    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 31.9k Views 25 Watching
    • massimoM Offline
      massimo Moderator
      You're welcome. 😄
      • jason_marantoJ Offline
        jason_maranto
        Here's my test with the Maxwell "production" engine left to render to SL 21 -- which took 2h 47m on my Intel i7 920 system (4 core hyper-threaded 2.66GHz).
        It could be rendered a bit longer to reduce the slight noise still present in parts but I personally wouldn't find this result objectionable... obviously you can adjust the exposure setting to whatever you need when setting up the scene.
        The lighting is dead neutral here so any color you are seeing is due to the materials themselves... and I know that Maxwell renders absolutely pure nuetral.
        I was also not happy with how the silhouette material you have was performing in this render (I've never used that effect before for rendering) -- so afterward I made a SketchUp material (Maxwellized of course) that you can use whenever you want that effect for better results.
        the SketchUp material.
        Best,
        Jason.
        • andybotA Offline
          andybot
          Thanks Jason for your efforts. I wasn't sure how to do the transparent material, anything transparent automatically gets a reflection - fine if everything transparent is glass... but I didn't know how to get rid of that so I changed it to plastic material with rough finish...
          It's interesting to see this compared to the 5-10 minute vray output... just sayin' - if time is money, well, vray pays for itself pretty quickly!
          Though I do have to say the RT view with Maxwell is pretty good and does save time.
            jason_maranto
            You are certainly correct on that count -- Maxwell has nothing on Vray when it comes to pure speed and there are no optimized engine presets (like Twilight) that drop complexity for speed (it renders everything all the time).
            However the quality of light is better for sure -- everything fits together into the scene very well which is not true in the Vray render which tends to look a bit disjointed with parts looking "pasted-in". Also the Anti-aliasing of edges is superior to both Vray and the Maxwell "draft" engine.
            I know that with some more time and energy spent on settings Vray could achieve similar results to the Maxwell render, but that is my point -- I would rather let the computer work than spend that time learning and tweaking all those arcane settings in Vray to attempt to get close to the same results that are simple in Maxwell.
            I know I have a very odd way of relating to time compared to most render engine users -- but my sense is it is better to produce quality, because sooner or later the hardware advancements (multi-processor CPUs with multi-CPU motherboards) will allow Maxwell to render fast enough to where quality is the only deciding factor. Already if I had a dual CPU motherboard with 2 low-end 6-core i7s I would have cut the render time to less than 1/3 (I would guess 30-45 min) for the same results... those speed improvements will only become more drastic as time goes by.
            Best,
            Jason.
            • andybotA Offline
              andybot
              That's where conversations like this are useful ☀ It gives everyone more information to help in making their own decisions. Everyone will value these multiple things differently: quality, speed, ease of use, price, etc.
                jason_maranto
                Absolutely -- I really enjoy reading threads like this too.
                BTW it's worth mentioning (once again) that this was done with the $95 version of the plugin -- If I was to use the full Maxwell Render Suite not only could I do it faster but I could also do it better (due to the material making limitations of the stand-alone plugin)... Not to mention at that point I could also make use of a network and render nodes.
                Best,
                Jason.
                • srxS Offline
                  srx
                  I was curious...and this is Thea render TR1 in 30 minutes.
                  www.saurus.rs
                    sepo
                    just to mention also TR1 is unbiased as well.
                      jason_maranto
                      A couple more quickies... the first is render with the production engine to SL 19:
                      And since I was getting bored with the blown out windows look I switched to the free sample HDR from http://www.hdri-locations.com/ -- if you want to try to match this I offset the HDR X axis by 43 degrees and dropped the intensity of the background channel to .25 (so it wouldn't blow-out)
                      The first one was rendered with the production engine to 30 minutes:
                      The second one is the same scene rendered in the full Maxwell Render Suite to 30 minutes -- this shows the full render suite is not only faster than the stand-alone plugin but also shows what can be done with MXED to make a better looking material for the wood floor(which was the only semi-complex material in the scene).
                      As I said before measuring these comparisons by time does not make much sense since we are all working off of different specs -- but here at least you can see that the full Maxwell Render Suite has a speed advantage (among all it's other advantages) over the stand-alone plugin (which I would also expect to be true with any other engine that is not rendering within SketchUp).
                      Best,
                      Jason.
                      • Z Offline
                        zack mierza
                        Im a newbie here.I was also a twilight user.It's been a year using and exploring it but there's still alot to improve and learn.Hope u guys can help me with twilight render in the future.Thanks and here a some of my work using twilight render. 😄
                        sketchup+twilight render+photoshop
                          lwbscenic
                          @jason_maranto said:
                          Yeah at $800 for VRay you could get the full Maxwell Render Suite for less at $700 which offers much more room to grow beyond just working inside SketchUp.
                          The others I don't know very well, so hopefully somebody else can comment.
                          Best,
                          Jason.
                          Ive seen this mention of the Maxwell render suite for $700 a few times. Is this still the case somewhere? It appears that it is currently going for $995.
                            jason_maranto
                            That promotional sale expired a little while ago -- Next Limit does sales like that every so often (maybe 1-2 times a year)... so keep your eyes open and you'll get a deal.
                            Best,
                            Jason.
                              lwbscenic
                              Jason
                              If I purchased the paid plugin would there be a upgrade to the suite, or is it still a full purchase?
                                jason_maranto
                                I'm not sure on that -- you would probably need to contact Next Limit directly to find out... although I cannot imagine them not offering some upgrade path.
                                Best,
                                Jason.
                                  lwbscenic
                                  So Next Limit Replied to let me know that they would only charge me the difference between the cost of the plug-in and the cost of the suite should I decide to upgrade.
                                  Nice
                                  LB
                                    jason_maranto
                                    That's good to hear, though I'm not surprised -- they are generally one of the best companies when it comes to their (IMO) liberal licensing policies (cross-platform, cross-product).
                                    Best,
                                    Jason.
                                    • soloS Offline
                                      Tested this scene with Thea.
                                      Firstly we must not forget that everyone's computers are different, even if you have identical rigs the difference could be in seconds or minutes.
                                      I tested on a first generation i7 with 24GB ram
                                      First we have biased tests (like Vray)
                                      First is the default Thea BSD setting, it is by default set to use maximum cores and normal super-sampling, This was pretty fast at 58 seconds but quality is questionable IMO:
                                      Then I upped the super-sampling to high and it took 2m21 secs:
                                      Here I used one of my own presets, used for actual work when I need to get lots of renders out fast and client does not need unbiased level quality, yet still getting a decent result, 3m34 sec:
                                      And lastly the unbiased version, for when you want a good result, note, I never needed to change a thing in order to render biased or unbiased just a matter of choosing before hitting render.
                                      • E Offline
                                        Ecuadorian
                                        Pete, there are two basic types of biased settings in Thea...
                                        -Bucket rendering, which finishes one square at a time and has a well defined "completion" point (Works similar to Vray and Mental Ray)
                                        Examples in Thea:
                                        Adaptive BSD
                                        Photon Mapping
                                        Final Gather
                                        -Progressive rendering, which you can stop anytime when satisfied (Works similar to unbiased modes, but is "biased" instead of "unbiased"... Can't tell the difference by just looking at the result.)
                                        Examples in Thea:
                                        Progressive BSD, which for me looks like a biased version of TR1
                                        Adaptive (AMC), which seems to be a biased version of TR2
                                        All these five biased modes are present in Thea. Which ones did you use for the test?
                                        -Miguel Lescano
                                        • soloS Offline
                                          BSD.
                                          • E Offline
                                            Ecuadorian
                                            There's two BSD modes:
                                            Progressive BSD (progressive) and Adaptive BSD (bucket rendering).
                                            I guess it must be Progressive BSD, right?
                                            -Miguel Lescano
                                            • 6 / 7
