    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 283.8k Views 66 Watching
    • G
      gohch
      Hi Ken,
      Thanks and please do not apologize for anything.
      I am really grateful that you raised a very important bug, as well as reminding me the importance of clarity and ease of use.
      If not for your comments, there will be a lot more people having problem with the bug right now.
      and, for every feedback on issues, there are always a lot more people who are frustrated with similar issues.
      Thanks again, and thanks for sending me your old key for debugging.
      I'll try to debug this so that we can get rid of the command window that seems to slow down the loading.
      Cheers! πŸ˜„ πŸ˜„
      Goh C H
      • G
        gohch
        hi everyone,
        I've just uploaded the debugged 1001bit Pro (version 1.2) for download.
        http://www.1001bit.com/pro/download/1001bit_pro(v1.2).zip
        The update contains the following:
        1. panel divide tool (re-written, should work better)
        2. startup loading; loads faster and should not show the black command dialog,
          and also got rid of the request code.
        Please try out πŸ˜„
        cheers!
        Goh
          hi everyone,
          Please try out πŸ˜„
          cheers!
          Goh
          Cheers! I'll give it a whirl. I've come to the habit of having 1001bit disabled by default and only load on demand due to the load performance and flashing command windows. Now I might keep it enabled. πŸ˜„
          • utilerU
            utiler
            Thanks Goh, great stuff!!
            Just Curious...
            • G
              gohch
              hi everyone,
              1001bit Pro Czech language pack is now available!
              http://www.1001bit.com/discussions/viewtopic.php?f=17&t=1131
              Special thanks to Marek Raab for his hardwork and sharing!
              (And he even translated the images!)
              • esteromxE
                esteromx
                1001bit Pro version 2 is out. http://www.1001bit.com/pro/pro2_improvements.html
                  πŸ‘ πŸ‘ Nice!
                  • KrisidiousK
                    Krisidious
                    bought... and installing pronto.
                    awesome awesome awesome...
                    Edges to 3D profiles
                    Extrude to target plane
                    Extrude along sloping curved path
                    Best fit face
                    what an incredible tool kit this has become... well it always has been. how can you top yourself, when you keep setting expectations so high.
                    instant tube frame or roll cage... just a few clicks and bang. and it lines up great. do you realize how much time I spent building the roll cage for my Nascar?
                    By: Kristoff Rand
                      One 'tip' for v1 pro users who are upgrading to v2 pro...
                      If you install v2 files overwriting the v1 files, then Sketchup might no longer auto-load 1001tools at all, as there will be some initial error messages [re. incorrect key etc].
                      You cannot therefore enter your new key-code into a dialog as your upgrade email has instructed. Bummer !
                      However, if you look in the 1001tool's subfolder there's a file called 1001bit_pro.key... open that using Notepad or similar plain-text editor like Notepad++... edit>copy your new key string from you confirmation email [all 458 characters of it!] and then in the .key file edit use edit>select-all and then edit>paste to overwrite the old key string. Save the .key file and restart Sketchup, now 1001tools v2 pro should auto-load successfully with all of the new/improved features... Fixed !!
                        TIG: Did you report this upgrade problem?
                          Just about to...
                          EDIT: It's now reported to 1001 direct.
                            French version of the news πŸ˜‰
                            • esteromxE
                              esteromx
                              I have this problem, but i canΒ΄t find: 1001bit_pro.key
                              • KrisidiousK
                                Krisidious
                                I just can't rave about this enough. what a great tool kit and a great price. soooo many great tools. for construction this is a must have.
                                By: Kristoff Rand
                                  • esteromxE
                                    esteromx
                                    Thanks TIG, does not appear as you show it, in my case (Windows 7 64bit) I have to look at COMPATIBILITY FILES to display the file. Key
                                      Arrrgh ! No, No, No...
                                      You do not have the proper access-rights to install Plugins.
                                      As an Administrator... Highlight the Plugins folder icon.
                                      Right-click context-menu Properties > Security/
                                      Change/Edit the settings so to ensure that YOU/others-like-you have 'FULL permissions'.
                                      Windows Vista/Win7 tries to protect you from yourself... if you have limited rights and you try to install files/subfolders within 'Program Files', it [stupidly] doesn't tell you, BUT installs them into a 'Compatibility Fies' subfolder instead ???
                                      You should only put the files/subfolders into the locations specified in the tool's instructions [typically 'Plugins']... πŸ˜•
                                      To do otherwise is a recipe for problems ❗
                                      YOU should have full access rights to the folders for Plugins, Materials, Components and Styles - otherwise you will get unpredictable results when trying to install any of these types of file...
                                      πŸ˜’
                                      • G
                                        griffeur
                                        I have a problem with the selection of doors/windows presets tool: http://img36.imageshack.us/img36/1949/bugtp.jpg (it's just an example, sometimes no windows appears). I used to have problems with the simple stairs in the previous version too, but it works in this one!
                                          Soarecu
                                          Hello, first off allow me to say what a great plugin this is. As a student in architecture it has really helped me cut down on the time it takes to build my models. I have only one question. The version of the plugin that i just downloaded with an academic license is v1.1.7, however it seems from the forums that version 2 is out. May i ask if that is a version available only for purchased licenses, or will the academic licenses be able to upgrade as well?
                                            Why not ask the question on the 1001 forums?
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
