[Plugin] FredoTools - v4.5a - 02 Apr 24
What a powerful tool, too practical, easy language conversion, love you Fredo6
"Show Box Lines" setting for Area Labeler.
What does this mean?
When you mouse over or select components, it shows the box of each subcomponents (instead of just showing the faces).
Thanks Fredo!!
Spanish Language
FredoTools_ES.lang -
@oxer said:
Thanks Fredo!!
Spanish Language
[attachment=0:7r7026d2]<!-- ia0 -->FredoTools_ES.lang<!-- ia0 -->[/attachment:7r7026d2]Oxer,
Thanks very much.
I just realized that I did not make the Help of VCB and shortcuts translatable. So I'll make it in a next release. This means that there will be some additional strings to translate.Thanks again
There isn't problem Fredo, i'll translate it and thanks again for these incredible tools.
I'm testing the FredoTools plugin and i have found some problems:
- The arrows keys don't work on Mac.
- When you use the first time "Remove Lonely Vertices" and you select "Remove" then if you push the icon "Launch FredoTools plugins from a list" the window of the list don't appears.
For the moment the rest of the features works fine on Mac.
Nice update!
Thanks Fredo Nice Work
Need Help Can not Save my new german translation ??
and in 000_AdditionalPluginFolders i got the message:2ERRORS The Following plugins had errors and may not be fully loaded
Plugin: LMapExt.so
Folder:C/ProgramFiles(x86)Google/GoogleSketchup8/Plugins
ERROR: (eval):1: uninitialized constant
AdditionalPluginFolder6;;LMap
(I Have Not createt an extra Plugin Folder)
and
Plugin: win 32api.so
ERRER: 127
Init_win32api
C/ProgramFiles(x86)Google/GoogleSketchup8/Plugin/win 32api.soThanks for help
SU8 on win7
Plugin: LMapExt.so
and
ERRER: 127
Init_win32api
SU8 on win7
This does not seem related to my scripts.
Maybe some users could tell what is this LmapExt.so fileFredo
It's associated with LightUp and it should be in the Tools folder
I downloaded last FredoTools 1.1 and LibFredo 44, all tools works good except ThruPaint. When i paint by texture(not by colour!) ScetchUp8 crushes! What is a reson of it?
Could "Reverse Faces" be available in the context menu of Thru Paint?
I think this is possible, but the Auto-flip option was there precisely to flip faces on the same side.
Is it reproducible and systematic?
Are you sure this is only with texture, never with color?Thanks
Fredo why don't you incorporate 'LibFredo' files with 'Fredo tools' pack?
Simply because LibFredo6 is used by many of my other plugins and that you usually need to have the latest version installed.
So incorporate all your stuff (which ~90% is a 'must have') in ONE megapack (with ability to selectively install\uninstall)
Just like another guru does:
http://www.neilblevins.com/cg_tools/soulburnscripts/soulburnscripts.htm -
Yes, Fredo. This is systematic and this is with textures only. As i put brush with texture to an object, it stay panted by texture,red clocks of waiting appears and program fly out immediately! All other plugins and programmes works properly.
Thanks. -
Hi Fredo,
Apart from all my congatulations for this marvelous plugin, just one wish: would it be possible to set the font size used in the dialog boxes and palettes ? (See below)
Best regards,
