    Front Face
    9 Posts 4 Posters 457 Views 4 Watching
      Kasimashi
      Hi !!!!
      How can I put all my model with front face ?
      Thanks for your help !
        Hi Alex,
        See some of these plugins for easier flipping faces:
        http://forums.sketchucation.com/viewtopic.php?t=44551
        http://forums.sketchucation.com/viewtopic.php?t=5333
        http://forums.sketchucation.com/viewtopic.php?t=32088
        http://forums.sketchucation.com/viewtopic.php?t=13380
          Kasimashi
          Thanks you very much for your help but when , I want to delete the back face for front face.
          But the back face reversing ... In my model I want just front face without back face.
          Thanks for you help
          Sorry for my english but I'm French ^^
          • gillesG Offline
            gilles
            Il n'existe pas de recto sans verso.
              Do you mean to remove all faces' back materials and leave their front materials completely unchanged ?
              Voulez-vous dire pour enlever tous les matériaux à partir des dos des visages et de laisser leurs matériaux frontales inchangée totalement?
              • gillesG Offline
                gilles
                MĂȘme si le matĂ©riau appliquer aux faces est identique, SU reconnait toujours un recto et un verso.
                Utiliser l'option affichage/style de face/ monochrome permet de vĂ©rifier l'orientation des faces, le recto front face doit toujours ĂȘtre orientĂ© vers l'extĂ©rieur de l' objet surtout si l'on faire un rendu.
                Even if front and back faces have the same material applied, SU always recognize a front face and a back face.
                Set View/face style/monochrome let you see faces orientation, always orient front faces front if you need to render.
                  Kasimashi
                  Ok , So I can't thanks for this information
                  tir des dos des visages et de laisser leurs matériaux frontales inchangée totalement?*[/quote
                  Yes
                    The one-liner code below copy/pasted + <enter> into the Ruby Console, will remove all of the back-materials from selected faces.
                    It is one step undo-able.
                    The displayed color of a back-face that has no material depends on the Style settings - typically it's a blue/gray. You can reset it to anything you like in a Style > Edit...
                    Faces within a group/instance will need to be selected whilst you edit the group/instance.
                    If the faces are within a group/instance and that 'container' has a material applied to it, then any default faces [backs OR fronts] will display in the group's material, even though they have really no material.
                    m=Sketchup.active_model;m.start_operation('bm2nil');m.selection.to_a.find_all{|e|e.class==Sketchup;;Face}.each{|f|f.back_material=nil};m.commit_operation
                    La seule ligne de code ci-dessous copier / coller + <enter> dans la Console Ruby, va supprimer tous les matériaux de dos faces sélectionnés.
                    Il s'agit d'une premiÚre étape défaire.
                    La couleur affichée d'un retour que face a aucun matériau dépend des réglages de Style - généralement il s'agit d'un bleu / gris. Vous pouvez le remettre à ce que vous voulez dans un Style > Modifier ...
                    Faces au sein d'un groupe [ou de l'instance] devront ĂȘtre sĂ©lectionnĂ©e pendant que vous modifiez le groupe [ou de l'instance].
                    Si les faces sont dans un groupe [ou de l'instance] et que «conteneur» a un matĂ©riau appliquĂ© sur elle, alors toutes les faces par dĂ©faut matĂ©riels [le dos ou devant] affichera dans le matĂ©riel de la «conteneur», mĂȘme si elles ont vraiment pas de matĂ©riel.
                      Incidentally, if you want to apply the same material to all backs then replace the text back_material=nil with back_material="MAT", where MAT is the name of that material inside "".
                      So for example, if you wanted all selected faces' backs to be 'invisible' you make a material using a fully transparent PNG as the texture and 100% transparency, use that as the backs' material and you can see through walls/ceiling etc when outside !
                      Soit dit en passant, si vous souhaitez appliquer la mĂȘme materiau Ă  tous les dos des faces, puis remplacer le texte back_material=nil avec back_material="MAT", oĂč MAT est le nom de ce matĂ©riau Ă  l'intĂ©rieur "".
                      Ainsi, par exemple, si vous vouliez toutes les dos des faces sĂ©lectionnĂ©es d'ĂȘtre «invisible» que vous faites d'un matĂ©riau en utilisant une image PNG totalement transparent que la texture, et 100% de transparence, l'utiliser pour les dos, et vous pouvez voir Ă  travers les murs ou au plafond , etc quand on regarde de l'extĂ©rieur!
