    Can't create Void
    28 Posts 5 Posters 1.7k Views 5 Watching
      Rustyy
      Edited OP and uploaded file. (uploading went to 100% so hopefully has been successful this time)
        Uh....nope.
          Rustyy
          Ok well am I doing it right by going to edit, upload attachment and then choosing the file, clicking on add file and waiting for it to upload?
          Anyone know of any good file hosting websites?
          • gillesG Offline
            gilles
            Maybe your files is too big? Just thinking...
              Rustyy
              Its 20.9MB is that too large?
                4Mb ! ๐Ÿ˜ฎ
                Copy.
                Model Info > Statistics > Purge Unused...
                Any smaller ?
                Zip it to try to make it even smaller.
                4Mb zipped IS a large SKP...
                  Rustyy
                  Right that looks like its worked, its in my OP
                    Yep. Now it's there.
                    So where did you want to put this hole? I put one on the same surface as the other two holes you'd drawn. No problem just drawing the oval hole and pushing it through.
                      Rustyy
                      FML.... Yeah its working fine for me too now ๐Ÿ˜ฎ Sometimes I wonder if its got a mind of its own ๐Ÿ˜ณ
                      Are you able to create a void using the highlighted shape selected in the below screenshot? the depth is 5mm.
                      http://img94.imageshack.us/img94/6017/71529731.png
                      Thanks for your help. ๐Ÿ‘
                        No but it looks like the bottom face isn't parallel to the top so it isn't surprising. It's not car out but it doesn't take much.
                        You've got a lot of messy geometry in that model and I think it's causing you the problems. If I were in your shoes I would start the entire model from scratch and make better use of components.
                        I wouldn't make this all as one big hunk of geometry. I'd split it up into sections that represent the way it would be made in reality. Make each of those parts into components.
                          Rustyy
                          Sigh... see im a massive sketchup noob ๐Ÿ˜ž
                          Once a component is made can it not be reversed?
                            What do you mean it cannot be reversed? Do you mean modified? Of course it can. You simply open it for editing by right clicking on it and choosing Edit component or double clicking on it with the Select tool.
                            I don't mean to sound condescending but I think before you tackle this computer case, you should try some simpler things and actually learn to use the program.
                              Here's an example of my workflow. Perhaps it'll give you some ideas.
                                Rustyy
                                Yeah I know how to edit a component, but as soon as your done editing it and click somewhere else the component is saved. is it possible to make a component not a component?
                                Do you have any good guides I could read or video tutorials?
                                EDIT: thanks I'll take a look at your workflow ๐Ÿ˜„
                                  I don't understand what the problem is with saving the changes in your component. Why would you want to edit something and not save the changes?
                                    Rustyy
                                    Don't worry about it man, I'll just start again
                                    I found it differcult to follow your workflow, nice job though ๐Ÿ‘
                                      It wasn't intended as a basic tutorial but you should see that I draw one piece and make it a component before moving on to the next and I add details after all the large parts are in place by opening the components and editing them.
                                      I still don't understand your comment that you don't want to save changes you make when you edit components.
                                      • BoxB Offline
                                        You can make it a "Group" or you can "Make Unique".
                                        Group makes it a simple individual bunch of geometry.
                                        Make Unique keeps it as a component but a new one so it doesn't alter other versions of the original component, but will alter new versions of itself.
                                        • gillesG Offline
                                          gilles
                                          If you want to modify just one instance of a component make it unique (context menu or edit menu).
                                            Rustyy
                                            Ok thanks guys, I think I'll read up on the basics and make sure I know what I'm doing, then perhaps start on something more simple.
