    Architects & Engineers for 9/11 Truth
    95 Posts 27 Posters 3.2k Views 27 Watching
      tomasz
      Knowledge from different sources gives a wider view. I haven't seen pictures of WTC 7 side facing WTC1 & 2. Quite large central piece of elevation and several floor adjacent to the perimeter walls were badly damaged. In my view this doesn't explain symmetrical and free-fall collapse of the building though.
      A&E movement doesn't address pentagon case, because a structural failure there was adequate to the impact.
      1600+ American architects and engineers demand a new investigation which would take their findings into account.
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        tomot
        The URL shows a 70ft, 50-ton steel 3 story column to be installed as a reminder of 911
        http://www.dailymail.co.uk/news/article-1309923/Twin-Towers-column-raised-Ground-Zero-World-Trade-Center-site-again.html
        Some of these ground floor column were not subjected to the so called pancake collapse. All subsequent exterior 3 story columns were staggered during installation, bolted and welded into place as the building height increased. They supported each floor, consisting of metal decking and 5" concrete floor, the metal deck was supported on open web steel joists much like 2x10's floor joists support the floor in your home, these Open web steel joists spanned from the exterior steel columns to the massive interior steel structure, consisting of 4'x 4' square trusses running vertically around the interior elevator cores of each tower the entire height of both towers. Each of the diagonal and vertical steel members making up these massive trusses were 1.5" inch.
        My attached composited pic, shows the so called pancake collapse, and one of the towers during construction.
        Please ask yourself one question?
        Can a pancake collapse, generate horizontal forces capable of ejecting 3 story steel columns, hundreds of feet around the perimeter of the building?
        All of these steel columns also disintegrate before they reached the ground. Not one piece of concrete from each of the 110 floor, survived this so called pancake collapse, which should have been slowed time wise due to gravity. Concrete contained on each floor, which consists of stone/gravel, sand cement, and water to initiate the hydration process, did not survive the collapse. Not one piece of stone or gravel, Not one chair, Not one cabinet, Not one table, Not one bathroom fixture, Not one computer. How is it possible to turn all of this stuff into instant dust in a simple pancake collapse which took less time than normally gravity would act upon?
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
        • kenK Offline
          ken
          "simple pancake collapse which took less time than normally gravity would act upon?"
          Let me count the things that fall faster than gravity. Lets see...........................
          OK, I got it, the collective IQ of pseudo engineers.
          PSS! I have some free energy machines for sale.
          • jeff hammondJ Offline
            I think you might be misintrepring.
            it took less time than a pancake collapse should take if the only things in play were gravity and the top of the building.
              david.
              +1. I'm going to have to remember that one for arguing with other 9/11 truthers. Not only did the US government orchestrate the whole event, it was able to defy the known laws of physics in the process of doing so. On top of that, the government is able to keep hundreds or thousands of conspirators from going public.
              • andybotA Offline
                andybot
                occam's razor anyone? What kind of rube goldberg setup of explosives and timers and etc. would be required to precisely mimic the obvious and largely accepted version of events?
                  There are many puzzling and unexplained matters with 9/11...
                  However, the "leap from abject ignorance to statements of absolute certainty", is with the 9/11 conspiracy supporters, very like the UFO-logists or supporters of other 'fringe' ideas...
                  You saw a UFO.
                  It must have been alien visitors in a flying saucer.
                  The second conclusion does not follow from the first statement, at all.
                  It is one of many possible explanations... but there are very many more possibilities that are more likely - the clue is in the word 'UFO'; it was 'Unidentified', so then there is no certainty it was aliens at all !
                  Humans don't like 'not knowing', so it's easy for any of us to fall into the trap of taking an explanation that fits the observations, when in fact there's little 'proof' that might lead to that conclusion, and of course many less far-fetched explanations that fit equally as well.
                  Back to 9/11...
                  I am amazed that the anomalies in many of the observed events and what we might have expected have not be investigated more fully. We don't understand exactly why the buildings collapsed how they did, but of course that doesn't mean they were 'demolished'! What it should mean is that we should still be seeking to understand what really happened during these catastrophes. It seems to me there are many important lessons to be learnt by architects, engineers, firefighters et al, about how such large structures really perform at these extremes for damage, and how we might then design/plan to avoid/mitigate such catastrophic outcomes...
                  • Alan FraserA Offline
                    Alan Fraser
                    I don't understand the 'faster than freefall' stuff. Calculations demonstrate that (given the height of the towers) the roof should have reached the ground in approx. 9.7 seconds. It is, after all, only high school maths...standard gravitational acceleration for 10 seconds slightly exceeds the height of the towers. The unfortunate jumpers can be seen to travel the same route in a little less than that.
                    Given the debris cloud surrounding the collapsing buildings, it's impossible to determine exactly when the roof structure hit ground level, but realistic estimates put one tower at around 15 seconds and the other one nearer 20 seconds. How is this faster than freefall?
                    It seems like the 9/11 truthers only count the time between the start of the collapse and the leading edge of the debris cloud hitting the ground. However, much of this debris can clearly be seen being pneumatically ejected from the structures far below the actual pancacking action...and this differential distance increases with time. It's reasonable to say (and is backed up by brief glimpses of the upper parts of the structure inside the cloud...like the masts) that when the cloud hits the ground there is something like 40 stories if intact tower, hidden inside, still awaiting its turn to get flattened...and quite a few stories of by-now nearly freefalling and still largely integrated upper tower above that.
                    In short, the top of the buildings hit the ground pretty much on schedule.
                    3D Figures
                    • andybotA Offline
                      andybot
                      That's the thing - the 'truthers' argue all these minutiae. There are certainly complex phsyical actions occurring and like TIG says, there is plenty to still understand since this is all happening at the extremes of forces. But the jump to seeing some huge rigged conspiracy beyond a couple airliners speeding and loaded with fuel slicing into very tall skyscrapers just seems far-fetched.
                        anyone that doesn't 100% believe the official story is labeled a 'truther' 'looney' 'conspiracy theorist' etc..
                        …when in fact, many of those tin foil hat wearing mofos simply want a more thorough investigation and/or access to certain informations in order to conduct private investigations..
                        a humongous crime took place.. the case was solved in 5 hours.. i call bullshit.. that doesn't make me a lunatic does it?
                        • andybotA Offline
                          andybot
                          Jeff,
                          Yes, it was a crime. It was perpetrated by whoever was flying those airplanes. To say that somehow the building was demolished internally just on the face of it makes no sense. It would have had to be something unbelievably coordinated and also withstand two airplanes flying into the towers.
                          I am specifically labeling the conspiracy theorists as the truthers.
                            @andybot said:
                            Jeff,
                            well it was a conspiracy, right? or did one person act alone?
                            thing is, half of America thinks saddam Hussein did it. who are the crazies again?
                            the architects, the ones in the video, are full on legit and well educated people. and there are thousands of them.. to dismiss what they have to say or observations made by them is shortsighted if you ask me..
                            I also can't recall any of them outright accusing any person or group of people as being the perps.. they're pretty much saying there are holes in the story and would like a new investigation.
                            • andybotA Offline
                              andybot
                              no, it was a group of hijackers, what do you mean one person acting alone?
                              Well that was W. and crew conflating Iraq and al-Queda
                              I'm saying that blaming some Deux ex machina explosions for causing the towers to come down just seems pointless. Finding out more to understand how structures catastrophically fail in extreme conditions is plenty worthwhile.
                                [wiki]a conspiracy is an agreement between two or more persons to break the law at some time in the future. [/wiki]
                                just saying that it's highly highly (highly) probable that a conspiracy took place.. i'm sure you agree with that.. so are you a conspiracy theorist too? (point is, i think it's a bit of a misnomer)
                                who's blaming anyone? (re: this thread & the subjects of the thread)
                                but yeah, regarding your second sentence, i agree and i hope most people can.. If those buildings (all 3) fell due to fire and a big amount of people that actually design/build those types of building think they should of fully withstood the planes/fire then.. well, we have a problem.
                                • andybotA Offline
                                  andybot
                                  OK, plenty of semantics to get wrong here. What I mean is that there seems to be some underlying notion of a government (or alien... 😒 ) coverup. I think the various loose ends are generally attributable to run-of-the-mill incompetence in the original investigation. By "Conspiracy": I mean specifically the idea that some agents (government or otherwise) rigged the WTC buildings to explode and miraculously timed it to look like hijacked airplanes crashing into the building. I don't buy that.
                                    i don't believe it either (well, let me rephrase.. i don't know what happened but there is a possibility that it was someone(s) other than 19 egyptians and some rich saudi arabian)
                                    i do think it's possible for the buildings to have been rigged with explosives of some sort prior to the plane hitting..
                                    i mean really.. what would it take? a group of 4 or 5 guys with proper security clearance working for a month or two? it's not that farfetched.
                                    not any more farfetched than 20 guys learning how to fly commercial jets over a period of 3-4 years then hijacking them with box cutters and driving them into a few buildings..
                                    both stories, to me, are just as likely to occur.
                                    • andybotA Offline
                                      andybot
                                      Well, at least the slick thing about the guys with the box cutters and the flying lessons is that it was out of the realm of the imaginable before 9/11. Explosives in the building - that was already tried in WTC, and I would imagine a lot more attention would be paid to that sort of effort, especially considering the quantities of explosives required. Also, to be able to coordinate the two in a convincing fashion would take some serious engineering. Unless you're saying that there were no aircraft hitting the buildings on 9/11... in that case back to the tinfoil hat 😒
                                      • StinkieS Offline
                                        Stinkie
                                        (...) 19 egyptians and some rich saudi arabian)
                                        If memory serves, there were no Egyptians among the hijackers. Most were Saudis, I believe.
                                        The Pentagon possibly mistook Iraq for Saudi Arabia. 👿
                                        Could very well be, but where's the proof? So far, no tangible evidence seems to have surfaced. Which would presuppose a giant cover-up. Did someone mention Occam's razor yet?
                                          it seems (again, i'm trying to be careful as to how i word this stuff but i'm sure i'll mess it up soon enough 😉 ), that much of the evidence, if there was any to be found, was destroyed prior to proper investigation.. that was by far the biggest crime scene ever in the city and i don't think it was treated as such..
                                          (but hey, we've all received the same info here.. we're all drawing conclusions from the same pool.. for all i know, the beams/rubbble were inspected prior to destroying them.. i just haven't read anything about it.)
                                          likewise, i don't think it would be a 'giant' coverup… very few people would need to be involved.. it's not like, if it were a u.s. based attack, the whole government is in on it but keeping their mouths shut..
                                          nah.. even those bowling for columbine kids were talking about doing the same thing.. and they died a couple of years prior to 2001..
                                          the japanese have definitely used planes for missiles against the u.s.. the buildings were designed with the possibility of an aircraft crashing into them (granted, probably not with the idea that the plane would be a weapon.. but an accident such as the plane that crashed into the empire state building back in the day (but that thing easily survived fwiw)..
                                          i think it was fully imaginable prior to 9/11 and i also think the defense dept has had this on their radar since, well, since a few years after kittyhawk..
                                          no.. i saw planes flying into buildings 😉
                                          re: 'some serious engineering'
                                          maybe.. i don't know.. i've never blew up a building.. half of me tends to believe it wouldn't be incredibly hard to do though.. (assuming access to high tech explosives and key parts of the buildings etc.)
                                          • andybotA Offline
                                            andybot
                                            Yep Tom - my first post on this thread!
                                            Jeff, my main point of contention is that the explosives and the planes crashing would have to be coordinated to some degree. That would point to a broader conspiracy.
                                            • 4 / 5
