    Help! How to make a spiral like a paper?
    29 Posts 12 Posters 1.6k Views 12 Watching
    • pbacotP Offline
      I think shape bender is more likely to be closer to the original paper size and shape.
      OK gilles I have to ask, what IS that avatar supposed to be?
      Pilou you have to say how you made the spiral.
        Green names are "Top SketchUcators", distinguished forum members.
        "Top SketchUcators" are known as exceptionally active and helpful as well as highly skilled members of the SketchUcation Community Forums. This is a closed group, new members can only join upon invitation of a group leader.
        They can, however, choose to remain a bit "under cover" and do not set that usergroup as their default so some of them are blue as regular members.
          Don Burns
          Manual SU by my above method. I'm sure it's a little slower than fredoscale and probably a little harder. Took about 25 min. and I should be doing something else, but this is more fun.
          • gillesG Offline
            gilles
            It's a dog.
              Ha. I can see now. In fact, a male dog. 😄
              • pbacotP Offline
                😆 Sorry I asked.
                • pbacotP Offline
                  With FredOscale Free bending tool. I just like using it for the fun of it. Way more fun than doing my taxes.
                  Start with rectangle. Make component. Put another rectangle vertical along direction of curl (I drew corner to corner) for setting the rotation. You have to bend a portion (I used 1/3). take off the straight portion (using edit component, choose flat face and edges, make component, cut, exit component, paste in place), bend that-- and repeat for total of three or more times, because you can only go 180 in each bend. Probably faster other ways? But this feels more "realistic" and you can adjust procedure for the curl you want.You explode and rejoin the portions at the end.
                  "distinguished"? Now I'll have to grow a mustache.
                    Like the first post with the draw Helix 😉
                    Draw any Helix / Copy Move then Scale it
                    The beauty of the thing is all that take 5 seconds to make! 😉
                      shahreza90
                      Super cool! You guys just save me!
                      • brookefoxB Offline
                        brookefox
                        @gilles said:
                        It's a dog.
                        I'm confused. I see what might be a tail, an organ, and an orifice but at that point my imagination can't hack it.
                                       **EDIT:** Now I get it. Before, I could not hear the splashing.
                        Great tips on the model, folks. First I'm going to try Pilou's 5 second method. Be back in the morning sometime when I finish.
                        I'm back but for me the use of TIG's tool is not intuitive. I don't doubt that that is more a reflection of my limitations but one might need reminding that TIG's tool needs curves for the rails, as Pilou mentioned. So you need to draw even a straight edge as multiple sections or divide it and then weld it into a curve.
                        ~ Brooke
                        • gillesG Offline
                          gilles
                          Definitely Shape Bender:
                          • pbacotP Offline
                            We never listen.
                              Jim
                              @gilles said:
                              It's a dog.
                              [off:116hequd]Oh. Can not be unseen.[/off:116hequd]
                                [off:25v2rhb7]Un chien mâle qui pisse, vu de derrière 😲[/off:25v2rhb7]
                                  Very conceptual avatar! 💚
                                    brookefox
                                    Thanks for learnin' me a little, after which, for me, extrude edges by rails works best, simply because I could not make the length of the helix and the diagonal to match so shape bender had an annoying error (the little projecting tab). How to make these equal? Note also the disagreement about the length of the scaled helix curve info=112', label=245'. I assume the scaling threw a wrench in the works?
                                    ~ Brooke
                                    • gillesG Offline
                                      gilles
                                      #1 draw the path ( helix )
                                      #2 select it, open entity info to get the length
                                      #3 draw the line the same length
                                      #4 draw the diagonal sheet the same length
                                      #5 draw the sheet with circle tool set to 4 segments ( if you want a square sheet )
                                      #6 erase the diagonal
                                      #7 group the sheet
                                      #8 run shape bender.....wait....
                                      #9 resize the model with tape tool. done
                                      it takes five minutes.
                                        brookefox
                                        Thanks for that.
                                        Sly:
                                        Perhaps that method it is more accurate than 'extrude edges by rails' even if a little slower.
                                        ~ Brooke
                                        • gillesG Offline
                                          gilles
                                          If your paper is square it's fast as you already have the diagonal.
                                          • mitcorbM Offline
                                            mitcorb
                                            Anybody tried Spirix on this? I am not sure if it can be applied here. Some more info, I think is in a thread back about 4months. As far as I know, the author doesn't post here.
