    Plugin Idea: place dimensions
    6 Posts 3 Posters 336 Views 3 Watching
    • bagateloB Offline
      bagatelo
      I wonder if there is some plugin that when you select an object, automatically place the dimensions of it. This would serve to build detail for woodworkers. It would be interesting if it were possible to enable these dimensions only in the tab enabled or created.
      Please open the attached file to understand my idea.
      exemplo.skp
      • bagateloB Offline
        bagatelo
        This may seem stupid to just one piece, but if you have many parts to detail with measurements, will be very handy.
          There is a problem where dimensions are not accessible to the Ruby API.
          But even if they where, how would the script know what part of the object to dimension?
          • bagateloB Offline
            bagatelo
            BoundingBox
            http://forums.sketchucation.com/viewtopic.php?t=28851
              It IS possible, in convoluted code, to add a premade SKP-dimension [component] onto a given 'edge' and then explode it, BUT it won't be 'attached' to the object afterwards.
              As thomthom said it's [currently] beyond the API...
              • bagateloB Offline
                bagatelo
                Ok, I understand. So let's dream. See the "EXEMPLO".
                exemplo.skp
