Having a Duh! moment
13 Posts 7 Posters 280 Views
    Anyone know an easy way to string chairs to a path, they need to face accordingly.
    See image, this is just a test shape so i can learn/remember how it's done, the real project will need 4800 seats.
    SKP attached
    Thanks. (Solo the noob)
    huh.skp
    • R Online
      Rick Wilsons Copy Along Path
      Chris' Component Stringer
      Spring to mind.
      Download the free D'oh Book for SketchUp
        Stringer is not working for some reason on my rig.
        Will try copy along path.
        • E Offline
          ely862me
          Copy along path will work , but the chairs will not be rotated in the right direction .
          For the attached image i made a normal row and bent it with radial bending from Fredo's scale . Too bad they are not components anymore. I would have create copy on the other rows too, they would have had more space between them , but it would have been pretty nice !
          huh-2 - radial bending with fredo-s scale.skp
          Elisei (sketchupper)
          Come and See EliseiDesign
          • E Offline
            ely862me
            Component stringer seems to work . It rotated the chair downward but i rotated it back and then i copied other instances up to the other rows . They are not nice and even but with a bit more care will do !
            huh-2 - component stringer.skp
            • R Online
              Component Stringer works for me?
              You need to align the axis
                andybot
                That's interesting, so it's not just me. I've had to use the dummy object trick with component stringer too. It does weird things/ doesn't work sometimes with certain components.
                  This is gonna be one tricky project.
                  Here is my reference, so you can see what I need to achieve.
                    Draw a Component "segment" with axes at its middle
                    Draw this component segment at any places and orientations you want
                    Select all components "segments"
                    Menu Component / Choose Component "Chair" (with same axes than "segment" ) / Replace Selected
                    = all chairs will be well aligned!
                      seems symetric so half work to make 😉
                      • R Online
                        I'm gonna pitch a curveball and suggest TGI3D Warper and Terrain tools.
                        Warper to form delicate curves and Terrain tools to drop them.
                        • E Offline
                          Ecuadorian
                          I can confirm that the latest version of Copy Along Path in SU 8 Free correctly rotates each component according to the path. I guess you're gonna render in something that allows the use of instances, Pete?
                          -Miguel Lescano
                          • jeff hammondJ Offline
                            it's not bad at all using vanilla tools… for that theater, i think you'd just need to do a few sections then mirror them etc…
                            here's a step_by_step .skp:
                            theater_seating.skp
                            good luck.
