    Having a Duh! moment
    13 Posts 7 Posters 629 Views 7 Watching
    • Rich O BrienR Online
      Rick Wilsons Copy Along Path
      Chris' Component Stringer
      Spring to mind.
      • soloS Offline
        Stringer is not working for some reason on my rig.
        Will try copy along path.
        • ely862meE Offline
          ely862me
          Copy along path will work , but the chairs will not be rotated in the right direction .
          For the attached image i made a normal row and bent it with radial bending from Fredo's scale . Too bad they are not components anymore. I would have create copy on the other rows too, they would have had more space between them , but it would have been pretty nice !
          huh-2 - radial bending with fredo-s scale.skp
          Elisei (sketchupper)
          Come and See EliseiDesign
          • ely862meE Offline
            ely862me
            Component stringer seems to work . It rotated the chair downward but i rotated it back and then i copied other instances up to the other rows . They are not nice and even but with a bit more care will do !
            huh-2 - component stringer.skp
              Component Stringer works for me?
              You need to align the axis
              • andybotA Offline
                andybot
                That's interesting, so it's not just me. I've had to use the dummy object trick with component stringer too. It does weird things/ doesn't work sometimes with certain components.
                • soloS Offline
                  This is gonna be one tricky project.
                  Here is my reference, so you can see what I need to achieve.
                    Draw a Component "segment" with axes at its middle
                    Draw this component segment at any places and orientations you want
                    Select all components "segments"
                    Menu Component / Choose Component "Chair" (with same axes than "segment" ) / Replace Selected
                    = all chairs will be well aligned!
                      seems symetric so half work to make 😉
                        I'm gonna pitch a curveball and suggest TGI3D Warper and Terrain tools.
                        Warper to form delicate curves and Terrain tools to drop them.
                        • E Offline
                          Ecuadorian
                          I can confirm that the latest version of Copy Along Path in SU 8 Free correctly rotates each component according to the path. I guess you're gonna render in something that allows the use of instances, Pete?
                          -Miguel Lescano
                          • jeff hammondJ Offline
                            it's not bad at all using vanilla tools… for that theater, i think you'd just need to do a few sections then mirror them etc…
                            here's a step_by_step .skp:
                            theater_seating.skp
                            good luck.
