    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • K
      kubusipit
      I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
      Jeem
        mac1
        Jeem
        Just happen to see this in passing:
        1. The way the windows 32 bit memory manager works it splits the memory somewhat equally between the kernel and the program. In addition any device memory ( graphics etc) gets mapped into that a subtracts form the usable memory. Check you task manager and think you will find low memory. Check what you have set for the paging file size and the memory manager will use the hard disk to help that problem but then the PC slows down because of the slower disk. IMO you should install more RAM if possible and is not hard to do just make sure you use an anti static strap.
        • fredo6F
          Jeem
          Just in case, could you open the Ruby console in case messages are displayed when running RoundCorner.
          There are a few plugins that create incompatibility problems (for instance some versions of Matchhbox and SunPosition). This may also be a source of problem.
          • C
            chalky
            I too have this problem. Lion 10.7.3 - SU v8. Latest Plugins too. Please help 😞
              sketchdraw
              only one thing: thank you
              its amazing
              • bagateloB
                bagatelo
                I have found the fourth icon.
                Download the attachment and think about.
                dream.skp
                  janmakowka
                  Hello, I have a problem.
                  Does the corner have to be at a 90 degree angle, or can it be any angle? Because when I try to do it at a non-90 degree angle it goes crazy and does this:
                  I am running windows 7, 32bit. I have 2048mb RAM. All help is appreciated 😄
                    MaciejS
                    Hello Everybody
                    I tried that tool on my model but it doest work correctly, does anybody have an idea what should i do to make all edges and corners smooth ? Help please
                    http://www.newcolorstudio.pl/valve.jpg
                    • fredo6F
                      @maciejs said:
                      Hello Everybody
                      Could you post the model, so that we can find out.
                      I guess this could be done piece by piece (plus duplication x6, as the wheel is symmetrical)
                        MaciejS
                        Yes, all parts of the model are symmetrical. All i need is to smooth every edge and make smooth transitions between parts.
                        here is a link: http://www.sendspace.com/file/1s2pol
                        • fredo6F
                          There are several problems with the model:
                          1. you have hidden internal faces at the ends of the branches of the steering wheel. This is why you cannot select some edges.
                          2. most corners have 4 edges, and their configurations seems to reach the limit of RoundCorner (4 edges and more are supported, but the algorithm is not very robust)
                          I think you have to either do the roundings manually or reconsider the design to have corners with 3 edges or try a subdivision with Whaat's Artisan.
                            MaciejS
                            Thank you Bro, i am going to fix it manually doing one branch separately and copy as you said. Could you tell me how can i check if my models have hidden internal faces?
                            • GaieusG
                              If you make a group and in the entity info box, you cannot see "solid", there may be internal faces (but other errors can also cause this)
                              You can also use this plugin to remove them:
                              http://forums.sketchucation.com/viewtopic.php?t=12668
                                MaciejS
                                It seems to be very useful plugin, thank you Gai. Im gonna try it out.
                                  AcesHigh
                                  Please, someone help me. A client asked me to do him a render of a logo. I made it for him like this:
                                  http://img341.imageshack.us/img341/6302/prototipo02.jpg
                                  Notice I used ROUNDCORNER around the logo, because the client wanted a glossy shiny effect on the borders, as seen in many rasterized 2D logos made in CorelDraw.
                                  I submitted the logo, but he wants MORE GLOSSY EFFECT, and sent me this logo as an example
                                  http://img12.imageshack.us/img12/5246/exemplologoglossy.jpg
                                  Ok, lets not enter the question of how to make that material in VRAY. I will create a topic at the VRAY section for that.
                                  Right now, I will try to create that effect by INCREASING the roundness of the corners of the logo.
                                  BUT THATS WHERE MY PROBLEMS START. I uploaded the same logo before any round-corner effect was applied.
                                  As you can see, the plugin doesnt work very well with the shapes of the logo, specially the upper and lower sections (darker blue).
                                  logocru.rar
                                    AcesHigh
                                    @aceshigh said:
                                    Fredo, this was probably asked before, but I didnt find it in this very long thread. Neither I found the answer in the quick manual.
                                    Check the image attached... the offset somehow overlaps itself. It happens quite often when I try to use your tool. And when the offset overlaps, it usually results in problems in the end.
                                    How do I solve this issue?
                                    this is my previous post about the same issue...
                                      AcesHigh
                                      I guess nobody has a solution? At least a suggestion of another program where I might try to round the corners of my object?
                                      • fredo6F
                                        RoundCorner is based on pure geometry and therefore the overlap issues (when the offset is too large) has no satisfactory solution.
                                        I think that Artisan by Whaat, which is based on a softer method, by subdivision, could help.
                                          AcesHigh
                                          Fredo, I noticed that the overlap issues in certain shapes occur even when the offset is MINIMAL...its just harder to notice, unless you zoom in.
                                          • fredo6F
                                            The fact is that the algorithm is too geometrical to handle complex meshes. It is more adapted when the edges to round are aligned.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 74
                                            • 75
                                            • 26 / 75
