    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 602.7k Views 102 Watching
    • EarthMoverE Offline
      EarthMover
      Next drink is on me my friend. Loving this plugin! Donated a little more than I paid for the new commercial UV tool as I think there are more features with ThruPaint. Although I think both tools together have great synergy.
      Content Creator at Skapeup
      • N Offline
        numerobis
        WOW! incredible! 😎
        Thank You very much for your great work!!! ...once again.
        • fredo6F Offline
          @bagatelo said:
          What then would be the advantages or disadvantages from this Plugin for Plugin SketchUV done by whaat? May I have to try both to say something...
          SketchUV is much more powerful for real UV Mapping. You can export, map UVs and import back to have a professional work. ThruPaint is just a paint tool that handle texture continuity in predefined situations within Sketchup. So both are complementary.
          Whenever I can, I will check whethere they could be any incompatibility or conflict when applying texture in one and editing in the other.
          • lele_poggiL Offline
            lele_poggi
            Simply the best!!!
            gsa | Gabriele Sacchi architetto
            http://www.gs-a.it
            • N Offline
              notareal
              Another great tool! Thank you.
              • N Offline
                nomeradona
                another mind blowing plugin.. thank you Fredo...
                • W Offline
                  wolfy
                  Fredo,
                  @thomthom said:
                  @wolfy said:
                  I am getting a bugsplat every time when I try to apply a material to a newly created group.
                  If I create a group and paint it with the native SU bucket, sample that with Thrupaint and apply it to a different group I don't get a bugsplat. Weird.
                  Any ideas?
                  Wolfy,
                  Could you be more explicit.
                  Are you on Mac or Windows?
                  What do you mean by "newly created group"?
                  That sounds like the material applied is from the Material Library and not In Model. The bugsplat I mentioned in my Materials article. Did you trap for that?
                  Fredo and ThomThom,
                  Thanks for the replies. I mean "newly created group" as in the first group I make when opening Sketchup, and yes I am picking the material from the materials library. Is that not the correct procedure? Does the material have to be in the model for use with Thrupaint?
                  Can't wait to learn the ins and outs of the fantastic plugin Fredo! Your skills are amazing ☀
                  • fredo6F Offline
                    @wolfy
                    A few questions to help me spot the problem
                    1. Is the material a color or a material with texture ?
                    2. Does the crash happen when you paint or when you simply mouse over the model
                    3. Do you use the options "Paint Faces and Edges"?
                    4. Does it happen always, or randomly?
                    5. Are you on Mac or Windows and which SU version ?
                    6. Could you post the model (and the newly created group) in the forum so that I can see if I can reproduce it.
                    • OxerO Offline
                      Oxer
                      Thanks you very much Fredo!! 👍
                      I have translated the plugin to spanish language, if you want i send it you by private message.
                      • W Offline
                        wolfy
                        @wolfy
                        Hi Fredo,
                        1. I've used both and it bugsplats in both cases.
                        2. Crash only happens whilst painting.
                        3. I've tried with same bugsplat result.
                        4. It happens everytime I try to paint a newly created group. (the 1st one after opening a new model)
                        5. Windows.
                        6. I simply created a random shape each time to test/try the plugin, no materials in the model and picked material from materials library after I had invoked the plugin. Each random shape/model bugsplats when i try to apply a new material with the plugin.
                        When I pick a material already in the model the plugin works fine, it's when I choose a new material from the material library that I get a bugsplat.
                        Thanks for the feedback!
                          leminilab
                          I'm working with Curviloft and Thrupaint...
                          I think I'm gonna vote for you to be the next president of France...
                          • "Live every day as if it were your last and then some day you'll be right."
                          • "ThomThom rules!!!"
                          • fredo6F Offline
                            @wolfi
                            Just a few other questions, as I am unable to reproduce it (and apparently it does not happen for the first users of ThruPaint)
                            1. Which version of SU
                            2. After you use ThruPaint with a material in the model (so no bugsplat) and you try a material in the Library, do you still get a bugsplat?
                            3. do you get a bugsplat if instead of a group, you paint a shape at top level of the model, or a true Component?
                            • W Offline
                              wolfy
                              @wolfi
                              Fredo,
                              It seems to work beautifully on my work computer. ☀
                              I will reinstall again and hopefully eliminate this bugsplat deal.
                              Thank you for your responses and I'll be sure to post my reinstall status.
                                d12dozr
                                Awesome, no, AWESOME plugin Fredo! Thank you for all your hard work making Sketchup better!!
                                http://goo.gl/f7ooYh
                                • charly2008C Offline
                                  charly2008
                                  It is wonderful that here in the forum are many talented Ruby programmers. Fredo, thanks a million for this additional excellent tool.
                                  Charly
                                  • Didier BurD Offline
                                    Didier Bur
                                    And I'm candidate to be his prime minister 🤣
                                    DB
                                    • fredo6F Offline
                                      NEW RELEASE: ThruPaint v1.0m - 14 Apr 12
                                      This update fixes a few issues found in ThruPaint and integrate the translation to Spanish - Spain (Oxer), Spanish - Latin America (Defisto) and Chinese (guanjin)
                                      See main post of this thread for more information on ThruPaint.
                                      See main post of FredoTools thread for download of FredoTools, which includes the script.
                                      • urgenU Offline
                                        urgen
                                        ....O-O-O! ☀ thank you Fredo! 👍
                                        --pupil forever...------
                                        • W Offline
                                          wolfy
                                          @wolfy said:
                                          @wolfi
                                          Fredo,
                                          Hi Fredo,
                                          Well the bugsplat continues on my laptop. I've installed the new version with the same result.
                                          Again, if the material already lives in the model it works just great. Only when a new material is applied using the plugin do I get a bugsplat.
                                          I've tried all types of shapes, groups, components, materails, you name it, all with the same result.
                                          I'm using the latest version of SU Pro, Windows 7 64 bit if that helps, and all your other plugins run perfectly smooth.
                                          Thanks again Fredo for your excellent work!
                                          • fredo6F Offline
                                            @wolfi,
                                            It might be a conflict with another plugin, which you would not have in the PC at the office.
                                            Do you have any plugins dealing with materials or UV mapping?
                                            For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
                                            • 16
                                            • 17
                                            • 2 / 17
