    Can't create Void
    28 Posts 5 Posters 1.7k Views 5 Watching
      Since you were able to do it with the rectangle, I'm guessing that at least part of the oval shape was not on the surface. It would help if you posted the SKP instead or in addition to the screen shots.
        Rustyy
        Hi, thanks for replying
        Since yesterday I tried it a different way by creating the void with a rectangle then adding in the ovals, this worked but was quite long winded. I've attached the sketchup file.
        Thanks for your help.
          There's really no reason you should have to do that.
          By the way, no file found.
            Rustyy
            I tried re-uploading the attachment, any joy?
              Retry now...
                Rustyy
                Sorry guys my internet connection keeps dropping out randomly, I'll try and upload again when my interwebs are working.
                ๐Ÿคข
                  Rustyy
                  Edited OP and uploaded file. (uploading went to 100% so hopefully has been successful this time)
                    Uh....nope.
                      Rustyy
                      Ok well am I doing it right by going to edit, upload attachment and then choosing the file, clicking on add file and waiting for it to upload?
                      Anyone know of any good file hosting websites?
                      • gillesG Offline
                        gilles
                        Maybe your files is too big? Just thinking...
                          Rustyy
                          Its 20.9MB is that too large?
                            4Mb ! ๐Ÿ˜ฎ
                            Copy.
                            Model Info > Statistics > Purge Unused...
                            Any smaller ?
                            Zip it to try to make it even smaller.
                            4Mb zipped IS a large SKP...
                              Rustyy
                              Right that looks like its worked, its in my OP
                                Yep. Now it's there.
                                So where did you want to put this hole? I put one on the same surface as the other two holes you'd drawn. No problem just drawing the oval hole and pushing it through.
                                  Rustyy
                                  FML.... Yeah its working fine for me too now ๐Ÿ˜ฎ Sometimes I wonder if its got a mind of its own ๐Ÿ˜ณ
                                  Are you able to create a void using the highlighted shape selected in the below screenshot? the depth is 5mm.
                                  http://img94.imageshack.us/img94/6017/71529731.png
                                  Thanks for your help. ๐Ÿ‘
                                    No but it looks like the bottom face isn't parallel to the top so it isn't surprising. It's not car out but it doesn't take much.
                                    You've got a lot of messy geometry in that model and I think it's causing you the problems. If I were in your shoes I would start the entire model from scratch and make better use of components.
                                    I wouldn't make this all as one big hunk of geometry. I'd split it up into sections that represent the way it would be made in reality. Make each of those parts into components.
                                      Rustyy
                                      Sigh... see im a massive sketchup noob ๐Ÿ˜ž
                                      Once a component is made can it not be reversed?
                                        What do you mean it cannot be reversed? Do you mean modified? Of course it can. You simply open it for editing by right clicking on it and choosing Edit component or double clicking on it with the Select tool.
                                        I don't mean to sound condescending but I think before you tackle this computer case, you should try some simpler things and actually learn to use the program.
                                          Here's an example of my workflow. Perhaps it'll give you some ideas.
                                            Rustyy
                                            Yeah I know how to edit a component, but as soon as your done editing it and click somewhere else the component is saved. is it possible to make a component not a component?
                                            Do you have any good guides I could read or video tutorials?
                                            EDIT: thanks I'll take a look at your workflow ๐Ÿ˜„
