    White colour instead of bluish tint?
    renderpluginsextensions
    19 Posts 7 Posters 5.1k Views 7 Watching
      rspierenburg
      @john2 said:
      @rspierenburg said:
      You can also always set a whitepoint in post processing.
      i don't understand, what's that? πŸ˜•
      For instance, if you render your image you can then bring it into Photoshop (or other editing programs) and tell Photoshop what is supposed to be white, it will then shift all your colors accordingly and your blueish tinge will turn white and all your other colors should be proper as well.
      Rob
      • john2J Offline
        john2
        Rob
        how is that done? can you elaborate the procedure?
        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        • stefanqS Offline
          stefanq
          How to Set the White Point in Photoshop:
          | ehow.com
          ehow.com (www.ehow.com)
          • john2J Offline
            john2
            that doesn't give good results, 😞.
            can anyone please tell the white balance [camera] technique?
            • eidam655E Offline
              eidam655
              examples: http://www.spot3d.com/vray/help/150SP1/examples_vrayphysicalcamera.htm
              short tutorial: http://www.mintviz.com/tutorials/white-balance-setup-with-with-v-ray-physical-camera-and-3ds-max/, it is for 3DSMax but i think it's applicable to VfSU, too.
              I'm using SketchUp 2017, V-Ray 3.4
              • john2J Offline
                john2
                I did it that way only but no success
                this is with white balance set to 237,246,253 [RGB]
                This is default render
                this is with value 130,156,178
                REND.skp
                  rspierenburg
                  Here is my attempt by using Photoshop's Color Balance Adjustment.
                  Rob
                  • john2J Offline
                    john2
                    its coming greenish, photoshop doesn't work, i tried a lot 😞
                    • andybotA Offline
                      andybot
                      you could always just reduce the saturation...
                      • john2J Offline
                        john2
                        but the yellowish colour will still be there wouldn't it? What setting do you use for bluish face issue?
                        • andybotA Offline
                          andybot
                          sorry, I meant in photoshop - use the "hue/Saturation" adjustment. Adjust the saturation slider down until it looks more gray.
