    Water Bottle
    25 Posts 12 Posters 5.3k Views 12 Watching
    • brookefoxB
      brookefox
      Nice bottle render and thanks much for the tut. Always useful to me, anyway.
      (Curious thing on the render: to me looks like a short bottle with a headless (and mismatching) reflection, and the bubbles on the mirror surface seem to agree with this reading, but it reads right, too.)
      ~ Brooke
      • brookefoxB
        brookefox
        Just that the narrowing of the waist looks like it could actually be the base. No importa, just curious. After all it is not cut-and-paste. Gorgeous, really, if hairless.
        ~ Brooke
        • cottyC
          cotty
          @hieru said:
          No problem. I was originally going to post it to your thread, but I didn't think it was 'simple' enough.
          impressive is a good excuse not to be simple 😎
          my SketchUp gallery
          • HieruH
            Hieru
            I can see what you mean now Brooke. I could probably rearrange some of the lights and reflectors so that the waist doesn't get lost in the background, but it will be quicker and just as effective to do it in post.
            The bottle does have some scratches and a subtle amount of bump, but it doesn't show up too well.........and when I increase the values it just looks unrealistic. Again, maybe that's something that I can do with PS.
            www.davidhier.co.uk
            • C
              cmoreink
              Great modeling and rendering job!
              Can you please upload file in ver. 7 SU.
              my portfolio
              • N
                ninopiamonte
                I like the realism of the cap and the water.
                • HieruH
                  Hieru
                  Here you go:
                  WaterBottle_Proxy_SU7.skp
                  www.davidhier.co.uk
                  • boofredlayB
                    boofredlay
                    Great work David.
                    • andybotA
                      andybot
                      What engine did you render with? The cap plastic material is spot-on. (I was just trying to do a similar material recently in vray, so curious how you got there.)
                      • HieruH
                        Hieru
                        Thanks Eric πŸ‘
                        I used Thea. I'm not sure if there is any similarity in the material system, but the cap plastic is just a basic clear glass with 20% Roughness and 40% Roughness Tr.
                        www.davidhier.co.uk
                        • soloS
                          Thanks for that I was wondering also.
                          • andybotA
                            andybot
                            Cool, thanks! Yes, the transmission and specular roughness parameters make sense.
                            edit: - oh yeah, another question - did you model the water as a separate object?
                            • HieruH
                              Hieru
                              The only part of the water that is separate is the top surface. That surface has one water material applied to it and the part of the bottle below the top surface has another material applied, which you have to assign a container material (in this case the plastic used for the rest of the bottle).
                              There's a really useful diagram over on the Thea forum, but I can't find it at the moment.
                              www.davidhier.co.uk
                              • C
                                cmoreink
                                @hieru said:
                                Here you go:
                                [attachment=0:67vktd13]<!-- ia0 -->WaterBottle_Proxy_SU7.skp<!-- ia0 -->[/attachment:67vktd13]
                                Thanks. I will try to render this in vray.
                                my portfolio
                                • L
                                  leminilab
                                  http://www.thearender.com/forum/viewtopic.php?f=54&t=5817&hilit=glass+liquid
                                  I don't know if you must be logged in first to read the post... πŸ˜•
                                  • "Live every day as if it were your last and then some day you'll be right."
                                  • "ThomThom rules!!!"
                                  • HieruH
                                    Hieru
                                    Frederik's diagram on that thread is pretty good and Notareal provides some useful variations, but I thought all the options might be a bit confusing.
                                    www.davidhier.co.uk
                                      Roger
                                      Some Post Pro
                                      Just some post pro to see what you think. The DOF simulation and opening up the tones in the top of the bottle are the most important effects.
                                      http://www.azcreative.com
                                      • HieruH
                                        Hieru
                                        Thanks for that Roger - I had completely overlooked the possibility of using a little DOF.
                                        www.davidhier.co.uk
                                        • N
                                          notareal
                                          Keep in mind that the posted Frederik's diagram is for Kerkythea. Even as models needs to be split a bit similarly in Thea, same diagram does not apply. Use of "Container" is required for correct result. Study Thea example scene GlassOfWater.scn.thea (that you can find under File > Scenes > Examples). Also on said topic it's mentioned that you need to use mouse right click > Assign Interface. "Assign Interface" was replaced in some point with term "Assign Container".
