    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 24.2k Views 25 Watching
      sepo
      just to mention also TR1 is unbiased as well.
      @srx said:
      I was curious...and this is Thea render TR1 in 30 minutes.
      • jason_marantoJ Offline
        jason_maranto
        A couple more quickies... the first is render with the production engine to SL 19:
        And since I was getting bored with the blown out windows look I switched to the free sample HDR from http://www.hdri-locations.com/ -- if you want to try to match this I offset the HDR X axis by 43 degrees and dropped the intensity of the background channel to .25 (so it wouldn't blow-out)
        The first one was rendered with the production engine to 30 minutes:
        The second one is the same scene rendered in the full Maxwell Render Suite to 30 minutes -- this shows the full render suite is not only faster than the stand-alone plugin but also shows what can be done with MXED to make a better looking material for the wood floor(which was the only semi-complex material in the scene).
        As I said before measuring these comparisons by time does not make much sense since we are all working off of different specs -- but here at least you can see that the full Maxwell Render Suite has a speed advantage (among all it's other advantages) over the stand-alone plugin (which I would also expect to be true with any other engine that is not rendering within SketchUp).
        Best,
        Jason.
        • Z Offline
          zack mierza
          Im a newbie here.I was also a twilight user.It's been a year using and exploring it but there's still alot to improve and learn.Hope u guys can help me with twilight render in the future.Thanks and here a some of my work using twilight render. 😄
          sketchup+twilight render+photoshop
            lwbscenic
            @jason_maranto said:
            Yeah at $800 for VRay you could get the full Maxwell Render Suite for less at $700 which offers much more room to grow beyond just working inside SketchUp.
            The others I don't know very well, so hopefully somebody else can comment.
            Best,
            Jason.
            Ive seen this mention of the Maxwell render suite for $700 a few times. Is this still the case somewhere? It appears that it is currently going for $995.
              jason_maranto
              That promotional sale expired a little while ago -- Next Limit does sales like that every so often (maybe 1-2 times a year)... so keep your eyes open and you'll get a deal.
              Best,
              Jason.
                lwbscenic
                Jason
                If I purchased the paid plugin would there be a upgrade to the suite, or is it still a full purchase?
                  jason_maranto
                  I'm not sure on that -- you would probably need to contact Next Limit directly to find out... although I cannot imagine them not offering some upgrade path.
                  Best,
                  Jason.
                    lwbscenic
                    So Next Limit Replied to let me know that they would only charge me the difference between the cost of the plug-in and the cost of the suite should I decide to upgrade.
                    Nice
                    LB
                      jason_maranto
                      That's good to hear, though I'm not surprised -- they are generally one of the best companies when it comes to their (IMO) liberal licensing policies (cross-platform, cross-product).
                      Best,
                      Jason.
                      • soloS Offline
                        Tested this scene with Thea.
                        Firstly we must not forget that everyone's computers are different, even if you have identical rigs the difference could be in seconds or minutes.
                        I tested on a first generation i7 with 24GB ram
                        First we have biased tests (like Vray)
                        First is the default Thea BSD setting, it is by default set to use maximum cores and normal super-sampling, This was pretty fast at 58 seconds but quality is questionable IMO:
                        Then I upped the super-sampling to high and it took 2m21 secs:
                        Here I used one of my own presets, used for actual work when I need to get lots of renders out fast and client does not need unbiased level quality, yet still getting a decent result, 3m34 sec:
                        And lastly the unbiased version, for when you want a good result, note, I never needed to change a thing in order to render biased or unbiased just a matter of choosing before hitting render.
                        • E Offline
                          Ecuadorian
                          Pete, there are two basic types of biased settings in Thea...
                          -Bucket rendering, which finishes one square at a time and has a well defined "completion" point (Works similar to Vray and Mental Ray)
                          Examples in Thea:
                          Adaptive BSD
                          Photon Mapping
                          Final Gather
                          -Progressive rendering, which you can stop anytime when satisfied (Works similar to unbiased modes, but is "biased" instead of "unbiased"... Can't tell the difference by just looking at the result.)
                          Examples in Thea:
                          Progressive BSD, which for me looks like a biased version of TR1
                          Adaptive (AMC), which seems to be a biased version of TR2
                          All these five biased modes are present in Thea. Which ones did you use for the test?
                          -Miguel Lescano
                          • soloS Offline
                            BSD.
                            • E Offline
                              Ecuadorian
                              There's two BSD modes:
                              Progressive BSD (progressive) and Adaptive BSD (bucket rendering).
                              I guess it must be Progressive BSD, right?
                              -Miguel Lescano
                              • soloS Offline
                                Ah, sorry, I used adaptive for these tests
                                • N Offline
                                  nomeradona
                                  im sold out with BSD now Pete.. nice tests... i came for thea for the unbiased and handling of multi-poly models, but seeing your Biased render, it made me rethink twice and thrice.. thanks for putting this gallery.
                                  • PixeroP Offline
                                    Pixero
                                    @Pete: I would be interested in seeing your tweaked settings.
                                      jpalm32
                                      I don't understand the window reflection on her shirt.
                                        She's a semi opaque 2d face me. You're a seeing through her.
                                        • FletchF Offline
                                          Fletch
                                          For future reference on the Twilight Render website there is a "Tutorials" link.
                                          There you will find the video tutorials for Twilight Render SketchUp plugin. They are made in such a way that people that do not understand spoken English so well can still learn how to use the plugin. (Videos are also available in Spanish and Japanese)
                                          The next place to go for beginners would naturally be the FAQ section of the user forum. In this case, it is not a list of some odd made-up words that no one actually ever asks about. No, it's actually a list of the most frequently asked 'beginner' questions.
                                          Warming up the sky: There are many controls for physical sky, and color of sun, sun radius (how soft the sun shadows are) in the Light Editor dialog for Twilight. Check these tips for beginners wanting to warm up the sun and sky, and speed up renderings and general working in SketchUp:
                                          Default Sky Setting for Twilight... and speed up SU (includes an excellent default sun and sky .skp template file)
                                          First thing to do to warm up the Sun and Sky
                                          In addition of course you can use any spherical sky image in .hdr or .jpg format.
                                          If somehow the User Manual (comprehensive, fully hyper-linked, well organized, and searchable) does not have an answer to your question, you can check out the Best Of Tips and Tricks - The Master List
                                          Lastly the Twilight Render community forum is very friendly, helpful, and welcoming to all. It is very similar to the lovely folks here at the SketchUcation forum. ☀
                                          Finally, users of the free trial still get free support from our user forum. People who purchase a Twilight Render license get access to the Red Carpet Section of the user forum, a lot of free advanced video tutorials, user content, scenes, etc.
                                          Fletch
                                          • 6 / 7
