The "Duh!" thread (aka the Doh! thread)
@oganocali said:
I usually remember there was a trick as someone's doh! moment to do what I want, I just can not remember who or where the trick was.
I had one of those DUH moments regarding the forums as well...
Usually searching works when you know exactly what you want... if I want to find "something that was somehow... I don't know exactly, but I can recognize if I see it", I'm sure that search box won't help
Maybe this is yet known but I just discover that today (Thx Chri)
With the follow-me, no need to select only the path, before call the Follow-me!
Click the surface is sufficient !I made Double clicks on the surface then Shift + Ctrl for deselect it for have only the path
(Double click Without deselection works also but...Here just 3 simple clicks
That's a new Duh! moment for me!!
Is it?
Interesting although admittedly I also have duh moments on trivia sometimes.
Note however that is there is a soften edge (say a diagonal) in the face, the follow me will not go completely around - not even when simply double clicking. In this case Pilou's "original" method: Double clicking then deselecting the inner (sur)face will do the job though.
So basically it only woks with single faces. Not even with coplanar but subdivided faces.
Another thing with Follow-Me I discovered a while back (and reported) is when you are defining a path that has curves, place the template face somewhere on a straight portion of any line segment, NOT at an endpoint.
If follow-me starts on an endpoint, the face template follows one of the subtended angles and royally screws up at the end, with an end face out of alignment. This is especially a major factor with closed loops.
However, if started on a straight section, it will end perpendicular to the last line of the path, and if the path is a closed loop, it will join properly.
Useful to know!
I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
It's a useful way to orbit/pan without using two hands
Mini Doh (due forgotten function)
- Alt gives you the possibility to Move a segment escaping at the X Y plan
!!! OMF-DUH!!!
A bit awkward though, as I use my index finger usually to press the middle mouse button, so I need to shift to my middle finger to free up my index for the left mouse button. ...which it was the right button that did that...
Ditto. I have known this "feature" but could never adapt myself to it.
That is very curious, because with the medium you can rotate many more the Mouse wheel than with index!
So more speedy scolling!
For the simple reason that the Medium is biggest than the index!
So the medium is always on the whell, so click it is a formality!
Try it! -
Try it!I have always used my mid finger on the wheel, with index on the left button. I also move my mid to the right button when needed as the ring finger has less control (which is why it is the "ring" finger ).
It shouldn't take long to adjust to that finger position.
And now I know why my "orbiting" suddenly goes into "panning" when my index finger twitches downward sometimes. Now that I know, I can exploit that feature. Thank you Broomstick.
And Pilou, I fail to see what you mean with Move+Alt. Could you please explain a bit more?
Hi Pilou, hi folks.
Yes, pressing the ALT key enables Autofold.
Just ideas.
Is that more clear ?
Without Alt Z axis is locked!
You can make some prisms or no coplanar faces with Move + Alt!
The Z axis become free with Move + Alt -
And here is the autofold description:
http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94865 -
I wish there was an option to make SketchUp Smooth+Soft auto-folded edges.
I've been harping on this for years now but I don't think anyone ever tries it.. oh well
orbit with a thumb button (if your mouse has one).. not only is it more comfortable, it also gets rid of the double duty zoom/orbit mmb... AND- makes panning with the LMB much easier.
Thumb buttons are Copy, Paste ...
