    Water Bottle
    25 Posts 12 Posters 5.3k Views 12 Watching
    • C
      cmoreink
      Great modeling and rendering job!
      Can you please upload file in ver. 7 SU.
      my portfolio
      • N
        ninopiamonte
        I like the realism of the cap and the water.
        • HieruH
          Hieru
          Here you go:
          WaterBottle_Proxy_SU7.skp
          www.davidhier.co.uk
          • boofredlayB
            boofredlay
            Great work David.
            • andybotA
              andybot
              What engine did you render with? The cap plastic material is spot-on. (I was just trying to do a similar material recently in vray, so curious how you got there.)
              • HieruH
                Hieru
                Thanks Eric πŸ‘
                I used Thea. I'm not sure if there is any similarity in the material system, but the cap plastic is just a basic clear glass with 20% Roughness and 40% Roughness Tr.
                www.davidhier.co.uk
                • soloS
                  Thanks for that I was wondering also.
                  • andybotA
                    andybot
                    Cool, thanks! Yes, the transmission and specular roughness parameters make sense.
                    edit: - oh yeah, another question - did you model the water as a separate object?
                    • HieruH
                      Hieru
                      The only part of the water that is separate is the top surface. That surface has one water material applied to it and the part of the bottle below the top surface has another material applied, which you have to assign a container material (in this case the plastic used for the rest of the bottle).
                      There's a really useful diagram over on the Thea forum, but I can't find it at the moment.
                      www.davidhier.co.uk
                      • C
                        cmoreink
                        @hieru said:
                        Here you go:
                        [attachment=0:67vktd13]<!-- ia0 -->WaterBottle_Proxy_SU7.skp<!-- ia0 -->[/attachment:67vktd13]
                        Thanks. I will try to render this in vray.
                        my portfolio
                        • L
                          leminilab
                          http://www.thearender.com/forum/viewtopic.php?f=54&t=5817&hilit=glass+liquid
                          I don't know if you must be logged in first to read the post... πŸ˜•
                          • "Live every day as if it were your last and then some day you'll be right."
                          • "ThomThom rules!!!"
                          • HieruH
                            Hieru
                            Frederik's diagram on that thread is pretty good and Notareal provides some useful variations, but I thought all the options might be a bit confusing.
                            www.davidhier.co.uk
                              Roger
                              Some Post Pro
                              Just some post pro to see what you think. The DOF simulation and opening up the tones in the top of the bottle are the most important effects.
                              http://www.azcreative.com
                              • HieruH
                                Hieru
                                Thanks for that Roger - I had completely overlooked the possibility of using a little DOF.
                                www.davidhier.co.uk
                                • N
                                  notareal
                                  Keep in mind that the posted Frederik's diagram is for Kerkythea. Even as models needs to be split a bit similarly in Thea, same diagram does not apply. Use of "Container" is required for correct result. Study Thea example scene GlassOfWater.scn.thea (that you can find under File > Scenes > Examples). Also on said topic it's mentioned that you need to use mouse right click > Assign Interface. "Assign Interface" was replaced in some point with term "Assign Container".
