wont work. so can any body help me with this equation thing more..
          and thank you
            boilingsnow
            @boilingsnow said:
            Very cool plugin!
            I figured out that SurfaceGen has a conflict with another plugin calls 'Modelfuction'.
            If you get Modelfuction installed in your sketchup, you can see the pop-up window by applying Surfacegen, but it will not create any surface.
            I have uninstalled Modelfunction now and SurfaceGen works well!
            By the way this is really a awesome plugin. So it would be perfect if the author can get rid of the conflict with other plugins...
              I far as I can see SurfaceGen does not use any unusual methods or interfere with base/built-in classes/methods. However, Modelfunction may well do that - there are a few scripts will ill-advisedly mess with these and thereby they affect other tools unpredictably [often messing with 'group', 'face' etc].
              As Modelfunction is a paid tool [and you must be a customer] I suggest you contact the author direct to get him to fix his code...
                Diggsey
                I haven't posted in ages, but I just noticed that there was a way I could improve the speed of this plugin. The new version only calls "eval" once to create a proc object which it then calls repeatedly, so it shouldn't have to keep parsing the expression each time.
                  I added version number and time of update to the thread title so it's easier to see the change when scanning the thread titles - also the Plugin Index works better then.
                    ramdelgp
                    ah very cool! 😎
                    Topmod and K3dSurf in a same place! 👍
                    (you can take some formula from K3DSurf 😉
                    For now, I'm just playing, but I have dreams of making some beautiful math sculptures like Bathsheba Grossmanmakes.
                    Topmod above is perfect for that 😉
                    by me 😄
                    http://forums.polyloop.net/imagehosting/1964703b3c059111.jpg
                    By Jotero
                    http://www.jotero.com/bilder/topmod/soccer_ball_jotero2007.jpg
                    Wooow did you made does models? simply amazin.
                    can you share some tutotials?
                    • brookefoxB Offline
                      brookefox
                      Wonderful tool, Diggsey. Many thanks. Nice that folks are sharing their settings. I wish someone with the appropriate skills or not would chart up some many examples, something like the pic below, and/or list many equations to experiment with. I do not have those skills. I had modeled something like the intersecting sine waves not long ago manually... tch, tch.
                      ~ Brooke
                        All models are made with TopMod
                        I have made the first 😉
                        I have made a little tut video ☀
                        (sorry in French but very visual)
                        Else you will find some very cool tutorials videos here 😉
                        (explore the site)
                        It's a very crazzy program! 😎
                        By me (French UI too by me 😉 Don't make renders inside Topmod (export as OBJ Render here in ZBrush)
                        http://www.polyloop.net/imagehosting/19646f79a19764f7.jpg
                          brookefox
                          Model collection (as shown in previous post) for for you to add your model/s to.
                          surfacegen plugin models.skp
                          ~ Brooke
                            Schaefer
                            hello! i need that for mathematical- educational purposes for sketchup make 2017 - or a similiar plugin, updatet to 2018. Does anybody have some information, where to get it. i couldn't find thomtoms surfacegen in the sketchucation-library. thanks, r. schaefer
                              It's in the PluginStore, made into an RBZ format download.
                              https://sketchucation.com/pluginstore?pln=surfacegen
                              It's not Thomthom's, it's Diggsey's plugin...
                              It'll probably still work in v2018 - however, because it's old and unsigned, you'll need to set the SketchUp Extension Manager's Loading Policy to "Unrestricted"...
                              • 4 / 4
