    Architects & Engineers for 9/11 Truth
    95 Posts 27 Posters 10.5k Views 27 Watching
      I think the whole issue is nothing to do with a mega-conspiracy - do your serious think the Bush administration was smart enough to organize this - it more to do with an incredibly shoddy security operation before the events, some patently unrealistic coincidences [like terrorist's passport found in the street???] which some intern dragged in to 'fix' the embarrassment, followed by a investigation that borders on the criminally inept - evidence was not preserved and large areas of possibilities went untested [like testing for explosives]. The FEMA/NIST reports are clearly incomplete - the computer simulation of Building 7 doesn't even look like the filmed collapse! Why won't they give details of the assumed conditions and calculations to professional engineers? Modern multistory steel-framed building do NOT collapse in even major fires - they sag/buckle and suffer localized damage - the WTC towers were designed to withstand plane impacts AND fires etc - so... since they DID collapse catastrophically [we saw them!] then probably something is wrong with the long established design ideas of engineers... if so it's the government's duty to ensure that new buildings are better built and old ones are made safer - they seem to have learnt nothing from the collapses. In the UK after the Ronan Point flats collapse where a deck of cards effect led to a catastrophic failure on one corner of a block of flats the public-enquiry that followed made many recommendations, including a complete change to Codes of Practice and Building Regulations: now building over a few storys tall must have additional structural precautions - floors and beams must be 'stitched' together and 'progressive collapse' rules - so for example if a column fails only the beams/floors connected to that column can be affected by its failure and there can be no 'domino' effect - the structure as a whole much remain intact and support the collapse elements - so removing a 'central core' column will only affect the four adjacent beams and immediate floor slab over and the floor-slab and beams/columns below must carry the debris as well as what they might normally carry; the column on the floor must remain in place and its beams continue to support their loads: the area around the damage will undoubtedly 'sag' and be badly damaged, but there should be no 'house of cards' 'progressive collapse' - all structural members must be rigidly connected together to ensure the integrity is preserved...
      This a very interesting and balanced review of what might have happened http://www.tms.org/pubs/journals/jom/0112/eagar/eagar-0112.html
      As a result of the manipulated hysteria the USA's civil-liberties have been eroded and their buildings are NOT any safer...
      • T
        tim
        Claims that the buildings could not have collapsed due to 'merely' the aircraft fuel etc are completely forgetting the ChemTrail tanks installed on the planes. Goodness knows how hot that stuff burns. And of course since the flights were interrupted, the tanks would not have been activated and so would have been full. Think about it sheeple!
          mics_54
          asspay the ongbay!
            Aluminum melts at ~660C and zinc at ~419C
            Steel actually melts into a liquid at ~1500C, buts starts to weaken at just ~450C.
            'Carbon' burns at ~3000C, BUT in open air is unlikely to exceed a third of that ~1000C.
            A typical confined 'furniture' fire is unlikely to exceed ~650C.
            Jet fuel burns in open air at only ~315C, BUT it can burn when confined at up ~750C, so it is sufficient on its own to weaken the steel structure - combined with secondary fires this is therefore quite likely.
            The poorly applied sprayed fire-resistant insulation was easily knocked off by the impact/explosions exacerbating the potential weaknesses.
            The prolonged heating of exposed parts the 18m long beams could have caused localized weaknesses and uneven expansion, then distortion and excessive stresses, causing unexpected multiple joint failures.
            Although the buildings were designed to withstand impacts and fires, the fires resulting from so much fuel etc could easily have weakened the buildings, leading to their collapse.
            Building 7 completely collapsed after having no major impacts [edit: I accept that parts of the main towers' collapse probably did damage WTC7 more than it appears from the 'back'] and several 'relatively minor' fires... is of the most concern. Localized damaged was to be expected, but a complete catastrophic collapse should not have happened had the building's design anticipated 'progressive collapse'. There seems to be no lessons learnt or definitive answers as to why this happened to this building, therefore engineers/architects cannot design new buildings with the certain knowledge that they can safely withstand relatively minor damage: occupants and firefighters should be very concerned about this...
            • Alan FraserA
              Alan Fraser
              [flash=640,390:36e2sn76]http://www.youtube.com/v/IwdD6ERutEI?version=3[/flash:36e2sn76]
              Actually, Building 7 was quite badly damaged...just not on the North side (why would it be?) which is where all the conspiracy theorists like to select their photos and videos from. There were also fires reported on no fewer than 16 of its floors...again, not quite the minimal conflagration the the CTs would like you to believe.
              I'm not saying lessons shouldn't be learned; and the building does appear to have had an Achilles heel...a single column that proved to be the final straw that broke its back...but it's a fallacy that it collapsed whilst relatively undamaged.
              The Solidworks reconstruction of the Pentagon attack, linked at the end of this video is also very impressive.
              3D Figures
                MartinK
                And don't forget about the effects of the highly acidic bodily fluids of the alien bodies which had been hidden in vaults, originally intended for gold bullion, in the towers for years and were dislodged from their protective containers by the plane impacts. Think about that. LOL
                • T
                  tomasz
                  Knowledge from different sources gives a wider view. I haven't seen pictures of WTC 7 side facing WTC1 & 2. Quite large central piece of elevation and several floor adjacent to the perimeter walls were badly damaged. In my view this doesn't explain symmetrical and free-fall collapse of the building though.
                  A&E movement doesn't address pentagon case, because a structural failure there was adequate to the impact.
                  1600+ American architects and engineers demand a new investigation which would take their findings into account.
                  • T
                    tomot
                    The URL shows a 70ft, 50-ton steel 3 story column to be installed as a reminder of 911
                    http://www.dailymail.co.uk/news/article-1309923/Twin-Towers-column-raised-Ground-Zero-World-Trade-Center-site-again.html
                    Some of these ground floor column were not subjected to the so called pancake collapse. All subsequent exterior 3 story columns were staggered during installation, bolted and welded into place as the building height increased. They supported each floor, consisting of metal decking and 5" concrete floor, the metal deck was supported on open web steel joists much like 2x10's floor joists support the floor in your home, these Open web steel joists spanned from the exterior steel columns to the massive interior steel structure, consisting of 4'x 4' square trusses running vertically around the interior elevator cores of each tower the entire height of both towers. Each of the diagonal and vertical steel members making up these massive trusses were 1.5" inch.
                    My attached composited pic, shows the so called pancake collapse, and one of the towers during construction.
                    Please ask yourself one question?
                    Can a pancake collapse, generate horizontal forces capable of ejecting 3 story steel columns, hundreds of feet around the perimeter of the building?
                    All of these steel columns also disintegrate before they reached the ground. Not one piece of concrete from each of the 110 floor, survived this so called pancake collapse, which should have been slowed time wise due to gravity. Concrete contained on each floor, which consists of stone/gravel, sand cement, and water to initiate the hydration process, did not survive the collapse. Not one piece of stone or gravel, Not one chair, Not one cabinet, Not one table, Not one bathroom fixture, Not one computer. How is it possible to turn all of this stuff into instant dust in a simple pancake collapse which took less time than normally gravity would act upon?
                    my plugins
                    tomot
                    • kenK
                      ken
                      "simple pancake collapse which took less time than normally gravity would act upon?"
                      Let me count the things that fall faster than gravity. Lets see...........................
                      OK, I got it, the collective IQ of pseudo engineers.
                      PSS! I have some free energy machines for sale.
                      • jeff hammondJ
                        I think you might be misintrepring.
                        it took less time than a pancake collapse should take if the only things in play were gravity and the top of the building.
                          david.
                          +1. I'm going to have to remember that one for arguing with other 9/11 truthers. Not only did the US government orchestrate the whole event, it was able to defy the known laws of physics in the process of doing so. On top of that, the government is able to keep hundreds or thousands of conspirators from going public.
                          • andybotA
                            andybot
                            occam's razor anyone? What kind of rube goldberg setup of explosives and timers and etc. would be required to precisely mimic the obvious and largely accepted version of events?
                              There are many puzzling and unexplained matters with 9/11...
                              However, the "leap from abject ignorance to statements of absolute certainty", is with the 9/11 conspiracy supporters, very like the UFO-logists or supporters of other 'fringe' ideas...
                              You saw a UFO.
                              It must have been alien visitors in a flying saucer.
                              The second conclusion does not follow from the first statement, at all.
                              It is one of many possible explanations... but there are very many more possibilities that are more likely - the clue is in the word 'UFO'; it was 'Unidentified', so then there is no certainty it was aliens at all !
                              Humans don't like 'not knowing', so it's easy for any of us to fall into the trap of taking an explanation that fits the observations, when in fact there's little 'proof' that might lead to that conclusion, and of course many less far-fetched explanations that fit equally as well.
                              Back to 9/11...
                              I am amazed that the anomalies in many of the observed events and what we might have expected have not be investigated more fully. We don't understand exactly why the buildings collapsed how they did, but of course that doesn't mean they were 'demolished'! What it should mean is that we should still be seeking to understand what really happened during these catastrophes. It seems to me there are many important lessons to be learnt by architects, engineers, firefighters et al, about how such large structures really perform at these extremes for damage, and how we might then design/plan to avoid/mitigate such catastrophic outcomes...
                              • Alan FraserA
                                Alan Fraser
                                I don't understand the 'faster than freefall' stuff. Calculations demonstrate that (given the height of the towers) the roof should have reached the ground in approx. 9.7 seconds. It is, after all, only high school maths...standard gravitational acceleration for 10 seconds slightly exceeds the height of the towers. The unfortunate jumpers can be seen to travel the same route in a little less than that.
                                Given the debris cloud surrounding the collapsing buildings, it's impossible to determine exactly when the roof structure hit ground level, but realistic estimates put one tower at around 15 seconds and the other one nearer 20 seconds. How is this faster than freefall?
                                It seems like the 9/11 truthers only count the time between the start of the collapse and the leading edge of the debris cloud hitting the ground. However, much of this debris can clearly be seen being pneumatically ejected from the structures far below the actual pancacking action...and this differential distance increases with time. It's reasonable to say (and is backed up by brief glimpses of the upper parts of the structure inside the cloud...like the masts) that when the cloud hits the ground there is something like 40 stories if intact tower, hidden inside, still awaiting its turn to get flattened...and quite a few stories of by-now nearly freefalling and still largely integrated upper tower above that.
                                In short, the top of the buildings hit the ground pretty much on schedule.
                                3D Figures
                                • andybotA
                                  andybot
                                  That's the thing - the 'truthers' argue all these minutiae. There are certainly complex phsyical actions occurring and like TIG says, there is plenty to still understand since this is all happening at the extremes of forces. But the jump to seeing some huge rigged conspiracy beyond a couple airliners speeding and loaded with fuel slicing into very tall skyscrapers just seems far-fetched.
                                  • jeff hammondJ
                                    anyone that doesn't 100% believe the official story is labeled a 'truther' 'looney' 'conspiracy theorist' etc..
                                    …when in fact, many of those tin foil hat wearing mofos simply want a more thorough investigation and/or access to certain informations in order to conduct private investigations..
                                    a humongous crime took place.. the case was solved in 5 hours.. i call bullshit.. that doesn't make me a lunatic does it?
                                    • andybotA
                                      andybot
                                      Jeff,
                                      Yes, it was a crime. It was perpetrated by whoever was flying those airplanes. To say that somehow the building was demolished internally just on the face of it makes no sense. It would have had to be something unbelievably coordinated and also withstand two airplanes flying into the towers.
                                      I am specifically labeling the conspiracy theorists as the truthers.
                                      • jeff hammondJ
                                        @andybot said:
                                        Jeff,
                                        well it was a conspiracy, right? or did one person act alone?
                                        thing is, half of America thinks saddam Hussein did it. who are the crazies again?
                                        the architects, the ones in the video, are full on legit and well educated people. and there are thousands of them.. to dismiss what they have to say or observations made by them is shortsighted if you ask me..
                                        I also can't recall any of them outright accusing any person or group of people as being the perps.. they're pretty much saying there are holes in the story and would like a new investigation.
                                        • andybotA
                                          andybot
                                          no, it was a group of hijackers, what do you mean one person acting alone?
                                          Well that was W. and crew conflating Iraq and al-Queda
                                          I'm saying that blaming some Deux ex machina explosions for causing the towers to come down just seems pointless. Finding out more to understand how structures catastrophically fail in extreme conditions is plenty worthwhile.
                                          • jeff hammondJ
                                            [wiki]a conspiracy is an agreement between two or more persons to break the law at some time in the future. [/wiki]
                                            just saying that it's highly highly (highly) probable that a conspiracy took place.. i'm sure you agree with that.. so are you a conspiracy theorist too? (point is, i think it's a bit of a misnomer)
                                            who's blaming anyone? (re: this thread & the subjects of the thread)
                                            but yeah, regarding your second sentence, i agree and i hope most people can.. If those buildings (all 3) fell due to fire and a big amount of people that actually design/build those types of building think they should of fully withstood the planes/fire then.. well, we have a problem.
                                            • 3 / 5
