    [tutorial] Sketchup Macros (OSX)
    18 Posts 5 Posters 5.9k Views 5 Watching
      Setting the screenshot to a fixed ratio would be nice, with a timestamp/watermark
      • jeff hammondJ Offline
        yeah.. i agree.. the popup alerting you to take a screenshot then the selection window is getting annoying..
        i think i'm going to set it up as a square ratio (height of window determines how wide to make it.. (i.e.- the same thing as choosing medium format 6x6 in advanced camera tools)
        probably won't do the timestamp.. osx makes it easy to view/sort by pretty much anything that could be associated with a file…
        (i will say, this service, while definitely helpful for me, is nowhere as neat/integrated as what's possible to do with osx itself.. i might upload an example of how saving works in Rhino (which is tied into osxVersions).. it's great.. it does take a bit of getting used to at first because typical 'save' 'save as' etc is so ingrained in us now and versions changes that (i.e.- you never save πŸ˜„ )..
        i'm sure it will come to windows soon..
        • bmikeB Offline
          bmike
          i so need to get on board with the saving stuff in OSX. still dating each file nearly every other day and having a hard time getting used to where to find stuff when i need a particular file. 'date modified' was my favorite sort in windows... that seems hit and miss in OSX.
          this is good stuff. thanks for sharing.
          • bmikeB Offline
            bmike
            that last video is great...
            will have to investigate that for sure.
              I'll rewrite parts of it so it's not specific to my machine and share it.
              (if you're on lion, sharing services is a breeze.. still possible to share on 10.5 & 6 but the user has to manually place it in the services folder)
                Cool Stuff ! 😎
                Why only just now and not from many years ago ? 😲
                Any idea for make the same on PC (the first macro) ❓
                • wind-borneW Offline
                  wind-borne
                  did create a couple macros 😎
                  would like guidance on creating macro of full SU window capture for icon/preview followed by cmd S without creating new file.
                  I'll let ForeverSave keep the manual(Automator) versions with it's autosave unchecked and sort from there.
                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                  %(#BF80BF)[SU 8 pro
                    wind-borne
                    Jeff,
                    having problems with the final applescript, doesn't seem to access SU.
                    "A" toggles axes off, but doesn't toggle back on with last script. Other test was trying "cmd a" in final script which should have selected all in SU but selected all on desktop instead. Tried shifting order?
                    other problem is this SU dialog which pops up after every first save after running macro. Can I automate a Save for this?
                    if I use GC, icon updates on main file which is probably my main goal as I don't often use ForeverSave2 as was icing on a big Mac bundle...
                    %(#BF80BF)[SU 8 pro
                      @wind-borne said:
                      Jeff,
                      yeah.. you've left the sketchup environment at this point in your script by going to finder and maybe graphic converter..
                      to get back to sketchup, you'll have to add this prior to your final system events tell
                      tell application "sketchup" to activate
                      this will bring sketchup back to the front application.
                      [attachment=2:32yjarrq]<!-- ia2 -->SketchUp.png<!-- ia2 -->[/attachment:32yjarrq]
                      hmm.. i'll have to look into this a little later to see what's going on..
                      fwiw, getting a non interactive screenshot (unless it's the entire screen) has proven to be a lot more difficult than i originally though it would be.. i'm in a thread at an applescript forum right now trying to reach a solution but it's not looking too good..
                      i also tried going the route of using sketchup's 2d export to create the icon image (which is actually pretty awesome because you could do pngs with transparent backgrounds.. it also eliminates what you're doing with hiding the axes because a 2d export doesn't include it).. the problem with that is there's about a 5 second delay in there because of something weird going on with the export dialogs (and i've posted about this on the google sketchup forums)..
                      if you open 'activity monitor' then go to sketchup's 2D export -> Options… you'll see a ginormous spike in cpu usage.. something is wrong with opening those panels which causes a slow down in the script i was trying to make..
                      still researching though.. non conclusive as of now.
                        wind-borne
                        Thanks,
                        I had tried moving script between Screenshot and Finder section.
                        needs to be
                        tell application "SketchUp" to activate πŸ˜†
                        Works now.
                        I was trying the " Watch Me Do" to automate pick window, didn't work how I tried.
                        %(#BF80BF)[SU 8 pro
                          @wind-borne said:
                          Thanks,
                          needs to be
                          Works now.
                          yeah.. watch me do doesn't work out as good as it seems.. super slow and whatnot..
                          i'm now messing around with the idea of getting the icon image via ruby instead of a screenshot or GUI scripting sketchup.. ruby confuses the hell out of me though πŸ’š ..i'll make a post in the developers forum real quick.. those guys will help me sort it out.. πŸ˜‰
