    Plugin interfering with DWG import (solved)
    24 Posts 5 Posters 4.8k Views 5 Watching
      Take the half and add 50% of the other half.
      Retry, if it's OK the problem lies with something in the 25%.
      If it fails the issue is with something in the 75%.
      Move out ~half of the files you just added back.
      Retry etc, repeat until you find the one file that's causing the issue.
      Rub with just that file to check if it reacts badly when alone.
      Now leave that in the folder and start moving back ~half of the previous files until the error happens then you know the other file is in the last lot moved in.
      Move these out by halves until you zoom in on the other file.
      Test with both files together to see that they interact badly.
      Tell us what they are... 😕
      Obviously removing one or both of them at least temporarily will let you do the DWG work needed...
      • EdsonE Offline
        Edson
        NAILED IT! the file that was preventing me from importing dwgs is vector.flat_angle.rb which is required by pathcopy.rb (rick wilson). I ran several tests to make sure it was the one to blame. in order not to get error messages at startup I removed pathcopy.rb as well.
        perhaps it is worth saying that this is happening on mac os 10.6.8. I do not know how the plugin behaves on windows.
        http://www.mahfuz.arq.br
          I don't have any issues with it [PC], though I rarely use it.
          It does add a method to the Vector class Vector.flat_angle to give the vector's angle as if it were 'flat' on the group.
          There must be something using its own new method of the same name but with different returned results ?
          You could try opening the files and changing flat_angle to flat_angleFOO with find/replace[all] - also rename the .rb file with +FOO to match.
          Then when pathcopy.rb requires/calls the code it won't have the same name, and should therefore not clash...
          [do it on copies in case you mess up]
          • EdsonE Offline
            Edson
            @tig said:
            I don't have any issues with it, though I rarely use it.
            it is not working. could you have a look at the two modified files? thanks.
            pathcopy.rb
            vector.flat_angleFOO.rb
              RickW
              I've not had problems with .dwg import on my PC, but I will investigate this on Mac.
              RickW
              www.smustard.com
              • EdsonE Offline
                Edson
                rick,
                thanks for chiming in. I hope you can find out what is happening. pathcopy is very useful.
                  Edson
                  This has every version FOO'd...
                  pathcopy.rb
                  • scottliningerS Offline
                    scottlininger
                    Hey Edson,
                    Does it fail with all DWGs, or just one in particular?
                    I installed Rick's script on SU8 Pro on my mac. Same OS version as you, and the DWG import worked for me. Could you share the file?
                    • Scott Lininger
                      SketchUp Software Engineer
                      Have you visited the Ruby API Docs?
                    • EdsonE Offline
                      Edson
                      @tig said:
                      Edson
                      bad news. it does not work either. sketchup crashes every time.
                      • EdsonE Offline
                        Edson
                        Hey Edson,
                        scott,
                        yes, I have basically been using one file for my tests but it fails with all dwgs. I can surely share the file.
                        03a_ANEXO-III-LEVANTAMENTO-TOPOGRÁFICO1.dwg
                          scottlininger
                          Hrm. Edson, I grabbed that file and I'm not seeing a crash. I'm on SU 8.0.11751.
                          Even in there is something corrupted about your specific SketchUp install, it's very strange that a plugin would change the behavior. I guess we'll wait and see if Rick can recreate... either way it'll be another clue.
                          • Scott Lininger
                            @edson said:
                            @tig said:
                            Edson
                            Strange all we have done is separate the Vector class/method into one that's unlikely to have a name clash... 😕
                            So to recap...
                            If you have those two .rb files loading then DWG fails.
                            If you remove the files DWG works OK ?
                            That's plain weird...
                            Can you double check both edited files are in the Plugins folder...
                            You don't have Fredo's tool loading to add an extra networked Plugins folder ???
                            It might be loading an unedited version from somewhere ??????
                            • EdsonE Offline
                              Edson
                              scott,
                              my SU version is 8.0.13608.
                              TIG,
                              it is enough to remove vector.flat_angle.rb for SU to import the dwg without problems. I only removed the other to get rid of error messages asking for the other.
                              you have only posted the edited pathcopy.rb file, not vector.flat_angle.rb.
                              what fredo tool do you mean precisely?
                                Fredo's AdditonalPluginsFolder [or similar name...]
                                I'd disable both of RickW's files, as one needs the other etc...
                                • EdsonE Offline
                                  Edson
                                  no, I do not have that plugin by fredo6 installed.
                                  I have disabled both plugins. I am almost sure there are other plugins that help copy objects along a path.
                                  • bigstickB Offline
                                    bigstick
                                    Actually every one of my Macs in the office (3 in total) has the same problem of being unable to import dwg files in SU Pro. This has been the case for every version of SU8 pro that I have used, and in the office it makes no difference whether we are on Lion or Snow Leopard.
                                    The import seems to work fine, the geometry seems to be imported, and the summary dialog pops up with the imported entities, but then SU crashes.
                                    Works fine on my MacBook Pro at home with the same version of SU Pro 8.0.11751 though. This probably has more plugins than any of the other machines.
                                    Pathcopy is not the culprit for me because it's on my home machine which works, and on my office machine, which doesn't.
                                    Works fine on the PC under all situations.
                                    • EdsonE Offline
                                      Edson
                                      my only guess is that in my case vector.flat_angle.rb conflicts with some other plugin. finding it is something much beyond my knowledge.
                                        RickW
                                        Does SU crash if vector.flat_angle.rb is the only .rb in the Plugins folder?
                                        RickW
                                        www.smustard.com
                                        • EdsonE Offline
                                          Edson
                                          no. it looks as if it conflicts with some other plugin.
                                            RickW
                                            It seems to me that the only way a plugin could crash SU when using the native dwg import is by using observers. Can anyone think of any other way?
                                            RickW
                                            www.smustard.com
