    Plugin interfering with DWG import (solved)
    24 Posts 5 Posters 4.8k Views 5 Watching
      Edson
      This has every version FOO'd...
      pathcopy.rb
      • scottliningerS Offline
        scottlininger
        Hey Edson,
        Does it fail with all DWGs, or just one in particular?
        I installed Rick's script on SU8 Pro on my mac. Same OS version as you, and the DWG import worked for me. Could you share the file?
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
        • EdsonE Offline
          Edson
          @tig said:
          Edson
          bad news. it does not work either. sketchup crashes every time.
          http://www.mahfuz.arq.br
          • EdsonE Offline
            Edson
            Hey Edson,
            scott,
            yes, I have basically been using one file for my tests but it fails with all dwgs. I can surely share the file.
            03a_ANEXO-III-LEVANTAMENTO-TOPOGRÁFICO1.dwg
              scottlininger
              Hrm. Edson, I grabbed that file and I'm not seeing a crash. I'm on SU 8.0.11751.
              Even in there is something corrupted about your specific SketchUp install, it's very strange that a plugin would change the behavior. I guess we'll wait and see if Rick can recreate... either way it'll be another clue.
              • Scott Lininger
                @edson said:
                @tig said:
                Edson
                Strange all we have done is separate the Vector class/method into one that's unlikely to have a name clash... 😕
                So to recap...
                If you have those two .rb files loading then DWG fails.
                If you remove the files DWG works OK ?
                That's plain weird...
                Can you double check both edited files are in the Plugins folder...
                You don't have Fredo's tool loading to add an extra networked Plugins folder ???
                It might be loading an unedited version from somewhere ??????
                • EdsonE Offline
                  Edson
                  scott,
                  my SU version is 8.0.13608.
                  TIG,
                  it is enough to remove vector.flat_angle.rb for SU to import the dwg without problems. I only removed the other to get rid of error messages asking for the other.
                  you have only posted the edited pathcopy.rb file, not vector.flat_angle.rb.
                  what fredo tool do you mean precisely?
                    Fredo's AdditonalPluginsFolder [or similar name...]
                    I'd disable both of RickW's files, as one needs the other etc...
                    • EdsonE Offline
                      Edson
                      no, I do not have that plugin by fredo6 installed.
                      I have disabled both plugins. I am almost sure there are other plugins that help copy objects along a path.
                      • bigstickB Offline
                        bigstick
                        Actually every one of my Macs in the office (3 in total) has the same problem of being unable to import dwg files in SU Pro. This has been the case for every version of SU8 pro that I have used, and in the office it makes no difference whether we are on Lion or Snow Leopard.
                        The import seems to work fine, the geometry seems to be imported, and the summary dialog pops up with the imported entities, but then SU crashes.
                        Works fine on my MacBook Pro at home with the same version of SU Pro 8.0.11751 though. This probably has more plugins than any of the other machines.
                        Pathcopy is not the culprit for me because it's on my home machine which works, and on my office machine, which doesn't.
                        Works fine on the PC under all situations.
                        • EdsonE Offline
                          Edson
                          my only guess is that in my case vector.flat_angle.rb conflicts with some other plugin. finding it is something much beyond my knowledge.
                            RickW
                            Does SU crash if vector.flat_angle.rb is the only .rb in the Plugins folder?
                            RickW
                            www.smustard.com
                            • EdsonE Offline
                              Edson
                              no. it looks as if it conflicts with some other plugin.
                                RickW
                                It seems to me that the only way a plugin could crash SU when using the native dwg import is by using observers. Can anyone think of any other way?
                                RickW
                                www.smustard.com
