    White colour instead of bluish tint?
    renderpluginsextensions
    19 Posts 7 Posters 5.4k Views 7 Watching
      Adjust the White Balance under Camera.
      • N
        nomeradona
        @john2 said:
        How can I change the bluish tint in shadows for pure objects that i get using the default setting renders?
        fernando made a video about this here. http://youtu.be/cPxtadpyM20
        • andybotA
          andybot
          there's also this one: http://www.youtube.com/watch?v=NnUEwI76Lkc
          explains turbidity, ozone, etc.
          • john2J
            john2
            well how should i adjust , what colour should i set it to?
            actually i'm in favour of this balance technique since it would give white light only, ozone/turbitidy is tricky. It gives yellowish renders.
            one more thing how is the vfb history seen as in tutorial video?
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
              rspierenburg
              You can also always set a whitepoint in post processing.
              • john2J
                john2
                i don't understand, what's that? πŸ˜•
                • andybotA
                  andybot
                  currently not working in vfsu 1.49.01
                    rspierenburg
                    For instance, if you render your image you can then bring it into Photoshop (or other editing programs) and tell Photoshop what is supposed to be white, it will then shift all your colors accordingly and your blueish tinge will turn white and all your other colors should be proper as well.
                    Rob
                    • john2J
                      john2
                      Rob
                      how is that done? can you elaborate the procedure?
                      • stefanqS
                        stefanq
                        How to Set the White Point in Photoshop:
                        http://www.ehow.com/how_7176906_set-white-point-photoshop.html
                        • john2J
                          john2
                          that doesn't give good results, 😞.
                          can anyone please tell the white balance [camera] technique?
                          • eidam655E
                            eidam655
                            examples: http://www.spot3d.com/vray/help/150SP1/examples_vrayphysicalcamera.htm
                            short tutorial: http://www.mintviz.com/tutorials/white-balance-setup-with-with-v-ray-physical-camera-and-3ds-max/, it is for 3DSMax but i think it's applicable to VfSU, too.
                            I'm using SketchUp 2017, V-Ray 3.4
                            • john2J
                              john2
                              I did it that way only but no success
                              this is with white balance set to 237,246,253 [RGB]
                              This is default render
                              this is with value 130,156,178
                              REND.skp
                                rspierenburg
                                Here is my attempt by using Photoshop's Color Balance Adjustment.
                                Rob
                                • john2J
                                  john2
                                  its coming greenish, photoshop doesn't work, i tried a lot 😞
                                  • andybotA
                                    andybot
                                    you could always just reduce the saturation...
                                    • john2J
                                      john2
                                      but the yellowish colour will still be there wouldn't it? What setting do you use for bluish face issue?
                                      • andybotA
                                        andybot
                                        sorry, I meant in photoshop - use the "hue/Saturation" adjustment. Adjust the saturation slider down until it looks more gray.
