    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 272.8k Views 66 Watching
      gohch
      hi everyone,
      1001bit Pro Czech language pack is now available!
      http://www.1001bit.com/discussions/viewtopic.php?f=17&t=1131
      Special thanks to Marek Raab for his hardwork and sharing!
      (And he even translated the images!)
      • esteromxE Offline
        esteromx
        1001bit Pro version 2 is out. http://www.1001bit.com/pro/pro2_improvements.html
          πŸ‘ πŸ‘ Nice!
          • KrisidiousK Offline
            Krisidious
            bought... and installing pronto.
            awesome awesome awesome...
            Edges to 3D profiles
            Extrude to target plane
            Extrude along sloping curved path
            Best fit face
            what an incredible tool kit this has become... well it always has been. how can you top yourself, when you keep setting expectations so high.
            instant tube frame or roll cage... just a few clicks and bang. and it lines up great. do you realize how much time I spent building the roll cage for my Nascar?
            By: Kristoff Rand
              One 'tip' for v1 pro users who are upgrading to v2 pro...
              If you install v2 files overwriting the v1 files, then Sketchup might no longer auto-load 1001tools at all, as there will be some initial error messages [re. incorrect key etc].
              You cannot therefore enter your new key-code into a dialog as your upgrade email has instructed. Bummer !
              However, if you look in the 1001tool's subfolder there's a file called 1001bit_pro.key... open that using Notepad or similar plain-text editor like Notepad++... edit>copy your new key string from you confirmation email [all 458 characters of it!] and then in the .key file edit use edit>select-all and then edit>paste to overwrite the old key string. Save the .key file and restart Sketchup, now 1001tools v2 pro should auto-load successfully with all of the new/improved features... Fixed !!
                TIG: Did you report this upgrade problem?
                  Just about to...
                  EDIT: It's now reported to 1001 direct.
                    French version of the news πŸ˜‰
                    • esteromxE Offline
                      esteromx
                      I have this problem, but i canΒ΄t find: 1001bit_pro.key
                        Krisidious
                        I just can't rave about this enough. what a great tool kit and a great price. soooo many great tools. for construction this is a must have.
                        By: Kristoff Rand
                          • esteromxE Offline
                            esteromx
                            Thanks TIG, does not appear as you show it, in my case (Windows 7 64bit) I have to look at COMPATIBILITY FILES to display the file. Key
                              Arrrgh ! No, No, No...
                              You do not have the proper access-rights to install Plugins.
                              As an Administrator... Highlight the Plugins folder icon.
                              Right-click context-menu Properties > Security/
                              Change/Edit the settings so to ensure that YOU/others-like-you have 'FULL permissions'.
                              Windows Vista/Win7 tries to protect you from yourself... if you have limited rights and you try to install files/subfolders within 'Program Files', it [stupidly] doesn't tell you, BUT installs them into a 'Compatibility Fies' subfolder instead ???
                              You should only put the files/subfolders into the locations specified in the tool's instructions [typically 'Plugins']... πŸ˜•
                              To do otherwise is a recipe for problems ❗
                              YOU should have full access rights to the folders for Plugins, Materials, Components and Styles - otherwise you will get unpredictable results when trying to install any of these types of file...
                              πŸ˜’
                                griffeur
                                I have a problem with the selection of doors/windows presets tool: http://img36.imageshack.us/img36/1949/bugtp.jpg (it's just an example, sometimes no windows appears). I used to have problems with the simple stairs in the previous version too, but it works in this one!
                                  Soarecu
                                  Hello, first off allow me to say what a great plugin this is. As a student in architecture it has really helped me cut down on the time it takes to build my models. I have only one question. The version of the plugin that i just downloaded with an academic license is v1.1.7, however it seems from the forums that version 2 is out. May i ask if that is a version available only for purchased licenses, or will the academic licenses be able to upgrade as well?
                                    Why not ask the question on the 1001 forums?
                                    • opalO Offline
                                      opal
                                      just me or is the link on the first page misdirecting to another place?
                                        Jim
                                        The link has been fixed.
                                        • opalO Offline
                                          opal
                                          Ty.. downloaded latest version of sketchup.. rebuilding plugins folder πŸ˜„
                                          • Mistro11M Offline
                                            Mistro11
                                            I tried to register at 1001bit forums and got this message in red saying my IP address was blacklisted as a spammer (I have definitely NOT spammed anyone). Anyone else had this problem? Also I would like to know if this would be a problem for me when it comes to activating the product? I want buy it now. I understand the company is in the far east so I don't expect a response from them just yet. Can I just buy 1001bit without registering to the forums or would my email given during activation be treated in a separate way?
                                            BTW, this set looks really good! I'm shocked I have not heard of this plugin until I stumbled on it while shopping for plugins yesterday. I'm so late to this community.
                                            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                            Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
